Er6F Won't start. FIXED
Electrabint
PostPosted: 10:29 - 03 Jul 2018    Post subject: Er6F Won't start. FIXED Reply with quote
Hi, new member here, I'm currently having a starting issue with my er6, 2007. Turn the key and the dash lights up, but the neutral light is dim or non existant even though it's in neutral. Press start button, nothing. However if I kick the side stand up and pull in the clutch I can here the fuel pump and clicking noise when I press the starter. It was running fine just 2 hours previously. Battery is brand spanking new. Anyone got any theories they would be most welcome.
PostPosted: 10:44 - 03 Jul 2018    Post subject: Re: Er6F Won't start Reply with quote
Why did you replace it?
I'll assume because the previous one died, but why did it die? Did you check the voltage across it while the bike was running, or look for a drain with the ignition off?
On that, do you have an alarm fitted?
Electrabint
PostPosted: 10:54 - 03 Jul 2018    Post subject: Reply with quote
Old battery was kaput because it was old and would not hold charge. Bike has had a recent engine rebuild and was running sweet as a nut, no alarm fitted so no drain from there.
Hawkeye1250FA
PostPosted: 11:17 - 03 Jul 2018    Post subject: Reply with quote
New battery is either not the correct battery for the bike, knackered before you installed it, or installed incorrectly.
The above assumes nothing else has been touched since it was running sweet as a nut.
Take it off / test it / test bike with another definitely working battery / refit / ride.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
fatjames
PostPosted: 11:20 - 03 Jul 2018    Post subject: Reply with quote
Sounds like a battery or charging system problem.
You'll need to get your multi meter out and find some readings.
Will it jump / bump start?
If it was a honda, I'd be guessing rec/reg.
Electrabint
PostPosted: 11:29 - 03 Jul 2018    Post subject: Reply with quote
Battery has been on bike a couple of weeks and had no problems in that time. The battery is the correct one for the bike and it has been installed correctly. Rode bike to work last night, everything fine, came back to it a couple of hours later she would not start. Got fuel pump prime, dash lights up and all lights, but she won't even attempt to turn over. I will get the meter out later and check the battery.
Hawkeye1250FA
PostPosted: 11:30 - 03 Jul 2018    Post subject: Reply with quote
Then I agree with charging problem 👍
Electrabint
PostPosted: 11:39 - 03 Jul 2018    Post subject: Reply with quote
I don't think I could bump start a 650 parallel twin, lol. When hubby gets back, we will get the meter on it. I was thinking it might be a loose connection somewhere, couldn't do too much last night as too dark.
Electrabint
PostPosted: 11:43 - 03 Jul 2018    Post subject: Reply with quote
I'll suggest charging problem to hubby, he's a vehicle tech and an electrician. We couldn't really check much last night as it was getting late and didn't want to wake the neighbours.
grr666
PostPosted: 12:25 - 03 Jul 2018    Post subject: Reply with quote
Shocked
Have you two had another row then? Or just work opposite shifts? Trying to fathom why you're looking further
than the end of your nose for an answer to this? You appear to already have everything you need to get to the
bottom of this. Or is he a crappy fitter/electrician?
Electrabint
PostPosted: 15:53 - 03 Jul 2018    Post subject: Reply with quote
grr666 wrote:
Shocked
Oh look a rude LITTLE man. He hasn't had a chance to look at it properly yet as he works all day. Shame you could not be as helpful as the other posters above. If you can't say anything nice or constuctive, don't say anything at all!
PostPosted: 16:31 - 03 Jul 2018    Post subject: Reply with quote
Do you like cats?
Electrabint
PostPosted: 16:43 - 03 Jul 2018    Post subject: Reply with quote
Have no opinion on cat's one way or another. Prefer reptiles.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:07 - 03 Jul 2018    Post subject: Reply with quote
Actually I agree with him. It' should be the work of minutes for a fitter /electrician to look at this problem.
We all work all day but I'd still have that diagnosed in virtually ten minutes with my multimeter and I'm an accountant....
Triumph Sprint ST 1050
Kawasaki Jimbo
PostPosted: 19:38 - 03 Jul 2018    Post subject: Re: Er6F Won't start Reply with quote
However if I kick the side stand up and pull in the clutch I can hear the fuel pump and clicking noise when I press the starter.
Interesting. Why would releasing the other other two safety switches (side stand and clutch) change the story? Is there a clue there?
Have you checked the fuses?
'93 Yamaha XJR400 grey import (p-ex’d), '99 Kawasaki ZX6R (nicked), another '99 ZX6R (still got it) and '03 Yamaha YZF-R1 (still got that too.)
Nobby the Bastard
Harley Gaydar
PostPosted: 20:04 - 03 Jul 2018    Post subject: Re: Er6F Won't start Reply with quote
If the clutch./stand switches are triggering the pump but the solenoid (technical term, ask hubby what it means) is clicking, you're back to a flat battery, which could be caused by the charging system being fucked, or knackered starter.
Hubby can explain how you tell which of those is the problem.
wr6133
PostPosted: 20:20 - 03 Jul 2018    Post subject: Reply with quote
Electrabint wrote:
he works all day.
Crappy ones do have to work longer hours
*runs off laughing having pulled the pin from a grenade*
Nobby the Bastard
Harley Gaydar
PostPosted: 21:03 - 03 Jul 2018    Post subject: Reply with quote
You do know that when hubby says 'I'm working late' during the world Cup he's actually in the pub?
Personally, I'd have fixed it and then gone to the pub, but we can't all be perfect.
Electrabint
PostPosted: 21:19 - 03 Jul 2018    Post subject: Reply with quote
Well bike is running and starting well again, none of the above was the cause.
Kawasaki Jimbo
PostPosted: 21:30 - 03 Jul 2018    Post subject: Reply with quote
Kill switch.
Electrabint
PostPosted: 21:46 - 03 Jul 2018    Post subject: Reply with quote
Nope, corrosion to the starter switch and the main bolting point for the engine earth.
PostPosted: 22:27 - 03 Jul 2018    Post subject: Reply with quote
To be fair, a new battery does quite often indicates that a bad charging circuit mullered the old one.
Hubby has checked that you're getting 14.6V or thereabouts across the battery terminals with the engine running, right?
Electrabint
PostPosted: 22:45 - 03 Jul 2018    Post subject: Reply with quote
Yep all voltages are good when running😊
He did agree it sounded like a charging problem.
PostPosted: 05:40 - 04 Jul 2018    Post subject: Reply with quote
Does he like cats?
Electrabint
PostPosted: 06:51 - 04 Jul 2018    Post subject: Reply with quote
Rogerborg wrote:
Does he like cats?
Do you have an obsession with cats or something? Shocked
The last post was made 8 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 125.86 Kb
