Xr 125l
Skinny 46
PostPosted: 22:07 - 04 Feb 2018    Post subject: Xr 125l Reply with quote
Hi I'm new to this so hope this is working. My son has blown his 2005 xr 125 pretty badly because the piston melted in the cylinder head completely f#>*ed it. I can't find a replacement and and Honda want stupid money. My question if anyone could help a CG 125 looks identical but the part numbers are different does anyone know if it will fit??? Thanks for any help 👍
PostPosted: 08:36 - 05 Feb 2018    Post subject: Reply with quote
CG is actually a different engine from I remember. One is OHV, the other OHC.
You'll have done more than the piston if it's been run without oil, a new engine is a safer bet.
Fizzer Thou
PostPosted: 11:28 - 05 Feb 2018    Post subject: Reply with quote
Someone on https://www.xrv.org.uk/forums/xr/ may well be able to answer the question and help with technical questions Thumbs Up Wink
Always have a 'Plan B'
bikenut
PostPosted: 12:16 - 05 Feb 2018    Post subject: cg Reply with quote
Honda xr125l 2005, cmsnl show that as a push rod engine very similar to a cg type.
nuts about bikes
Skinny 46
PostPosted: 12:39 - 05 Feb 2018    Post subject: Reply with quote
I think from 2004 the XR used a push rod that is identical to a CG but just wondered if anyone knew any different. Thanks for the replys any more is appreciated.
PostPosted: 14:53 - 05 Feb 2018    Post subject: Reply with quote
Ah, I'm recalling the XLR I think Laughing
It'll definitely be minced either way Thumbs Up
Suntan Sid
PostPosted: 15:32 - 05 Feb 2018    Post subject: Reply with quote
When I rebuilt my XL125, (OHC), the label on the box said it was suitable for an XL and a CG.
If you can use the same piston for a push rod engine on an OHC, I would guess the CG piston would be fine in the XR!
Skinny 46
PostPosted: 16:49 - 05 Feb 2018    Post subject: Reply with quote
Think I'll give it a go, the CG seem to be easier to get hold of. I'll repost how it goes. Hopefully get some pictures.
Skinny 46
PostPosted: 15:36 - 11 Feb 2018    Post subject: Reply with quote
I gave up on the cylinder in the end and bought a whole new engine. From what I've spoke to people about the XR125 L FROM 2004 onwards used a pushrod engine the same as the CG??????
bikenut
PostPosted: 12:22 - 12 Feb 2018    Post subject: cg Reply with quote
don't scrap the old engine, pictures of the head and damage, buggered camshaft bearing ???
the old engine will be a source of some parts probably, see cmsnl for exploded views which can only help you. Strip down for the experience/practise, and see what special tools you may need, flywheel remover, a proper one not a 3 leg bit of crap. The 3 leg bit of crap have their uses but not this particular one.
pics of the head damaged head etc.... :karma:
nuts about bikes
Suntan Sid
PostPosted: 11:46 - 13 Feb 2018    Post subject: Re: cg Reply with quote
You will need these to strip/rebuild the engine:-
This for the flywheel:-
https://e.ridersdiscount.com/generated/477/1/36477-steel-bikemaster-flywheel-puller-10-14-16-18mm_500.jpg
This for the oil pump, you could make this yourself, quite easily:-
https://i.ebayimg.com/thumbs/images/g/hgIAAOxyXWdQ8UD5/s-l225.jpg
bikenut
PostPosted: 11:58 - 13 Feb 2018    Post subject: tools Reply with quote
Both items well worth the relatively small expense.
The peg spanner socket, they are needed in various sizes, an mtx engine needing 2 sizes, but as said they are relatively easy to make particularly if you have a new nut for pattern.
The old ones usually being mangled by the last owner.
It is possible to remove the slotted nuts without mangling them too much.
nuts about bikes
Suntan Sid
PostPosted: 14:06 - 13 Feb 2018    Post subject: Re: tools Reply with quote
Depends if they've been removed or replaced previously.
I bought replacements before I started, the one I eventually got off was absolutely knackered, before I touched it, it was on way too tight, I had to use an impact driver and extreme violence to get it off!
The last post was made 8 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 75.21 Kb
