How to shift to 3rd gear in a honda cf50
vellios
PostPosted: 23:34 - 02 Sep 2018    Post subject: How to shift to 3rd gear in a honda cf50 Reply with quote
I've just bought my cf50 and I connot figure out how to change it to 3rd gear
[/code]
PostPosted: 14:38 - 03 Sep 2018    Post subject: Reply with quote
The same way you changed it from 1st to 2nd.
It wont shift into higher gears unbless the bike and/or engine are rotating so if you're sat on it in the garage making brumming noises, you won't get it into third.
Are you sure you are setting off in first and not second?
vellios
PostPosted: 01:25 - 04 Sep 2018    Post subject: Reply with quote
It shifts normally to 1st and 2nd but in can't for some reason
Nobby the Bastard
Harley Gaydar
PostPosted: 12:54 - 04 Sep 2018    Post subject: Reply with quote
This is when we find out that the gearbox is 1 down and 2 up and you are expecting 3 up.....
Triumph Sprint ST 1050
johnsmith222
PostPosted: 12:56 - 04 Sep 2018    Post subject: Reply with quote
does the shifter return after shifting, or does it stay in place?
If it stays in place, then it probably needs either: removed, cleaned/lubricated, or perhaps the shifter return spring is worn or has snapped.
The last post was made 7 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 41.67 Kb
