How do you remove a Tank Pad???
GreigR
PostPosted: 00:30 - 15 Mar 2005    Post subject: How do you remove a Tank Pad??? Reply with quote
Any tips guys as I want to change the one that came with the bike but its well stuck on.
Confused Confused Confused Embarassed
extreme3d
PostPosted: 00:36 - 15 Mar 2005    Post subject: Reply with quote
Use a hot air gun, or failing that a hairdryer. Gently warm it and it will easily peel off.
strag
PostPosted: 01:21 - 15 Mar 2005    Post subject: Reply with quote
The top layer should come off easily leaving a glue residue. I used white spirit to remove this and worked fine.
carbon bling
Jrod
Page 3 Girl
PostPosted: 01:27 - 15 Mar 2005    Post subject: Reply with quote
I tried to do this without heat, I didn't want paint on the tank anyways.... Doh!
Johnny GSX-R
PostPosted: 02:18 - 15 Mar 2005    Post subject: Reply with quote
The only safe way to remove it without damage is by using a kettle of boiling water poured gently over the pad then ease it off as the heat softens the glue.. Use a drop of petrol on a cloth to remove the remaining glue then polish the tank prior to replacing.
It is possible to burn the paint with a heatgun or worse set the damn thing on fire!
I used to be a professional valeter and the hot water was a trick i used daily.
Moss46
PostPosted: 08:57 - 15 Mar 2005    Post subject: Reply with quote
WD40 is the best stuff to get sticky crap ond tar off painted surfaces.
I would CAREFULLY use a sharp razor blade and start at the top, this also works on well stuck stickers
Johnny GSX-R
PostPosted: 09:37 - 15 Mar 2005    Post subject: Reply with quote
Are you trying to wreck the fuel tank on this bike???? A sharp razor blade!! if it digs into the laquer its knackered... Thumbs Down
ginguar
PostPosted: 12:40 - 15 Mar 2005    Post subject: Reply with quote
I found the only way to get the old one off my boyfriend's bike was to use my nails to scratch it off.
The last post was made 21 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 54.64 Kb
