| Renton |
 Renton World Chat Champion
 Posted: 15:19 - 27 Jan 2018 Post subject: Brakes Stuck On |
Regrettably, the bike has been left untouched for the last month...outside.
I've gone to move it today, but it will not budge anywhere. It looks as though the front brakes are stuck on.
How do I go about taking the callipers off to clean them, if I cannot even move the front wheel. So bad that I was able to lift the bike off the ground by holding one of the front wheel spokes.
Yes, I am suitably ashamed of myself. ____________________ This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless. |
 Posted: 15:25 - 27 Jan 2018 Post subject: |
There's probably nothing wrong with the calipers the pads will be rusted to the disks. Give the front tyre a few good clouts with a big hammer right on the front. Take care not to hit the wheel or the mudguard. ____________________ a.k.a 'Geri'
| Irn-Bru |
 Irn-Bru World Chat Champion
 Posted: 15:39 - 27 Jan 2018 Post subject: |
Wouldn't advise pushing it, recently ripped the rear pads clean off on my KTM doing that  ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| Renton |
| Courier265 |
 Courier265 World Chat Champion
| Pjay |
 Pjay World Chat Champion
| Howling TerrorOutOfOffice |
| Pjay |
| Polarbear |
 Polarbear Super Spammer
 Posted: 18:02 - 27 Jan 2018 Post subject: |
Agree with Pete. One of the few times a bit of brute force and ignorance is called for.  ____________________ Victory Cross Country American tractor. |
| Irn-Bru |
 Posted: 18:38 - 27 Jan 2018 Post subject: |
Worst part was it was in front of a mechanic that came to collect the bike for a service... hang on a minute *clunk* oops... right, I've got another job for you  ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
| Bozzy. |
 Bozzy. Scooby Slapper
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 20:51 - 27 Jan 2018 Post subject: |
| Nobby the Bastard |
| kerr |
 kerr World Chat Champion
 Posted: 21:30 - 27 Jan 2018 Post subject: |
| Nobby the Bastard |
| MCN |
 MCN Super Spammer
 Posted: 02:08 - 28 Jan 2018 Post subject: |
| Teflon-Mike |
 Posted: 05:34 - 28 Jan 2018 Post subject: |
Once upon a time... it was 'more' common for an unused bikes brakes to rust-on.... bain of metalised pads and cast discs... (mental anguish scream BLUDI-GUZZI!!)
Since stainless discs became the norm, it's not been so common.... but getting more so.... probably chitty non OEM Chinky un-stainless discs to blame
Otherwise, and especuliarly on Honda's, more likely a gummed up floating caliper... tendency is to grab the brake when you grab the bars.. corroded caliper grips disc, corrosion makes it stick there.
Brute force over ignorance can 'un-stick' them, but ht is that calipers probably need an overhaul, & thorough clan de-gunk, and grease.
I am rather loath to use the G-Clamp trick to press piston back into caliper body... if there's enough ali-fir in the caliper and or the piston is sufficiently corroded to stick, whats that crud going to do when forced back past the seals? Good way to promote a failure to my mind... pistons should self retract.
Loose caliper bolts, pry from forks or carrier with a tyre lever or similar, clean and inspect, and work fro there when you can see how bad it is. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| andyscooter |
 andyscooter World Chat Champion
 Posted: 12:37 - 28 Jan 2018 Post subject: |
Yeah wax your brake discs. Another world-beating idea. That would be the only circumstance I would advocate smashing them with a mallet afterwards. ____________________ a.k.a 'Geri'
| Islander |
 Islander World Chat Champion
The last post was made 8 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
