XJ600 Clutch nackered, Pull rod broken?
adengtg
PostPosted: 13:28 - 23 Oct 2018    Post subject: XJ600 Clutch nackered, Pull rod broken? Reply with quote
Was testing my 97' Yamaha Xj600N the other day when i pulled the clutch and nothing happened. managed to get it into gear and check the cable which is fine. Looked at the release lever and it was completely loose. seemed to be no resistance on it at all and was not operating the clutch at all. Took the clutch cover off and had a look inside.
It seems that without taking the clutch its self off, that the "Pull rod" is completely loose and doesn't seem to be doing anything. I have no idea how to fix this or what it really means to be honest. just looked at the manual and saw the pull rod wasnt doing anything useful.
I will attach a video or two and some photos on a google drive to give a better explanation of the issue.
https://photos.app.goo.gl/r5zbeGjARr7vn7h57
Just in need of some advice as to what is broken and how best to fix it. Ive not had any experience working on clutches so i dont really know whats what, will try by best to fix it myself though.
Thanks very much for the help guys!
rpsmith79
PostPosted: 14:17 - 23 Oct 2018    Post subject: Re: XJ600 Clutch nackered, Pull rod broken? Reply with quote
This might help you understand what is supposed to be going on
https://www.youtube.com/watch?v=TcYsV063lk8
Looks like you push rod is actuated via the rack and pinion (the rack being the straight gear teeth section on your push rod, and the pinion being the gear wheel on the clutch cover, actuated by the clutch lever)
So make sure when you put it back together that the rack and pinion mesh correctly
adengtg
PostPosted: 14:34 - 23 Oct 2018    Post subject: Re: XJ600 Clutch nackered, Pull rod broken? Reply with quote
Right, very helpful actually. Dont suppose you have any ideas on whats up with mine then? Would it be the actual rod thats broken maybe or the bearings perhaps?
rpsmith79
PostPosted: 15:02 - 23 Oct 2018    Post subject: Reply with quote
No idea i'm afraid
Have you looked up the parts drawing online at somewhere like Fowlers or CMS, they can usually help understand what is supposed to go where, and what might be missing/broken
Here you go, clutch assy from an XJ600, 1997 year
https://www.cmsnl.com/yamaha-xj600n-1997-4ke7-all-countries-274ke-300e1_model38905/partslist/0016.html#.W88q23tKjIU
adengtg
PostPosted: 15:25 - 23 Oct 2018    Post subject: Reply with quote
rpsmith79 wrote:
No idea i'm afraid
Thanks, have the drawing in my haynes manual as otherwise id have no iidea what a pull rod is. Big thanks for the help anyways mate!
Riejufixing
PostPosted: 15:56 - 23 Oct 2018    Post subject: Re: XJ600 Clutch nackered, Pull rod broken? Reply with quote
What/why were you testing? Had you had the thing apart to replace or check something, or what?
adengtg
PostPosted: 15:59 - 23 Oct 2018    Post subject: Re: XJ600 Clutch nackered, Pull rod broken? Reply with quote
Riejufixing wrote:
What/why were you testing? Had you had the thing apart to replace of check something, or what?
No, nothing apart. Just riding it ,slowed down to stop when the clutch lever went all loose and it stalled. At first i thought the cable had broken but thats not the case. had to ram it back and forth in gear to get it into neutral to push it back home. hadnt touched the clutch or anything to do with it previously
Riejufixing
PostPosted: 16:07 - 23 Oct 2018    Post subject: Re: XJ600 Clutch nackered, Pull rod broken? Reply with quote
I might be inclined to whip off the pressure plate, and check that the actuating mechanism fits in the cover nicely and that nothing is worn or broken.
adengtg
PostPosted: 16:14 - 23 Oct 2018    Post subject: Re: XJ600 Clutch nackered, Pull rod broken? Reply with quote
If you check the google drive thatss posted you should be able to see whats happening. i can try to take it off as long as you dont need any specialist tools such as a clutch holding tool
adengtg
PostPosted: 16:30 - 23 Oct 2018    Post subject: Re: XJ600 Clutch nackered, Pull rod broken? Reply with quote
Ok, i took it off and all seems fine to my eyes. all the springs are...springy, the pull rod bearing is fine and the friction plates dont look to worn. The clutch is engaged through all of this i should stress. I might just put it all back together and see what happens. All the bolts were sufficiently torqued and nothing seems out of place but ive never worked on a clutch before so that means exactly nothing.
A100man
PostPosted: 18:18 - 23 Oct 2018    Post subject: Reply with quote
The 'wobbly' push plate rod is OK I think. You need to look inside the clutch cover and see what the mechanism there is like (damaged?). Check all parts against the diagram posted above. Maybe post a photo of teh clutch cover
Riejufixing
PostPosted: 20:50 - 23 Oct 2018    Post subject: Reply with quote
If you fit up the pull mechanism in the (dismounted) pressure plate to the actuator in the cover does it all seem OK, a good fit and not so slack that the teeth don't engage (and are all the teeth intact)? The thing is if the clutch just stopped working then something must have happened!
EDIT: It occurs to me that the clutch cable (which you say is OK) must fasten to the end of the actuating mechanism; is the connection and the attachment of a lever arm (?) secure, and any splines/square adjustable (?) join OK?
bikenut
PostPosted: 10:02 - 25 Oct 2018    Post subject: clucth Reply with quote
Ain't cmsnl exploded views great, a picture tells a 1000 words.
Is the actuating arm slipping on the clutch arm shaft, splines knackered perhaps or just the pinch bolt loose ?
clutch hub nutted on so no real special tools needed apart from a means of stopping the hub rotating, but you have a gearbox and rear brakes eh.
All that info from a diagram.
You do not have to remove the clutch hub or basket to remove the clutch plates but perhaps it would be easier to remove the last metal sprung loaded plate, the one that's circliped on.
The clutch was not slipping just not releasing ?
nuts about bikes
R1stu
Shrek!
PostPosted: 10:44 - 25 Oct 2018    Post subject: Reply with quote
Ive got a complete engine spare, going be breaking down for parts if need anything for the clutch side.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
adengtg
PostPosted: 15:35 - 27 Oct 2018    Post subject: Re: clucth Reply with quote
I noticed that when i went to full throttle it slipped a little but i just wrote that off as a one time thing from being a bit too aggressive. Ive since taken the pressure plate and the clutch plates out and nothing seems too worn o obviously broken. i put everything back together and tightened it all up and its just the same as it was last time.
bikenut
PostPosted: 11:27 - 29 Oct 2018    Post subject: clucth Reply with quote
I think some more pics are in order here.......you have the cmsnl exploded view so know what stuff looks like......
the clutch friction plates will have a service limit thickness, below the limit will influence clutch slip. The coil springs will have a service limit poundage, weak springs cannot clamp the worn friction discs etc tight, so the clutch slips. 2muew w r, but count the friction faces, as that formula assumes a 2 friction face clucth system.
So, the clutch end cable lever on the engine has good splines and so does the pull "shaft", so no slippage there ??
The rack system is all ok, see the picture of the "pull clutch release" part, the bit with the rack held in by what looks like a roll pin or spring dowel, that is ok ?
What the pull part pulls against is all ok, like the thrust bearing, the bit with the clock face rollers and what they roll on, are all ok ?
How is gear selection, bit of a daft question as the clutch is usually involved with that, and how is the gearbox input shaft end float, any more than a tiny bit of in and out movement means possiblel bearing problem....
clutcvh friction plates and metal plates thickness and all is ok with the innermost metal plate and its "spring" ?
What is the up to date fault, you pull the handle bar clutch lever to the handlebar and what happens exactly ?
I assume the handlebar end lever and pivot etc. is all ok as is the cable inner and outer, and any mid cable adjuster etc. ?
Pics and a video might be good.....
nuts about bikes
cb1rocket
PostPosted: 12:10 - 29 Oct 2018    Post subject: Reply with quote
Look at the shaft in the clutch cover that conects to clutch cable, your most likely find that it has snapped.
cb1rocket
PostPosted: 12:13 - 29 Oct 2018    Post subject: Reply with quote
Your looking for this shaft, its most likely has snapped above the pinion.
https://i.ebayimg.com/images/g/4oEAAOSwvvBaoYx5/s-l1600.jpg
cb1rocket
PostPosted: 12:20 - 29 Oct 2018    Post subject: Reply with quote
Full clutch unit
https://www.ebay.co.uk/itm/1992-2004-YAMAHA-XJ-600-S-DIVERSION-4BR-CLUTCH-COVER-ARM-0044/271467456644?hash=item3f34b8a884%3Ag%3A3HkAAOxycD9TW7RX&LH_ItemCondition=4
A100man
PostPosted: 20:46 - 29 Oct 2018    Post subject: Reply with quote
We asked this before - OP don't listen that good Rolling Eyes
adengtg
PostPosted: 21:15 - 29 Oct 2018    Post subject: Reply with quote
It hasnt, i thought that was clear by the photos. If you'll look on the album you can see that its working fine. Ive been busy these past few days but tomorrow ill take it all apart again and put a fuck ton more photos on the google drive as requested.
cb1rocket
PostPosted: 00:18 - 30 Oct 2018    Post subject: Reply with quote
there are NO photos of the clutch cover. I'm talking about the clutch rod in the clutch cover. Forget all the pictures of the clutch assembly on the engine that you took. None of that seems broken.
You mentioned that the clutch actuation rod on the cover was all loose and floppy. It shouldn't be
adengtg
PostPosted: 00:21 - 30 Oct 2018    Post subject: Reply with quote
If you look at the videos, one of them features the clutch cover and assembly. Sorry for not being more specific. I took all that apart and it seems fine but i will do it again tomorrow and take more pictures.
cb1rocket
PostPosted: 00:27 - 30 Oct 2018    Post subject: Reply with quote
sorry. just seen that video, didn't know it was a video. The only thing i can think of is that the splines to top of actuation rod is stripped. can you get me a picture of clutch cover inside and rod rotation direction. i got the feeling the cover has worked loose and not pushing on the rod.
adengtg
PostPosted: 00:29 - 30 Oct 2018    Post subject: Reply with quote
Can do, will be about lunch time tomorrow. Right now its held on my a few bolts as close to as it was when it broke. i will strip it all back to show what went wrong and document the hole thing on the google drive.
The last post was made 7 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 138.38 Kb
