| Scarb1989 |
 Scarb1989 Derestricted Danger
| jaffa90 |
 jaffa90 World Chat Champion
| Scarb1989 |
| Evil Hans |
 Evil Hans World Chat Champion
| Scarb1989 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:16 - 31 Aug 2018 Post subject: |
Single disc?
What bike?
This 'Wobble' is it on the brake, or the steering?
Caliper bolts to fork; disk to wheel; pads 'should' sort of touch the pads in the caliper, there should be space above disc between pads before caliper.
Wheel alignment/spindle-spacers would alter where the wheel sits between the disc, side-to-side, not the height of caliper up-and-down.
If its a floating caliper... ie only one or one pair of pistons driven by the hydraulics, so the driven piston pushing against disc pulls the caliper over to press other pad against disc from the back; then a sticky float mount, dirty, rusty or worn float-pins, then the caliper can be reluctant to move and when brake released leave usually back, non piston side pad rubbing slightly on disc.
IF the disc warped... then wobble on the disc will push the pads further apart than they would if true., and give a take-up lag when you brake, as well as pulsating brake pressure.
Released, you'd also probably get a knock or wobble on the brakes, as the wobly disc tries to shove the caliper side-to-side- as the wheel turns, which would be more pronounced if floating caliper and float mounts old and sticky.
If the caliper is resting on the disc.... as in the body of the caliper has dropped up-down-wise.... then ???? Caliper-Mounts, wheel bearings, what else would let caliper go that far down or wheel come up so far?
IF, the 'wobble' is in the steering... and head-races just changed... probably the first suspect, but last to be looked at is the front tyre.
Before headrace bearings chanced, there was probably some side to side and up and down 'play' on the whole forks; that would likely exacerbate tyre wear and uneven wear; that p[lay removed by new bearings, the tyre could be trying to 'track' on old wear ridges, causing wobble.
Headrace bearings, should also be re-checked and pre-load adjusted after about 100-200 miles, as they bed in... has this been done yet?
Lastly? If head-race bearings replaced; what about wheel bearings?
If the headrace bearings worn, then the wheel-bearings will have likely been taking an extra hammering from any slop in the stem; headrace bearing play could let wheel go high, which 'might' pit disc closer to caliper; but again, would be prime candidate for any 'wobble' in the steering, which would be most noticeable at walking pace type speeds.
More investigation, and better description required, possibly photo's.
History, vis work done in headrace replacement, may or may not have any influence on the matter; so first rule of diagnostics; dont go by what was, go by what IS, clean sheet, fresh eyes; go by what you see, here and now, dont let that be blind-sided by assumptions and presumptions from what might be or has been. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Scarb1989 |
 Posted: 15:22 - 31 Aug 2018 Post subject: |
| Teflon-Mike wrote: | Single disc?
What bike?
History, vis work done in headrace replacement, may or may not have any influence on the matter; so first rule of diagnostics; dont go by what was, go by what IS, clean sheet, fresh eyes; go by what you see, here and now, dont let that be blind-sided by assumptions and presumptions from what might be or has been. |
It's a rieju rs3 lc pro 125 2015 model. No wheel bearings weren't changed and the steering bearings were only changed yesterday. I am getting 2 new tires next Friday so might change the bearings aswell. It's the steering itself almost like it's steering left to right itself at low speeds but at higher speeds If I take my hands of the handlebars it's fine obviously I do this cautiously. I'm suppose to he travelling 40miles tomorrow and don't want to end or with a fucked up day ____________________ Mscarbro |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Riejufixing |
 Riejufixing World Chat Champion
| Nobby the Bastard |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Scarb1989 |
| Scarb1989 |
The last post was made 8 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
