Changing Gear
fatjames
PostPosted: 08:51 - 01 Aug 2018    Post subject: Changing Gear Reply with quote
I've been wearing a different set of boots, they're a little bit more chunky than my old ones.
But I keep missing my gears when using the clutch. Especially going from 1 to 2, I keep landing on N.
It hasn't happened when clutchless shifting.
I wondered.. can I adjust the gear lever so it requires less travel? Or would I need after market rear sets to do that?
Bike is a 2004 CBR 600 F
Islander
PostPosted: 09:40 - 01 Aug 2018    Post subject: Reply with quote
As above, adjust the linkage to give you the best lever position. However, give it a quick soak with penetrating oil before you try to adjust it - the link rod threads have a nasty habit of seizing in the ends.
recman
PostPosted: 11:14 - 01 Aug 2018    Post subject: Reply with quote
I went from a pair of boots that felt like slippers to new RST slightly sporty type.
Had the same problems with changing gears.
You can try changing things to suit but my issue just went away over a short period of time.
WD Forte
PostPosted: 12:15 - 01 Aug 2018    Post subject: Reply with quote
I recall going from 'slippers' to chunkier boots too with similar results.
Like Recman I adjusted to it and it was cheaper and easier than making any modifications.
What if you did do the mods and changed boots again?
bikers smell of wee
PostPosted: 15:57 - 01 Aug 2018    Post subject: Reply with quote
Then you'd take 2 minutes to adjust them again...
Too many 'what if' and 'why would you' from you recently sir... you must be getting on a bit Wink
This is why I use trainers, specifically skate shoes. So much more feeling in your feet Laughing
fatjames
PostPosted: 08:59 - 02 Aug 2018    Post subject: Reply with quote
Thank you.
I'll get my spanners out Smile
And as Paddy says.. I can always change them back if I change boots again. Although.. my last boots lasted longer than 4 bikes. I would keep wearing them if the peg on left didn't keep popping in from underneath to say hello to my socks Laughing
The last post was made 8 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 51.33 Kb
