YBR 125 HID kit
Cavallo
PostPosted: 19:15 - 21 Aug 2018    Post subject: YBR 125 HID kit Reply with quote
Hi Guys,
I was planing to install an HID headlight kit for my 2016 YBR125ed (stock bulb 35w/35w H4). If I install a 55w kit, would it be too much for the bike? the kit draw power directly from the battery but since the factory bulb is 35w, i worry that the 55w will melt the headlamp or some factory wiring. any suggestions?
Thanks all.
ThatDippyTwat
PostPosted: 20:17 - 21 Aug 2018    Post subject: Reply with quote
Don't. It dazzles oncoming traffic.
Chuck in Osram nightbreakers or similar. They worked just fine in my YBR on Welsh country roads at 5:30AM in the winter on the way to work.
Cavallo
PostPosted: 20:19 - 21 Aug 2018    Post subject: Reply with quote
Aren’t those 55w?
ThatDippyTwat
PostPosted: 20:22 - 21 Aug 2018    Post subject: Reply with quote
Cavallo wrote:
Aren’t those 55w?
Yes. The wires were ok with the current. I never noticed any heating or crispiness on the wires.
HID's are designed for a totally different lens than the YBR has. That's why it dazzles, not the wattage they consume. A 55W LED would blind everything.
Cavallo
PostPosted: 20:26 - 21 Aug 2018    Post subject: Reply with quote
I m not going to use an led, but i m going to get a xenon kit. Would this dazzel other drivers as well?
Cavallo wrote:
Aren’t those 55w?
redeem ouzzer
PostPosted: 20:50 - 21 Aug 2018    Post subject: Reply with quote
Installing HIDs in a reflector designed for a conventional bulb is an instant MOT fail regardless of beam pattern.
Be a REAL MAN!
ThatDippyTwat
PostPosted: 20:59 - 21 Aug 2018    Post subject: Reply with quote
LED was an illustration to show you that Wattage is just the energy consumed, and not really an indicator of the light emitted. Unless you replace the entire headlamp with something like a Daymaker, I wouldn't bother with LED's/.
In short - Don't use HID's, full stop.
Osram (Nightbreaker), Phillips (X-Treme Vision) etc all do really good bulbs. Use those.
Cavallo
PostPosted: 21:02 - 21 Aug 2018    Post subject: Reply with quote
My headlamps is like this one https://youtu.be/Vx-TiafBowU
Nobby the Bastard
Harley Gaydar
PostPosted: 21:06 - 21 Aug 2018    Post subject: Reply with quote
What part of 'Don't use HID' don't you understand?
Your next comment will be 'I'll stick with the standard tyole bulb but increase the wattage', won't it?
Triumph Sprint ST 1050
Cavallo
PostPosted: 21:13 - 21 Aug 2018    Post subject: Reply with quote
No, just an answer. In my county we dont do mot for motorcycles, so no one will give a damn what bulb i do use.....
Nobby the Bastard
Harley Gaydar
PostPosted: 21:19 - 21 Aug 2018    Post subject: Reply with quote
So you don't care about dazzling people then?
Can you tell us which country you are in so that we can avoid it? The death rates on the roads there must be appaling if you are typical.
ThatDippyTwat
PostPosted: 21:20 - 21 Aug 2018    Post subject: Reply with quote
They will if you dazzle oncoming drivers and one decides to turn around and "have a chat" about it and shove it up your arse. Frequently happens in Latino countries if Youtube is anything to go by.
Also - Top quote, not bottom quote.
The last post was made 7 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 73.16 Kb
