Waterproof Phone Mount
Jayy
Mr. Ponzi
PostPosted: 02:11 - 26 Mar 2018    Post subject: Waterproof Phone Mount Reply with quote
I see people who have their phone mounted on the their bike bars or yoke and wonder what's the best setup I need?
Is there any advantage to the ones that clip to the bar over ones that screw in to the yoke?
Phone is an S7 Edge and bike is an 2016 RSV4 RF.
I have been looking on ebay but they range from £5 to £50.
Ben90
PostPosted: 07:20 - 26 Mar 2018    Post subject: Reply with quote
I have an S7 which like the Edge is IP68 water resistant. I use one of those cheap £5 zip up ones with a bar mount that the case clips on to. Been out in a downpour with it and the phone was fine.
Didn't fully trust the clip though so added a backup choker around the mount using a bit of shoelace. Thumbs Up
Yamaha FZ6 S2
ThatDippyTwat
PostPosted: 07:22 - 26 Mar 2018    Post subject: Reply with quote
Cheap waterproof case that fits your phone, the clear bag type ones, stuck in an X-grip (RAM clone), about a tenner from China for the holder.
EDIT:- Mine mounts under the mirror, but some of the clones have a bar mount as well.
matlow
PostPosted: 10:15 - 26 Mar 2018    Post subject: Reply with quote
I've used these for a few years https://www.twistyride.com/ good quality but questionable if its required now that most phones are waterproof.
Hornet 600, CBR600F, 929 blade, 07 R1, R1200GS, 09 Blade, 750 SRAD, ZZR1200, 954 Blade, KTM 990 Adventure, Ducati 749s
formula400
PostPosted: 22:12 - 26 Mar 2018    Post subject: Reply with quote
quad lock with waterproof poncho
Tierbirdy
PostPosted: 04:10 - 27 Mar 2018    Post subject: Reply with quote
Givi do a great range of universal and phone specific cases. A bit pricey though at around £30-40 depending on model and where you shop.
I always found with the cheap Chinese shite that there was way too much slack on where the screen sits, so the plastic cover ripples slightly and glares in the sun so you cant see the screen. Not to mention would you trust your £600+ phone to a £5 bit of plastic made by child sweatshop labour? The Givi mounts are rock solid, don't vibrate or lose their position, and have a little sun shade built in which I find really helps using satnav in summer.
ThatDippyTwat
PostPosted: 05:34 - 27 Mar 2018    Post subject: Reply with quote
I do trust my £££ phone to one, but you can always test it like I did. Put a bit of bogroll inside, and jetwash/hose/submerge in bathtub. If bogroll isn't damp, it works. Mine was hosed with decent mains pressure after being submerged. No issues, but that may not be the case for all cases, inexpensive or wallet-raping. I've seen Pelicases fail underground and kill a £3K camera and the same in L series lenses. They paid for replacements to be fair, but still, anything can fail.
MCN
PostPosted: 09:49 - 27 Mar 2018    Post subject: Reply with quote
Waterproof Pockets on my jacket. (Fonepal)
Shocked
Tierbirdy
PostPosted: 13:45 - 27 Mar 2018    Post subject: Reply with quote
I'm not so much concerned about the waterproof (though that's nice), more the shoddy materials/construction, the mount failing at motorway speeds and bye-bye phone under the wheels of a lorry etc. Fair enough you can guard against that with a retention strap, but then there's just the poor quality causing the mount to wobble at any kind of speed and struggle to see the phone screen. Especially those ones with the stupid long flexible mounts etc.
Cadbury
PostPosted: 14:02 - 27 Mar 2018    Post subject: Reply with quote
I have one of these:
https://i.ebayimg.com/images/g/CUcAAOSws6ZZ8Kir/s-l300.png
Cost £15 from amazon. It's surprisingly well made, nothing wobbles, and you can cinch everything down nice and tight. The claw means i put it on/off in seconds without tools.
My lg g6 is waterproof anyway, but i did do the waterproof test mentioned above. Nothing got through. For the money Thumbs Up
NC700x.
ThatDippyTwat
PostPosted: 15:11 - 27 Mar 2018    Post subject: Reply with quote
This is the system in question (standard disclaimer - not affiliated etc, first example I found, can probably be found cheaper). It's not long, it's not flexible unless you undo the knob. That's not something you'll be doing accidently.
https://www.ebay.co.uk/itm/Motorcycle-Phone-Mount-LESHP-Universal-X-Grip-Clamp-Stand-Holder-for-Bike-5/282848342328?epid=847384140&hash=item41db133138:g:85kAAOSwj1ZahFhO
Davemc37
PostPosted: 16:34 - 27 Mar 2018    Post subject: Cadbury do you have a link to the item not just the picture Reply with quote
Do you have a link to the full item not just a picture of it?
born again biker with a mere 23 year gap between bikes.
Cadbury
PostPosted: 07:03 - 28 Mar 2018    Post subject: Re: Cadbury do you have a link to the item not just the pict Reply with quote
Sure. T'was this one: https://www.amazon.co.uk/gp/aw/d/B0742B4WFZ/
Be warned, its gone up by £1 since I got mine! Shocked
NC700x.
rpsmith79
PostPosted: 07:14 - 28 Mar 2018    Post subject: Re: Cadbury do you have a link to the item not just the pict Reply with quote
I have looked at these before, but i couldn't figure out if there was any way to get a phone charger cable plugged in or not, can't quite tell from the photos
Cadbury
PostPosted: 09:42 - 28 Mar 2018    Post subject: Re: Cadbury do you have a link to the item not just the pict Reply with quote
There's no specific slots or anything, no. The zip basically goes all the way around, but it has 2 zip pulls, so you can plug in the cable and then close each end of the zip up against it, which is what I do. It does mean that there the slightest of gaps where the cable goes through, but as its usually tucked up behind the winsdcreen it doesn't get wet.
NC700x.
fatjames
PostPosted: 09:50 - 28 Mar 2018    Post subject: Reply with quote
I used to use one of the ultimate addons cases with a ram ball mount. It was good, but not cheap. I quite liked the stem mount they do beccuase I could still use my bar muffs.
Link is for iphone 6-7
https://www.amazon.co.uk/Ultimateaddons-Tough-Waterproof-Mount-iPhone/dp/B01N1T4UMF/ref=sr_1_7?ie=UTF8&qid=1522230425&sr=8-7&keywords=ultimate+addons
rpsmith79
PostPosted: 11:58 - 28 Mar 2018    Post subject: Re: Cadbury do you have a link to the item not just the pict Reply with quote
Nice one, cheers
The last post was made 8 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 95.89 Kb
