Tips to help avoid being pulled out on by other vehicles.
dodsi
Dirty Carny
PostPosted: 02:45 - 16 Mar 2005    Post subject: Tips to help avoid being pulled out on by other vehicles. Reply with quote
Something things I got tought.
To you older more experianced riders I am not aiming this at you, its more aimed at younger less experianced riders such as myself.
When you see a car at a junction that is wanting to pull out on you, these are methods that I use to help them make sure they see me.
Firstly I allways have my dipped beam headlight on. Secondly watch the cars wheels as the wheels begin to move before the car appears to move off this way you know when the vehicle is moving much easier.
Also look at the driver of the other vehicle, Stare at them as often they will look back at you and then they have seen you.
Another good idea (illustrated) is to move about in the road a bit as it draws attention to yourself as they then see a moving object and look more carefully to see a bike. also if they do start to pull out, you are further accross the road so you have more room away from them if they decide its a good idea to pull into it.
Dont be afraid to tap your horn if they begin to move away as this often makes them panic and slam on their brakes and realise that you are there.
Allways adjust your speed accordingly when you see people at junctions so you have time to react.
On motorways/duel carrigeways, near slip roads check them to look for oncoming vehicles and if there is, get into the outside lanes as then they can safely pull onto that lane and not into you.
NEVER flash your lights in annoyance at someone pulling out on you as they will see this to be a sign to carry on doing so.
Stay safe guys.
mchaggis
PostPosted: 02:51 - 16 Mar 2005    Post subject: Reply with quote
Dipped headlights and being close to the centre line are the two I most commonly use, and most important imo. That and being paranoid about them, covering the brakes and envisaging what you could do if they do pull out.
I must not be a troll...
Mmmm, Guinness
Davo
Davo To The Rescue!
PostPosted: 03:29 - 16 Mar 2005    Post subject: Reply with quote
It depends on the circumstances.
If i'm in town i'll use a gear lower than normal, emits a lot more engine noise. (Could use a race can instead there)
Keep the brakes covered etc..
Fire_Eyes
PostPosted: 05:09 - 16 Mar 2005    Post subject: Reply with quote
I use the flasher everynow and then, sometimes if you're going fast and the car can't make out your speed they might want to make that turn... the flasher is just to scare them and telling them that you are going fast.
Kawasaki ZZR 400 | K5 GSX-R 600
Shaun
Likes 'em bent
PostPosted: 08:29 - 16 Mar 2005    Post subject: Reply with quote
Thats a very stupid idea, they could misinterpret that as "go on buddy, I'm letting you out" and you would go into the side of them!
natv4
PostPosted: 09:45 - 16 Mar 2005    Post subject: Reply with quote
Mchaggis: Spot on. Same here.
Fire_Eyes: I'm with Shaun here. Regardless of highway code, it is universally accepted (in the UK) that flashing headlights are a, go ahead. This would not be sensible.
In Italy, however, it is accepted that this means "I'm coming through!". So you would be fine there. Smile
Travelling around the world...a bit at a time. Where am I now? / Visit my BLOG
Bike: Blue Honda VFR800fi (*NEW*) Mileage: 22k Countries visited: GB/F/D/CZ/PL/E/I/B/A/HR/H/Rus/E/MA
West Europe...2004, East Europe...2005, Russia/France...2006, Morocco...2007
PostPosted: 09:51 - 16 Mar 2005    Post subject: Reply with quote
Note that full (dipped or not) beam headlights can cause problems with distance perception. I believe TC has mentioned that it has been used against people if they had the choice and used them in the day time. Get a bike to ride towards you with it's head light on and not and it should be fairly apparant... especially if it's a tallish bike and you're sitting lowish as you would in a car.
Also makes it harder for them to see your face and make eye contact etc.
I always use sidelights in the day time, these days.
Bendy
Mrs Sensible
PostPosted: 10:02 - 16 Mar 2005    Post subject: Reply with quote
Suss your escape plan.
You should get to the point where this is entirely subconscious, but will mean you've assessed what is around about the car and have an idea of the path of least destruction - slamming the brakes on in a straight line isn't always it, maybe you could dive up the road they're coming out of. Also be aware of what's coming towards you and what's behind you - it may not be clear enough to change lane in the well-mannered, lots of space sense, but there might be room for a swerve and squeezing in next to a little car. If it's an 18 wheeler in your 4 o'clock, you need to know.
Claud 14.7 to 1
PostPosted: 11:42 - 16 Mar 2005    Post subject: Reply with quote
Agree. Saved my hide. Was riding back in Winter, really appalling weather, very heavy rain, very dark, and rush hour.... Rolling Eyes Guy pulls into my line (was pulling into a side road). Had I pulled on the brakes, they either would have locked or not been able to stop me in time, as it was so wet. So anyway, I turned instead and aimed the bike towards the side road, away from the car and then put on brakes. I'm pretty sure I would have been splatted otherwise, as he ended up right in my riding line. Me ending up a few meters behind him.
Remember you go where you look. I got myself into a habit of not "concentrating" too much on cars, although being well aware of what they are doing.
That and on the approach to a junction just bring your speed down. Gives them a lot more time to notice you, and covering the brakes works.
And just generally anticipate car's movements. "What might they do?"
JonB
Afraid of Mileage
PostPosted: 11:48 - 16 Mar 2005    Post subject: Reply with quote
Whilst overtaking it is actually a GOOD idea to flash your lights as that is what they are there for. To warn other motorists of your presence, if you get a car driver dumb enough to pull out on you than that is just unfortunate.
veeeffarr
PostPosted: 12:07 - 16 Mar 2005    Post subject: Reply with quote
I'm not expert, I don't even ride, but if you have dipped lights on and you go over a bump in the road as you pull up to a junction your lights bouncing could appear like they are flashing another driver through as well!
Claud 14.7 to 1
PostPosted: 12:11 - 16 Mar 2005    Post subject: Reply with quote
I would have though indicators would be enough.
No, well yes, but there are plenty of things you can do to account for even other road user's mistakes. Actually I recon if you apply yourself 100% in every situation you can never have an off. But in the real world this doesn't happen.
binge
Emo Kiddy
PostPosted: 12:16 - 16 Mar 2005    Post subject: Reply with quote
The whole speedbump thing, ^. If the other driver had any common sense at all, they would see the lights flash, look, see the speedbump and then realise that was what the flashing was...
I thaught I was going to get splatered yesterday. I was on my way to work and a car was driving towards me, On the wrong side of the road. He wasnt overtaking, He was just driving down the wrong side of the road... Laughing
What a Wombat!
I had to plhysically get on the pathment to let him by. He was an old man too...
<|Ben|>
goony
PostPosted: 12:36 - 16 Mar 2005    Post subject: Reply with quote
just be paranoid and expect them to pull out and so be prepared to stop or evade
MattShill
PostPosted: 12:52 - 16 Mar 2005    Post subject: Reply with quote
There was a thing about this in Bike last month, it said that the best tactic is to move to one side as shown here, or move slightly left and right. This makes your outline move against what's happening in the background and so the driver notices you. Apparently it's not a good idea to drive in a straight line because all that happens is your outline gets slightly bigger and the driver's brain doesn't register you as a moving object. That is until you're really close and by then it's too late.
PostPosted: 14:23 - 16 Mar 2005    Post subject: Reply with quote
Safest thing is to just assume they are going to pull out and ride accordingly. Even making eye contact with the driver doesn't stop them in many cases although it is a start.
Looking at the wheels of the car for movement can let you spot a "creeper" who is ready to jump out in front of you because he thinks he can make it into the gap, other people who have actually stopped properly at the junction are less likely to try this.
PostPosted: 14:27 - 16 Mar 2005    Post subject: Reply with quote
I disagree.
Maybe it is better, I've never tried it.
You may well panic the driver, them thinking they are in the way somehow. Or they maybe intending to pull out and they think you are flashing them out.
m99dws
PostPosted: 14:37 - 16 Mar 2005    Post subject: Reply with quote
So you flash, they look in the mirror to see why and drive into someone else? Good plan Batman
instigator
PostPosted: 14:38 - 16 Mar 2005    Post subject: Reply with quote
You're forgetting, fire_eyes lives in a different country where it may be the "norm" to flash lights to alert someone of your presence.
Here, it is very much so for "on you go, I'll let you in" or so it seems.
Just don't assume anything is all I say.
m99dws
PostPosted: 14:39 - 16 Mar 2005    Post subject: Re: Tips to help avoid being pulled out on by other vehicles Reply with quote
dodsi wrote:
Also look at the driver of the other vehicle, Stare at them as often they will look back at you and then they have seen you. .
I'm one of the least experienced riders on here, but I would think that even if they are looking at you, it doesn't mean they have seen you.
instigator
PostPosted: 14:43 - 16 Mar 2005    Post subject: Re: Tips to help avoid being pulled out on by other vehicles Reply with quote
Thats why I say assume nothing. Assuming someone has seen you is a very bad thing to do... Confused
TheShaggyDA
Repost Police
PostPosted: 14:47 - 16 Mar 2005    Post subject: Reply with quote
Keep an eye on their brake lights - if they go off, they're coming out.
Zoffo
PostPosted: 15:05 - 16 Mar 2005    Post subject: Reply with quote
When passing a left hand junction you should be near the white line anyway. ive yourself as much time and space as possible.
personally I don't ride with the headlight on unless it's dark. That way I can flash it on and draw some attension if I think someones not seen me.
woo
PostPosted: 15:17 - 16 Mar 2005    Post subject: Reply with quote
Drive an 18 wheeler truck and i guarantee you that the driver of the other vehicle will never ever ever ever pull out in front of you again!
Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil
Method
PostPosted: 16:05 - 16 Mar 2005    Post subject: Reply with quote
i just assume that all car drivers are idiots and should be treated accordingly... obviously when im off the bike im a bit more polite Razz
but like bendy said you should be looking for your escape subconciously... ive been doing that now since ive been on the 500, and certainly has saved my purty little rear end many a time Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
The last post was made 21 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 130.95 Kb
