Tamper proof carb!? Kymco CK1
UnspeedySam
PostPosted: 23:08 - 31 Oct 2018    Post subject: Tamper proof carb!? Kymco CK1 Reply with quote
I've taken in a poorly 2014 Kymco CK1 for a neighbour that his son ran dry and now won't start. I'm 90% sure it's got a blocked idle jet from the symptoms and very sparky spark plug.
Now the annoying bit. As is standard with Mikuni carbs, the float bowl screws are stuck and made of cheese. So I want to take the carb off to get it on a work bench. However on the side of the carb is some electrical gubbins with a connector that refuses to come off.
Am I correct in thinking I need to snap off the little red bits on the connector and then accept it'll never go together again without bodgery? I know I could buy a silly tamper proof screw driver to remove the unit, which is another option. Oh and the cable goes straight into the main loom. Sad
Oh and yes the carb is upside-down. That's my desperate attempt at trying to soak the float bowl screws in penetrating fluid.
https://www.bikechatforums.com/download.php?id=101712
Riejufixing
PostPosted: 23:22 - 31 Oct 2018    Post subject: Reply with quote
I've seen some of those silly red bits on something before, but I can't remember what. I don't think you break them, I think there's a cunning way, but ICBW.
UnspeedySam
PostPosted: 23:26 - 31 Oct 2018    Post subject: Reply with quote
Interesting. I've just remembered that I have a security torx set that I bought ages ago. I guess I'm hunting for those tomorrow. Would be good to know what I'm removing though...anyone have a clue?
cb1rocket
PostPosted: 00:07 - 01 Nov 2018    Post subject: Reply with quote
its a tps.
throttle position sensor
Riejufixing
PostPosted: 00:14 - 01 Nov 2018    Post subject: Reply with quote
This is bugging me ("you too, huh?"). I thought I had one but I haven't. ISTR you have to pull them up, sideways or down, or maybe they ara part of another thing and move when that's pushed/whatnot. Blast. Sorry.
WD Forte
PostPosted: 01:14 - 01 Nov 2018    Post subject: Reply with quote
I reckon the outer bit is the locking part of the connector and has to be pulled away (over the red bits) to release it
bikers smell of wee
jaffa90
PostPosted: 01:31 - 01 Nov 2018    Post subject: Reply with quote
As said, i can see a torx screw a broken t.p.s. with the outer locking part.
Monkeywrenche...
PostPosted: 10:00 - 01 Nov 2018    Post subject: Reply with quote
Those red bits need to be slid backwards out of the plug, they're blocking the "flap" from pivoting up when you push the release tab in. if there's no tab to push try sliding a thin screwdriver gently up thae gap between the connector and the sensor to lift the locking flappy bit.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
ThatDippyTwat
PostPosted: 20:55 - 01 Nov 2018    Post subject: Reply with quote
cb1rocket wrote:
its a tps.
TPS? On a carb?
It's an Autochoke.
cb1rocket
PostPosted: 21:34 - 01 Nov 2018    Post subject: Reply with quote
pretty sure its a tps. my vtr1000 had carbs and a tps. no autochoke
UnspeedySam
PostPosted: 21:35 - 01 Nov 2018    Post subject: Reply with quote
ThatDippyTwat wrote:
cb1rocket wrote:
its a tps.
TPS? On a carb?
It's an Autochoke.
Nope! Choke is manual, cable operated. It's a 2014, lots of mad emissions stuff on there I don't understand...
UnspeedySam
PostPosted: 21:37 - 01 Nov 2018    Post subject: Reply with quote
I'll have another go at this. I have a lot of cable ties if I screw it up. Laughing
Thanks to everyone for the feedback. I'll have another go tomorrow or Saturday and let you know what happens.
Unfortunately there is NOTHING online about this bike, despite there being loads around (looking at ebay and gumtree). You can't even get an air filter for it from a UK supplier as far as I can see. Very odd...
temeluchus
PostPosted: 07:24 - 02 Nov 2018    Post subject: Reply with quote
TPS? On a carb?
It's an Autochoke.
Fucking loads of carb'd bikes had TPS. Pretty common by the mid 90s.
talkToTheHat
PostPosted: 09:33 - 04 Nov 2018    Post subject: Reply with quote
Both my carbed 125s had a TPS. Removing them means realigning when you put it back. Service manual should have numbers for closed and WOT resistances. Check it.
You can take the security stud out of a torx with a pin punch and hammer.
Bandit. does. everything.
The last post was made 7 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.14 - MySQL Queries: 13 - Page Size: 80.13 Kb
