| ash t |
 ash t World Chat Champion
| Jrod |
 Jrod Page 3 Girl
| ash t |
 Posted: 01:14 - 16 Mar 2005 Post subject: |
Thats adjusted fully  ____________________ When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical |
| Jrod |
 Jrod Page 3 Girl
| Johnny GSX-R |
 Johnny GSX-R World Chat Champion
| ash t |
| Johnny GSX-R |
| ash t |
| Johnny GSX-R |
| ash t |
| Johnny GSX-R |
| Johnny GSX-R |
| ash t |
| Johnny GSX-R |
 Posted: 02:00 - 16 Mar 2005 Post subject: |
OK, i sit corrected then. Maybe it has had a damn good thrashing from you and its died of natural causes. |
| ash t |
 Posted: 02:03 - 16 Mar 2005 Post subject: |
Well i must admit, i did give the bike a good raping on sunday
It was the local charity egg run, and afterwards,we went to an industrial estate and had a few drag races.
Oh dear....is it best to get it booked into a garage, or is it a straightforward job to replace plates? ____________________ When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical |
| Jrod |
 Jrod Page 3 Girl
| ash t |
| mchaggis |
 mchaggis World Chat Champion
| Johnny GSX-R |
| ash t |
 Posted: 02:12 - 16 Mar 2005 Post subject: |
Yeah..Lots of clutch if you want to get anywhere in a hurry on a 2t.
If ZXR400er's suggestion doesent work, il motor on down to the local 2t specialist and see what hes got. Its a good thing i got the day off tomorrow.
Are they easy to fit??
Im quite competent with a spanner...I THINK  ____________________ When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical |
| Johnny GSX-R |
| Kickstart |
 Kickstart The Oracle
 Posted: 14:01 - 16 Mar 2005 Post subject: |
Check the adjustment. There should be a little free play in the lever. There is an adjuster by the lever and another inside the clutch cover. Undo the plug in the middle of the clutch cover and you will find a small screw with a lock nut, and you use this to adjust the clutch.
Not had any problems using synthetic car oil in bikes I have used it it. That it is synthetic is not the problem, it is any friction inhibitors that have been added, so that depends on the make of oil really.
The Aprilia clutches are fairly tough, but it is possible that you have wrecked it. They are quite easy to change, but you will have to drain the oil. Take off the clutch over and the whole clutch basket will just come off in your hand (this is not like other bikes), then I think it is 6 bolts holding that all together and you can take the plates out of the basket. Leave the new plates soaking in oil before you fit them.
When you reassemble it be careful to check that the shift mechanism under the clutch cover is correctly located as otherwise it will be bent when you put the cover back in place.
The last post was made 21 years, 178 days ago. Instead of replying here, would creating a new thread be more useful? |
