Plumes of smoke from my TZR
Bomberman
PostPosted: 12:41 - 19 Mar 2005    Post subject: Plumes of smoke from my TZR Reply with quote
Hmmm. this looks potentially bad Thumbs Down
I've fitted a new (eBay second hand) exhaust to my bike, and took it out for a run yesterday. As it was warming up I noticed a lot of smoke. Seemed okish though so off I went. Now, as I've repainted my bike, its currently without mirrors so I don't know when this started. Anyway, I eventually noticed huge clouds of white smoke pouring out the back of the bike when under revs.
It was running mint until I replaced the exhaust so what's happened? To be honest its running a crap load better now, far more responsive and improved acceleration due to the exhaust not being swiss cheese , but with gouts of smoke. Has the extra compression popped something inside? Could it be crap burning off the inside of the exhaust? I reallly have no idea Sad
PostPosted: 13:18 - 19 Mar 2005    Post subject: Reply with quote
Could just be crap from inside the exhaust. I usually assosciate white smoke with water, could just be condensation or water in the zorst. At worst your head gasket could be leaking coolant into the engine.
Check your plug to make sure the mix is right and keep an eye on the coolant level.
ts50x0
PostPosted: 17:24 - 20 Mar 2005    Post subject: Reply with quote
to be honest id ride it for about anther week or so and see if it stops, its a bit of a coincedence if another problem were to come just at that time, id say it is crap in your exhaust.
how long did you ride it for?
alains
PostPosted: 20:51 - 20 Mar 2005    Post subject: Reply with quote
clean exhaust system and have a look at your oil pump adjustment . but normally 2 strokes engines starts somky and then became clear .
PostPosted: 22:00 - 20 Mar 2005    Post subject: Reply with quote
Is it an aftermarket "race" exhaust or just another stock one?
White smoke from a 2 stroker can be quite an evil indication, as StinkWheel said, of a leaky gasket.
If its a race system, just make sure its not burning lean, of course if its just a replacement standard pipe, you shouldnt need to worry about that.
I've been told that caustic soda works wonders for cleaning out exhausts. Might be worth flushing it out with some. Thumbs Up
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
Bomberman
PostPosted: 00:02 - 21 Mar 2005    Post subject: Reply with quote
Thanks for all the replies, but I'm leaning toward it having been just full of crap after a good ragging today. Seems (after again, a smokier than usual start) to have settled down, so fingers crossed that's all it was. None of my fluid levels seem to be falling abnormally (after about 30 miles running) so another good sign I think. the coolant level hasn't moved in the 6 months I've been running this bike. Should drain and refresh that I guess at some point. Finally, its a straight swap, the new zorst carries the same markings and serial number as the one it replaced.
On alains point about the pump, it did remind me a lot of when the 2t pump broke and got jammed on full permanently. But that would be too coincidental surely (plus the pump is only about four months old).
I'll keep an eye on it and let you know Thumbs Up
Bomberman
PostPosted: 16:10 - 21 Mar 2005    Post subject: Reply with quote
Hmmm. After a good 50 mile run today, lets look at the facts...;
a) Fine before new exhaust fitted, smoky after but running well.
b) None of the fluid levels are falling.
c) Paint is literally falling off the downpipe on the zorst... Rolling Eyes
So, after getting the engine really hot and looking it over, I discovered I can wipe the black paint off the exhaust with my fingers Rolling Eyes Which would suggest to me that;
a) Muppet I bought the exhaust off used bog standard spray paint or Zebrite...
b) In the effort to make the exhaust look like a pro paint job painted the top and a bit of the inside of the exhaust with the same non heat resistant paint...Rolling Eyes
I believe I'm burning this crap through now and that's the smoke I'm experiencing. Sounds fair, given the above? Any damage going to occur?
PostPosted: 16:42 - 21 Mar 2005    Post subject: Reply with quote
It'll probably be fine. Just wait for enough of it to melt off, or remove the crap paint yourself and get a can of Halfords exhaust spray, its only about £6 a can and works pretty well. Just make sure the normal paint is off first or the high temperature stuff wont work too well.
The last post was made 21 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 59.26 Kb
