Batteries
t121anf
PostPosted: 09:49 - 27 Mar 2018    Post subject: Batteries Reply with quote
So it looks like the winter has killed my battery, despite being on a charger it seems one of the toggle switches was neither up nor down and must have been doing jack.
Is it worth paying the cost of a Yuasa or should I grab an Exide whilst EuroCarParts have a discount code, or go for a cheapo no name?
Pjay
PostPosted: 10:15 - 27 Mar 2018    Post subject: Re: Batteries Reply with quote
My Yuasa purchased in 2017 died this winter. I wouldn't bother paying more for one.
struan80 - I'll go first - satisfied tick 1
MCN
PostPosted: 10:45 - 27 Mar 2018    Post subject: Reply with quote
Yuasa 2013
Died 2018
Was flagging end of 2017 though.
It was on the Ctek life-support.
I pulled the plug on it Jan 2018. Sad
But it's still kicking around to run my air pump for tyres. Smile
The auld Bastirt.
Padgetts-Online (Ebay.uk)
t121anf
PostPosted: 11:49 - 27 Mar 2018    Post subject: Reply with quote
I'm sure like with most things you are paying for the name and there is little difference in the actual product.
MCN
PostPosted: 18:56 - 27 Mar 2018    Post subject: Reply with quote
You maybe are not sure but just think so.
Pigeon
PostPosted: 19:14 - 27 Mar 2018    Post subject: Reply with quote
Yuasa 2013 - Not died yet, but have bought a Motobatt to replace it as its been through 5 winters, so I've had a good innings.
Kept on an Optimate3+ for 2-3 weeks, then off for a couple of days, repeat.
If the Motobatt doesn't give trouble free 4 years, then I'll revert to Yuasa.
Qyburn
PostPosted: 21:12 - 27 Mar 2018    Post subject: Reply with quote
My Motobatt died after 18 months, and I hated it's stupid connections. Wouldn't buy another.
Lord Qyburn
Courier265
PostPosted: 21:55 - 27 Mar 2018    Post subject: Reply with quote
My suzuki still has the original battery from 2013..
My cb250's battery is 2 years old
MY CBF500 is due to be replaced in May, it gets replaced every 12 months.
Yuasa batteries every time, never use anything else.
Stallion. wrote:
My Fazer is still on the original which is 17 years old and still going strong.
BULLSHIT. Shocked
ThatDippyTwat
PostPosted: 07:09 - 28 Mar 2018    Post subject: Reply with quote
Stallion. wrote:
Waste of money.
More bullshit than a beef farm. Let me educate you Bodyform...
A single Pb cell, of which there are 6 to go south in your battery as they are around a nominal 2v each, will lose capacity over time after 5, never mind 17, years of charge/Discharge cycles. Multiply that by 6 and the current generated after 5 (17!) years is significantly down on new. Active material depletion, or plate/grid breakdown, is why they last about 5 years when starting vehicles, not more than triple that you fucking tool. The reason Optimates help so much is they can trickle charge them, or provide a "saturated" charge lasting, from memory, about 14-18 hours. It's the best way to charge a battery. What you get from a vehicle with a Alternator or Stator/Reg-rec is pretty much what equates to a violent stuffing. It charges at a fairly high current to ensure that it's charged the next time you start it up, even after a short journey. This increases the level of breakdown on the plates and grids, and is why it dies.
Unless your fazer shipped with a fucking long extension cord, or a stipulation to ride for 14-18 hours continuously, someone has replaced the battery in your shitty fazer, but likely with OEM, hence confusing your small amount of little grey cells.
If you google for something like "Pb charge/discharge life cycle" you can science yourself on many whitepapers that are out there.
techathy
PostPosted: 10:58 - 28 Mar 2018    Post subject: Reply with quote
That all said I did have a car that had a 9 year old battery which didn't seem to have any issues with voltage & current supply. However, the battery was kept in the boot of the car & also I believe was he correct size for cars with the cold weather pre-heat system, which mine didn't have.
Bikes: '17 Zero FX ZF6.5, '16 BMW R1200 RS, '12 Triumph Daytona 675
ThatDippyTwat
PostPosted: 11:09 - 28 Mar 2018    Post subject: Reply with quote
It may have been over-specified, then you lose capacity as normal, but still retain enough to start/run the car without issues. There's generally no space on a bike to put a much bigger battery in.
However - All Pb batteries lose capacity. You tend to not get sulfation as much these day's, as charging systems are far better, but the consequence of higher charge rates is depletion of materials. It may also, but probably not, have been a Flooded lead acid battery rather than a Sealed, as they deal with overcharge better. Stationary batteries (lead, but in power supplies etc) are another beast altogether.
If Bodyform has made the original fazer battery last 17 years, then a number of chemists and companies will give him lots of money to reveal his secrets, and he can finally make his imaginary R6 a reality.
PostPosted: 15:28 - 28 Mar 2018    Post subject: Reply with quote
^^^^ True ^^^^
Personally I'd prefer batteries that you could top up rather than sealed ones. You have a half chance of saving them if they go completely flat.
Anyway, anyone used these for bike batteries? I use them for boat batteries and they are just about the best/cheapest on the net.
https://www.tayna.co.uk/motorcycle-batteries/
Triumph Trophy Launch Edition
ThatDippyTwat
PostPosted: 16:00 - 28 Mar 2018    Post subject: Reply with quote
Yup, decent prices and decent selection. Unless it's got a lot of gizmo's, constant drain alarms etc on it, I find Varta to be decent bang for buck. You put the Acid in yourself and bung it up, so you should, in theory, be able to top it up with sulphuric acid.
grr666
PostPosted: 16:20 - 28 Mar 2018    Post subject: Reply with quote
I don't think Tayna are that competitive on bike batteries, but I have used them numerous times for cars and vans
and their service has been superb, plus they are amazing at packaging up batteries to survive transportation to customer.
Would recommend, but would probably still shop around if it was a bike battery I was after.
ThatDippyTwat
PostPosted: 16:40 - 28 Mar 2018    Post subject: Reply with quote
Having had a couple of banged up and leaking batteries in the past from other companies, I have to say they do very well, and I'll pay a few quid more for that, rather than deal with the absolute bollockache that is uncontained sulphuric acid. I've had 3 bikes now that had aging/weak batteries when I got them, and all 3 have been from there, all 3 intact, despite in 1 case, the courier playing football with it.
Copycat73
PostPosted: 17:21 - 28 Mar 2018    Post subject: Reply with quote
i`ve bought from hunters on the hill ( Westgate road )for years .. providin you keep it on a conditioner they last 5 years .. lasts half that you get from an original battery but at 33% of the price ....
your choice... Thumbs Up
caveat emptor
The last post was made 8 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 16 - Page Size: 100.88 Kb
