GPZ500s Rear Suspension
black gpz500s
PostPosted: 21:19 - 15 Mar 2005    Post subject: GPZ500s Rear Suspension Reply with quote
Hello, new here.
My bike's rear shock has gone very stiff. If you push the back of the bike down it goes with a nasty creaking noise and does not spring back up. Lifting the back of the bike up by the grab rail releases it, again with a horrible noise. When riding over a bump it is very noisy.
Is there any maintenance I can do to ease the shock absorber?
And is it easy to get at?
Thanks.
PostPosted: 22:26 - 15 Mar 2005    Post subject: Reply with quote
Most likely the rear suspension linkages have seized. You need to strip and grease these, although you may also need to replace the bushes if they are badly seized up.
The GPZ is a minor pig for doing these as Kawasaki kindly designed the rear suspension so that when the centre stand is in the down position is blocks you from getting out the bolts for the front link. So despite a centre stand you need to use something (I used a pair of axle stands) under the lower frame rails to support the bike with the back end raised.
black gpz500s
PostPosted: 22:59 - 16 Mar 2005    Post subject: Reply with quote
Thanks Kickstart.
The last post was made 21 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 36.1 Kb
