Yam YBR 125 2012 Throttle Cable snapped, help.
JamesDuncann
PostPosted: 13:08 - 28 Oct 2018    Post subject: Yam YBR 125 2012 Throttle Cable snapped, help. Reply with quote
Hi,
I'm new here and need some advice from fellow bikers who know what they're doing.
One of my inner throttle cables has snapped and I am unsure of what I need to rectify this, do I need a specific cable for the YBR or can I buy a universal inner cable?
I am also unsure of whether it matters if it is push or pull as I have searched google and found two types on cable.
I'm quite hands on and want to give this a go myself.
Cheers,
James.
PostPosted: 13:14 - 28 Oct 2018    Post subject: Reply with quote
1. Buy replacement throttle cable for about a tenner
2. Fit it.
3. ?
4. Profit.
JamesDuncann
PostPosted: 13:21 - 28 Oct 2018    Post subject: Reply with quote
The Shaggy D.A. wrote:
4. Profit.
Sounds good to me, thanks.
Evil Hans
PostPosted: 15:21 - 28 Oct 2018    Post subject: Re: Yam YBR 125 2012 Throttle Cable snapped, help. Reply with quote
Is it the push or the pull cable that has snapped?
Maybe just replace both to be on the safe side Very Happy
WD Forte
PostPosted: 16:04 - 28 Oct 2018    Post subject: Reply with quote
Buy both
bikers smell of wee
flearider
PostPosted: 16:41 - 28 Oct 2018    Post subject: Re: Yam YBR 125 2012 Throttle Cable snapped, help. Reply with quote
JamesDuncann wrote:
Hi,
Cheers,
James.
it snapped at the nipple din't it ?
had one bout 5 yrs ago happened twice.. not good
JamesDuncann
PostPosted: 09:18 - 31 Oct 2018    Post subject: Reply with quote
WD Forte wrote:
Buy both
When I looked on mymoto or MandP for replacements there is only one throttle cable type, are the push and pull the same length?
dydey90
PostPosted: 09:42 - 31 Oct 2018    Post subject: Reply with quote
Wemoto says pull cable
https://www.wemoto.com/bikes/yamaha/ybr_125/12/picture/throttle_cable_a_pull_genuine_manufacturer_part_oem
JamesDuncann
PostPosted: 10:08 - 31 Oct 2018    Post subject: Reply with quote
dydey90 wrote:
https://www.wemoto.com/bikes/yamaha/ybr_125/12/picture/throttle_cable_a_pull_-_slinky_glide
As you see this part is pull as well
Do I just get both of them
Riejufixing
PostPosted: 10:47 - 31 Oct 2018    Post subject: Reply with quote
Aren't they the same part, one "original equipment", the other a pattern?
Evil Hans
PostPosted: 11:27 - 31 Oct 2018    Post subject: Reply with quote
Fowlers shows two different cables:
https://www.fowlersparts.co.uk/parts/5452224/ybr125ed-2012-51d2-europe-black-metallic-x/steering-handle-cable
Again, which of yours has broken, the push or the pull?
bikenut
PostPosted: 11:41 - 31 Oct 2018    Post subject: cable Reply with quote
get a new cable, probably the pull one that opens the "throttle".........
easy to suss out which one has broken, cables are probably different with different adjusters etc........
you know of cmsnl for the exploded views but shop around.....
dont bin the old cable just yet, make a new nipple and learn how to repair the old cable.......
motorcycle maintenance is very much little and often, and that means cables as well, they need lub and good runs.....
nuts about bikes
JamesDuncann
PostPosted: 12:56 - 31 Oct 2018    Post subject: Reply with quote
I’m just going to be replacing both, thanks for link
Islander
Run the new cable in alongside the old first, then remove the old one. That way, you'll keep the routing right. Thumbs Up
bikenut
PostPosted: 11:12 - 01 Nov 2018    Post subject: cable Reply with quote
If it was routed right that is, its a 2012 bike......look and make sure its not trapped anywhere and not kinked and a smooth run.
Make sure the engine does not start to rev when the handlebars are moved form lock to lock, and that the throttle "returns" and snaps ( bad choice of word but you get my drift ) closed after letting go of the throttle twist grip.
Remember it needs to be in adjustment also.
There may be a manual on here with the oe routing shown.
Cables need regular lubing, little and often.
nuts about bikes
The last post was made 7 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.52 - MySQL Queries: 13 - Page Size: 84.53 Kb
