Tank slapper
mudcow007
PostPosted: 07:35 - 19 Jul 2018    Post subject: Tank slapper Reply with quote
This morning I experienced my first tank slapper.
I had just left the house took my hands of the bars for a second an the front wheel shook like Micheal J Fox.
it was still happening all the way to work to.
Could it be a balance weight has flew off or something?
mudcow007
PostPosted: 08:51 - 19 Jul 2018    Post subject: Reply with quote
Ah good point, will have a look at lunch time.
Weirdly the bike was absolutley fine when i last used it - last week?
ta
UnknownStuntm...
PostPosted: 08:58 - 19 Jul 2018    Post subject: Reply with quote
Check your tyre pressures.
PostPosted: 12:23 - 19 Jul 2018    Post subject: Reply with quote
Got a top box?
mudcow007
PostPosted: 12:52 - 19 Jul 2018    Post subject: Reply with quote
Checked front wheel (with bike on center stand), doesnt seem to be any play in wheel or binding brakes at all
Hold front brake an try to rock the bike an cant feel any clunks etc.
Checked pressure, it was at 47psi!? so dropped that back down to 42psi but problem still there
Paddy - yeah I have a top box on, with a small chain etc in - reckon it could be that?
doggone
PostPosted: 14:34 - 19 Jul 2018    Post subject: Reply with quote
Unlikely, if you normally have it in.
Lift the front end and see if the bars move smoothly side to side - head bearings. Usually the first symptom of wear is the feeling of a notch straight ahead.
kramdra
PostPosted: 20:38 - 19 Jul 2018    Post subject: Reply with quote
What speed, acceleration?
I was getting instability above 110. Forks needed a service - cured it, but can not explain why.
MCN
PostPosted: 21:04 - 19 Jul 2018    Post subject: Reply with quote
Tank Slappers dont just happen unless certain conditions present.
https://youtu.be/fvsDIq3WwVA
BusterGonads
PostPosted: 21:54 - 19 Jul 2018    Post subject: Reply with quote
That's a bloody brilliant video. Thanks for posting that. I had weave in the 1970s on an A10. Nearly shat myself. I had no idea what was going on until now.
The explanation starts at about 4 minutes 20 so if people are impatient they can start there.
2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250
UnknownStuntm...
PostPosted: 07:05 - 20 Jul 2018    Post subject: Reply with quote
rpsmith79
PostPosted: 07:14 - 20 Jul 2018    Post subject: Reply with quote
Which tyre, and what about the other one?
mudcow007
PostPosted: 07:24 - 20 Jul 2018    Post subject: Reply with quote
First time it happened I was going maybe 20 - 30mph
Both pressures have been checked an are at 42psi
Messed about with the front end last night an steering feels smooth with no resistance at any point from left - right etc.
brakes arnt dragging
One thing I did notice is that on the front I have a weight on one side of the rim, but not the other. On the rear wheel, weights are the same on both sides?
Jewlio Rides Again LLB
PostPosted: 07:35 - 20 Jul 2018    Post subject: Reply with quote
Does it look like the weight has been on the other side too? If not, it won't matter.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
PostPosted: 07:57 - 20 Jul 2018    Post subject: Reply with quote
The bike shaking its head is usually a problem with the back end somewhere. As has been said, usually a soft tyre.
A real tank slapper goes lock to lock even when you're holding onto it, often severely enough to rip the bars out of your hands. Sounds like you have a bit of a head shake which if it isn't the tyre pressure is probably wheel bearings.
fatjames
PostPosted: 10:26 - 20 Jul 2018    Post subject: Reply with quote
Does the top box unclip? If so, have as ride without it on, just to eliminate.
When mine's full, the front end is lighter.
As stinkwheel said though, if you're missing a weight from the wheel, there will be a little clean patch where it used to live.
Neither of the wheels are loose, are they? And nothing stuck in the tyre like a stone / nail?
Islander
PostPosted: 11:19 - 20 Jul 2018    Post subject: Reply with quote
Are you sure both tyres should be at 42psi?
If a wheel balance weight has fallen off, then there's usually a sticky patch left behind or a cleaner area where it once was.
PostPosted: 12:44 - 20 Jul 2018    Post subject: Reply with quote
42psi on the front is madness. I'd run then at 36/42 usually.
Still reckon its the top box being a twunt issue though.
MCN
PostPosted: 15:25 - 20 Jul 2018    Post subject: Reply with quote
I run 110 front 120 rear.
I'm Mental.
Very Happy
Nobby the Bastard
Harley Gaydar
PostPosted: 16:40 - 20 Jul 2018    Post subject: Reply with quote
Point of order...
It's not a tank slapper unless it rips the bars out of your hands. This is just a mild undulation of the steering.
I should know,. I got thrown 12 feet into the air by one.
Triumph Sprint ST 1050
mudcow007
PostPosted: 19:36 - 20 Jul 2018    Post subject: Reply with quote
42 F & R are what the book says...so Thinking
I'm gonna try the bike tomorrow without the box on, an will have a better look at the maybe missing weight(s)
The bike is 03 Blackbird
fanks all
PostPosted: 23:03 - 20 Jul 2018    Post subject: Reply with quote
BB loaded I'd do 40/42, but solo non fat me, 36/42
PostPosted: 23:07 - 20 Jul 2018    Post subject: Reply with quote
What do the tyres say on them about pressures?
MCN
PostPosted: 03:47 - 21 Jul 2018    Post subject: Reply with quote
You've taken it too far this time Ste.
I mean, talking tyres?
Whatever next? Shocked
mudcow007
PostPosted: 08:39 - 24 Jul 2018    Post subject: Reply with quote
Fixed - It was the top box
I have been using it since January an never noticed any wobble before?
thank all
The last post was made 8 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 124.84 Kb
