YBR 125 Stripped Exhaust socket cap bolts : Solved
DanteKrys
PostPosted: 15:31 - 04 Feb 2018    Post subject: YBR 125 Stripped Exhaust socket cap bolts : Solved Reply with quote
Hi, Very Happy
How can I remove a striped exhaust cap bolt. The bolts are small (8mm). I was able move them half turn before I striped the bolts. They should be quite lose but not enough to move them using pilers
.would a nut-splitter work for it?
Ybr125
ADSrox0r
PostPosted: 16:31 - 04 Feb 2018    Post subject: Reply with quote
Either weld a nut onto the end or cut a slit across and use a manual impact driver and twat it out. Saying that though if they're already loose then just cut a slit and use a big flat blade screwdriver.
DanteKrys
PostPosted: 16:49 - 04 Feb 2018    Post subject: Reply with quote
I warmed up the engine before I heated up the bolt with a blow torch. Then covered the bolt with a piece of cloth and used a 9mm socket piece. It worked. Nevertheless, thx for help.
Ybr125
The last post was made 8 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 35.23 Kb
