| adengtg |
 adengtg Scooby Slapper
 Posted: 13:28 - 23 Oct 2018 Post subject: XJ600 Clutch nackered, Pull rod broken? |
Was testing my 97' Yamaha Xj600N the other day when i pulled the clutch and nothing happened. managed to get it into gear and check the cable which is fine. Looked at the release lever and it was completely loose. seemed to be no resistance on it at all and was not operating the clutch at all. Took the clutch cover off and had a look inside.
It seems that without taking the clutch its self off, that the "Pull rod" is completely loose and doesn't seem to be doing anything. I have no idea how to fix this or what it really means to be honest. just looked at the manual and saw the pull rod wasnt doing anything useful.
I will attach a video or two and some photos on a google drive to give a better explanation of the issue.
https://photos.app.goo.gl/r5zbeGjARr7vn7h57
Just in need of some advice as to what is broken and how best to fix it. Ive not had any experience working on clutches so i dont really know whats what, will try by best to fix it myself though.
Thanks very much for the help guys! |
| rpsmith79 |
 rpsmith79 World Chat Champion
 Posted: 14:17 - 23 Oct 2018 Post subject: Re: XJ600 Clutch nackered, Pull rod broken? |
This might help you understand what is supposed to be going on
https://www.youtube.com/watch?v=TcYsV063lk8
Looks like you push rod is actuated via the rack and pinion (the rack being the straight gear teeth section on your push rod, and the pinion being the gear wheel on the clutch cover, actuated by the clutch lever)
So make sure when you put it back together that the rack and pinion mesh correctly ____________________ Current Bike: Honda CG125 ES4 // Honda CB600FS Hornet // Triumph Street Triple R |
| adengtg |
| rpsmith79 |
| adengtg |
 Posted: 15:25 - 23 Oct 2018 Post subject: |
Thanks, have the drawing in my haynes manual as otherwise id have no iidea what a pull rod is. Big thanks for the help anyways mate! |
| Riejufixing |
 Riejufixing World Chat Champion
| adengtg |
| Riejufixing |
| adengtg |
| adengtg |
| A100man |
 A100man World Chat Champion
 Posted: 18:18 - 23 Oct 2018 Post subject: |
The 'wobbly' push plate rod is OK I think. You need to look inside the clutch cover and see what the mechanism there is like (damaged?). Check all parts against the diagram posted above. Maybe post a photo of teh clutch cover ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Riejufixing |
| bikenut |
 bikenut World Chat Champion
| R1stu |
 R1stu Shrek!
| adengtg |
| bikenut |
 Posted: 11:27 - 29 Oct 2018 Post subject: clucth |
I think some more pics are in order here.......you have the cmsnl exploded view so know what stuff looks like......
the clutch friction plates will have a service limit thickness, below the limit will influence clutch slip. The coil springs will have a service limit poundage, weak springs cannot clamp the worn friction discs etc tight, so the clutch slips. 2muew w r, but count the friction faces, as that formula assumes a 2 friction face clucth system.
So, the clutch end cable lever on the engine has good splines and so does the pull "shaft", so no slippage there ??
The rack system is all ok, see the picture of the "pull clutch release" part, the bit with the rack held in by what looks like a roll pin or spring dowel, that is ok ?
What the pull part pulls against is all ok, like the thrust bearing, the bit with the clock face rollers and what they roll on, are all ok ?
How is gear selection, bit of a daft question as the clutch is usually involved with that, and how is the gearbox input shaft end float, any more than a tiny bit of in and out movement means possiblel bearing problem....
clutcvh friction plates and metal plates thickness and all is ok with the innermost metal plate and its "spring" ?
What is the up to date fault, you pull the handle bar clutch lever to the handlebar and what happens exactly ?
I assume the handlebar end lever and pivot etc. is all ok as is the cable inner and outer, and any mid cable adjuster etc. ?
Pics and a video might be good..... ____________________ nuts about bikes |
| cb1rocket |
 cb1rocket World Chat Champion
| cb1rocket |
| cb1rocket |
 Posted: 12:20 - 29 Oct 2018 Post subject: |
| A100man |
 Posted: 20:46 - 29 Oct 2018 Post subject: |
| cb1rocket wrote: | Look at the shaft in the clutch cover that conects to clutch cable, your most likely find that it has snapped. |
We asked this before - OP don't listen that good  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| adengtg |
| cb1rocket |
 Posted: 00:18 - 30 Oct 2018 Post subject: |
there are NO photos of the clutch cover. I'm talking about the clutch rod in the clutch cover. Forget all the pictures of the clutch assembly on the engine that you took. None of that seems broken.
You mentioned that the clutch actuation rod on the cover was all loose and floppy. It shouldn't be ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| adengtg |
| cb1rocket |
 Posted: 00:27 - 30 Oct 2018 Post subject: |
sorry. just seen that video, didn't know it was a video. The only thing i can think of is that the splines to top of actuation rod is stripped. can you get me a picture of clutch cover inside and rod rotation direction. i got the feeling the cover has worked loose and not pushing on the rod. ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| adengtg |
The last post was made 7 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
