Front brake question
Scarb1989
PostPosted: 13:26 - 31 Aug 2018    Post subject: Front brake question Reply with quote
I have recently just had my steering bearings changed and there is still a slight wobble at very low speed 5to10mph but no wobble at higher speeds than that at closer inspection I have noticed that the brake is sitting on the disc. Could this be to do with it have they aligned my wheel wrong
Mscarbro
jaffa90
PostPosted: 13:39 - 31 Aug 2018    Post subject: Reply with quote
Is the caliper touching the disc edge?
Has the tyre been fitted correctly and wheel balance?
It could be a rear wheel problem!
Scarb1989
PostPosted: 14:22 - 31 Aug 2018    Post subject: Reply with quote
Yes mate it's rubbing on it I have lifted the bike up and it's making a noise when you spin the wheel and you can see it touching it
Mscarbro
Evil Hans
PostPosted: 14:58 - 31 Aug 2018    Post subject: Reply with quote
So it's definitely the caliper touching the disc and not just the pad?
Nasty - did they put some spacers back in wrong, maybe?
Scarb1989
PostPosted: 15:08 - 31 Aug 2018    Post subject: Reply with quote
I meant pad sorry. New to learning about bikes clearly lol. Just never noticed it before then to say I have had new steering head bearings it certainly shouldn't have a slight wobble. Even though it does sort itself out once your going passed 10mph
Mscarbro
Teflon-Mike
tl;dr
PostPosted: 15:16 - 31 Aug 2018    Post subject: Reply with quote
Single disc?
What bike?
This 'Wobble' is it on the brake, or the steering?
Caliper bolts to fork; disk to wheel; pads 'should' sort of touch the pads in the caliper, there should be space above disc between pads before caliper.
Wheel alignment/spindle-spacers would alter where the wheel sits between the disc, side-to-side, not the height of caliper up-and-down.
If its a floating caliper... ie only one or one pair of pistons driven by the hydraulics, so the driven piston pushing against disc pulls the caliper over to press other pad against disc from the back; then a sticky float mount, dirty, rusty or worn float-pins, then the caliper can be reluctant to move and when brake released leave usually back, non piston side pad rubbing slightly on disc.
IF the disc warped... then wobble on the disc will push the pads further apart than they would if true., and give a take-up lag when you brake, as well as pulsating brake pressure.
Released, you'd also probably get a knock or wobble on the brakes, as the wobly disc tries to shove the caliper side-to-side- as the wheel turns, which would be more pronounced if floating caliper and float mounts old and sticky.
If the caliper is resting on the disc.... as in the body of the caliper has dropped up-down-wise.... then ???? Caliper-Mounts, wheel bearings, what else would let caliper go that far down or wheel come up so far?
IF, the 'wobble' is in the steering... and head-races just changed... probably the first suspect, but last to be looked at is the front tyre.
Before headrace bearings chanced, there was probably some side to side and up and down 'play' on the whole forks; that would likely exacerbate tyre wear and uneven wear; that p[lay removed by new bearings, the tyre could be trying to 'track' on old wear ridges, causing wobble.
Headrace bearings, should also be re-checked and pre-load adjusted after about 100-200 miles, as they bed in... has this been done yet?
Lastly? If head-race bearings replaced; what about wheel bearings?
If the headrace bearings worn, then the wheel-bearings will have likely been taking an extra hammering from any slop in the stem; headrace bearing play could let wheel go high, which 'might' pit disc closer to caliper; but again, would be prime candidate for any 'wobble' in the steering, which would be most noticeable at walking pace type speeds.
More investigation, and better description required, possibly photo's.
History, vis work done in headrace replacement, may or may not have any influence on the matter; so first rule of diagnostics; dont go by what was, go by what IS, clean sheet, fresh eyes; go by what you see, here and now, dont let that be blind-sided by assumptions and presumptions from what might be or has been.
Scarb1989
PostPosted: 15:22 - 31 Aug 2018    Post subject: Reply with quote
Teflon-Mike wrote:
Single disc?
What bike?
It's a rieju rs3 lc pro 125 2015 model. No wheel bearings weren't changed and the steering bearings were only changed yesterday. I am getting 2 new tires next Friday so might change the bearings aswell. It's the steering itself almost like it's steering left to right itself at low speeds but at higher speeds If I take my hands of the handlebars it's fine obviously I do this cautiously. I'm suppose to he travelling 40miles tomorrow and don't want to end or with a fucked up day
Mscarbro
Teflon-Mike
tl;dr
PostPosted: 15:34 - 31 Aug 2018    Post subject: Reply with quote
That steering wobble sounds to me more like tyre and/or or wheel bearings.
Riejufixing
PostPosted: 15:54 - 31 Aug 2018    Post subject: Reply with quote
Ah. I have a couple of those out at the back. Steering head bearings replaced, wobble, stops with hands off bars?
Perhaps after the bearings were replaced, the whole steering head was put together slightly twisted. Your hands on the handlebars correct the pull to one side, which re-exerts itself, then repeat. Just a thought.
EDIT: they're taper roller bearings. Perhaps the steering head needs adjustment?
Nobby the Bastard
Harley Gaydar
PostPosted: 16:39 - 31 Aug 2018    Post subject: Reply with quote
Probably just need tightening to the correct torque.
DrDonnyBrago
PostPosted: 16:41 - 31 Aug 2018    Post subject: Reply with quote
Pads resting lightly on the disc is normal. If it is dragging badly then the caliper likely needs some TLC.
Scarb1989
PostPosted: 16:55 - 31 Aug 2018    Post subject: Reply with quote
going to take a look tomorrow morning before setting of quite a resillant bike not had many problems with it in fairness
Mscarbro
Scarb1989
PostPosted: 19:26 - 31 Aug 2018    Post subject: Reply with quote
Also I have noticed a slight creak every so often in the steering
Mscarbro
The last post was made 8 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 85.25 Kb
