| Thomas-R |
 Thomas-R L Plate Warrior
 Posted: 21:13 - 04 Dec 2018 Post subject: TDR125 Crank 1991 model |
Hi there
I have bourght a 1991 TDR125 italy, with the wired wheels. But i desperat needs a botom end rebuild, the previus owner ran i with a briken oil line causing major failure. The bad thing is that it seems the crank is discontinued. Con rod might stil be around.
But does any body know if the crank from the later models fits, etc form a 1997 model. The 170cc kit fit everything from 1991 to 2005, so at least the piston pin must be the same.'
cmsnl.com have the 1997 crank dead cheap, but if it does not fit it is just a waste of money.
Hope you guys can help  |
 - Super Spammer
 Posted: 23:21 - 04 Dec 2018 Post subject: Re: TDR125 Crank 1991 model |
| Thomas-R wrote: | Hi there
Just get it rebuilt. It will be the same crank as an early TZR125 and probably the same as later DTR125’s. The Con rods will be the same as a TDR/TZR 250 too and loads of them are still getting rebuilt.
Plenty of parts available if you look harder. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| rs700 |
 rs700 Derestricted Danger
| Thomas-R |
| Thomas-R |
 - Super Spammer
 Posted: 10:04 - 06 Dec 2018 Post subject: |
It should yes, those are exactly the engines I expected to use the same con rod.
You do realise you can't fit this yourself though? You need a lot of specialist tools and experience to press apart and rebuild a crank.
My engine builder has a 10 ton press for a start. Cranks are not bolted together.
Why not leave the specialist to find the correct parts? ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| Thomas-R |
 - Super Spammer
 Posted: 22:05 - 06 Dec 2018 Post subject: |
| Thomas-R wrote: | I know it is not an nuts and bolts job. Might send it to PJME, only thing is the dam shippeing cost from Denmark, and i know that if my mate says he knows what he i dooing then he knows. But defetenetly gona by the parts from PJME, all i one place and save some shipping cost |
Your mate thinks he can rebuild cranks? Best of luck.
Unless he’s a specialist, I wouldn’t bother. It needs some serious tools and equipment to do the job properly and check end float, including like I said, a bloody big press.
This is not a job for your average mechanic. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| Thomas-R |
 Posted: 06:44 - 07 Dec 2018 Post subject: |
He is a mashinist, has rebuild noumurus engines and cranks, and has the tools, and has a serius pasion for bikes and engines.
And regarding the presses, i think we at work have alt least 3 that is more than up to the job.
But i'm not that confident that i will tackel it my own.
I did rebuild my SV1000 engine when i broke 2 gears in the gear box, so not totaly noob in the engine department, just could'nt figure out why the parts for a 1997 TDR125 did not fit min, as it is the year on the title. Just got notice from Yamaha and it is actualy a 1990 model, talk about sitting in the show room for a long time
But i realy apriciate the help  |
 - Super Spammer
 Posted: 10:01 - 07 Dec 2018 Post subject: |
| Thomas-R wrote: | He is a mashinist, has rebuild noumurus engines and cranks, and has the tools, and has a serius pasion for bikes and engines.
Don't think I was putting you down.
I'm a fairly competent machanic too. I raced a TZR250 for 5 years and know those engines inside out. A TZR250 is basically 2 X TDR/TZR/DTR 125 barrels.
I'm just saying that cranks are not a job for an amateur. You need serious experience and specialist tools. If your mate has done them before, fine. I just wanted to stress that this is not something I or the vast majority of mechanics could tackle, it needs a specialist engineering firm who do cranks and have the right equipment.
On some cranks, mainly car ones, the con rods are bolted together at the bottom so can be changed without splitting the crank. On these obviously the crank needs taking apart. Good luck. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| Thomas-R |
| bladerunner |
 bladerunner World Chat Champion
 Posted: 02:14 - 08 Dec 2018 Post subject: |
| mpd72 CPT wrote: | | Thomas-R wrote: | He is a mashinist, has rebuild noumurus engines and cranks, and has the tools, and has a serius pasion for bikes and engines.
On some cranks, mainly car ones, the con rods are bolted together at the bottom so can be changed without splitting the crank. On these obviously the crank needs taking apart. Good luck. |
to be fair for a single 2t crank you need a hand press, a feeler gauge, a copper hammer and a dti clock and V blocks....if your a machinist then this is pretty much bread and butter stuff ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| Sister Sledge |
 Sister Sledge World Chat Champion
 Posted: 10:04 - 08 Dec 2018 Post subject: |
The last post was made 7 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
