 black gpz500s Borekit Bruiser
 Posted: 22:26 - 15 Mar 2005 Post subject: |
Most likely the rear suspension linkages have seized. You need to strip and grease these, although you may also need to replace the bushes if they are badly seized up.
The GPZ is a minor pig for doing these as Kawasaki kindly designed the rear suspension so that when the centre stand is in the down position is blocks you from getting out the bolts for the front link. So despite a centre stand you need to use something (I used a pair of axle stands) under the lower frame rails to support the bike with the back end raised.
