What type of wire does the cdi use??
nitbag_10
PostPosted: 20:56 - 28 Jul 2018    Post subject: What type of wire does the cdi use?? Reply with quote
So i bought a pulse scout 50cc and it works fine however i derestricted it by cutting the pink wire and got up to 40mph then the belt snapped. so i replaced the belt and it’s kinda working fine but i want to rerestrict it because it just feels a we bit dodgy. I was trying to put the wires back together and i realised i don’t have enough wire.
Now i don’t know much about electronics and stuff but i’m guessing i can just use normal copper wire to join them together.
Is this correct or do i have to buy some special stuff.
Speedy23
PostPosted: 21:37 - 28 Jul 2018    Post subject: Re: What type of wire does the cdi use?? Reply with quote
So you're asking a question like this but have no qualms about snipping wires? Shocked Hmm.......have a think about it.
andy_uk
PostPosted: 22:55 - 28 Jul 2018    Post subject: Re: What type of wire does the cdi use?? Reply with quote
Just any wire of a similar thickness will do.
Aprilia Classic 125, GS500E, ER5-A1, ER5-C4, ER6 & an XJ6 project frame...
PostPosted: 23:23 - 28 Jul 2018    Post subject: Reply with quote
Affirmative @ copper wire. Thumbs Up
PostPosted: 00:31 - 29 Jul 2018    Post subject: Reply with quote
Most modern motorcycles will use thinwall cable which has a multistrand copper core.
If it's for electronics, it needn't be particularly thick.
I would suggest using crimps to join it. These should be applied with the correct crimping tool.
A solder splice with shrinktube over the top is also appropriate.
Twisting them together then wrapping them in PVC tape or screwing them into a chocblock type connector is not ok on vehicle wiring. It WILL fail.
The last post was made 8 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 44.39 Kb
