Oil changes
Fahniy
PostPosted: 13:19 - 20 Dec 2018    Post subject: Oil changes Reply with quote
Hi, i'm new here. Need good advice.
I bought another Wing - 82 Espencade - previous owner was running synthetic - can I change back to a regular oil https://mechanicguides.com/best-oil-additive/ or will this cause problems.
Thanks!
RhynoCZ
PostPosted: 13:34 - 20 Dec 2018    Post subject: Reply with quote
Yes. The question is why would you.
Synthetic oil is far superior to any mineral oil. Even a semi-synthetic oil is better than pure mineral oil. Why is that? Well, synthetic oil does not leave any residues/deposits inside the engine and doesn't degrade as quickly as mineral oil would.
Now (not your case), if you've been using mineral oil for years and now thinking it's time to switch to synthetic, you must flush the engine first, several times to be sure. That is because mineral oils leave deposits inside the engine and the moment you start using synthetic oil, it will dissolve these deposits and small bits of it will then flow through the engine. In automotive engines, these small bits typically clog up the hydraulic valve tappets = knocking from the head, tappet damage.
TL; DR: You may switch back to mineral oil, however I wouldn't.
Northern Monkey
PostPosted: 13:57 - 20 Dec 2018    Post subject: Reply with quote
^ This is all horse shit. You can mix synthetic and non-synthetic oils. If you couldn't, semi-synthetic wouldn't be a thing.
RhynoCZ
PostPosted: 14:05 - 20 Dec 2018    Post subject: Reply with quote
You do not read what I say. Synthetic oils dissolve all the mineral oil and carbon deposits. If you run a semi-synthetic oil there are no deposits left in the engine. Also, I have seen this several times before, people switching to (semi) synthetic oils for their cars which then developed a loud valve tappets noise, as the tiny holes in them got clogged up by the now freed deposits that the years of mineral oil usage left behind.
PostPosted: 14:08 - 20 Dec 2018    Post subject: Reply with quote
You do not need to flush the engine when switching between mineral oil and synthetic oil
RhynoCZ
PostPosted: 14:10 - 20 Dec 2018    Post subject: Reply with quote
Engine flush costs next to nothing and is advisable for the reasons above. However, this is the internet and people say all kinds of things that they don't mean. Thinking
Robby
Dirty Old Man
PostPosted: 22:24 - 20 Dec 2018    Post subject: Reply with quote
Ignore Rhyno. He means well, but he's talking shite and marketing.
It's a 1982 Wing. All it needs is whatever sort of oil existed in 1982. So a basic mineral multigrade oil.
Use whatever motorcycle-specific oil you're happy with. Anything you can buy today will be equal or superior to anything you could buy in 1982.
The only thing to watch out for is clutch slip that can happen in some circumstances with some modern car oils. That sentence was carefully written to avoid the usual argument. Using a bike-specific oil gets around that problem, and argument.
Islander
PostPosted: 23:26 - 20 Dec 2018    Post subject: Reply with quote
^^This. It'll do no harm to switch to semi-synth or basic mineral oil. No need to flush the old stuff, just run it till it's warm and then drain it and refill with the oil of your choice. By the way, the oil that seems to cause clutch issues is Magnatec.
I run all of my bikes on Comma Eurolite semi-synth. It's cheap enough and doesn't cause any clutch issues Smile
Pjay
PostPosted: 23:46 - 20 Dec 2018    Post subject: Reply with quote
I have no idea what I am talking about, but I have gone from mineral to fully synthetic by just using semi synthetic in between the change.
It made sense to me and the bike was fine for a long time afterwards until it was sold on to the unsuspecting buyer.
struan80 - I'll go first - satisfied tick 1
PostPosted: 02:55 - 21 Dec 2018    Post subject: Reply with quote
You just had to go and start the usual argument.
Razz
temeluchus
PostPosted: 04:24 - 21 Dec 2018    Post subject: Reply with quote
Any cheap walmart etc brand 10/40 car oil will be just fine.
A100man
PostPosted: 08:12 - 21 Dec 2018    Post subject: Reply with quote
Uh oh - oil thread alert!
..damn too late Rolling Eyes
bikenut
PostPosted: 11:57 - 21 Dec 2018    Post subject: gl Reply with quote
see pm, i would use synthetic suitable for a "wet" clutch in this engine, as cost would not be a problem if I had one of these.
nuts about bikes
weasley
PostPosted: 15:16 - 21 Dec 2018    Post subject: Reply with quote
Sorry, I can't resist posting to an oil thread.
There is a grain of truth in the "new oil flushes out deposits" story, but it isn't as clear cut as RhynoCZ makes out. Mineral oils are not guaranteed to create deposits and synthetic oils are not guaranteed not to make them. There's a good chance the engine is already largely 'clean'. Furthermore it is generally a strong detergency that lifts old deposits rather than a different type of base oil - if anything synthetic base oil has a lower tendency to solubilise things.
Short answer to the OP - you can mix oils of mineral, part- or fully- synthetic at will, so long as you realise that mixing them will lead to an end point that isn't exactly one thing or the other. There shouldn't be any problems though*, if used within the required specification requirement and oil change interval.
*caveat: with a bike of that age and unknown history, there are no guarantees.
bikenut
PostPosted: 15:30 - 21 Dec 2018    Post subject: oil Reply with quote
Some bikers are very fond of using Shell Rotela, which is a high detergent oil mainly intended for diesel engine?
nuts about bikes
weasley
PostPosted: 15:51 - 21 Dec 2018    Post subject: Re: oil Reply with quote
This is a US thing. They seem to like to use Rotella in everything. Rotella is a US brand, in Europe it is Shell Rimula but that's just the brand family name - you'd need to choose one of the numerous variants.
There's no need for bikes to have high detergent oils, you're better off with an oil at least desigend for a petrol engine, if not specifically a bike engine.
Pigeon
PostPosted: 22:49 - 21 Dec 2018    Post subject: Re: oil Reply with quote
Is there any truth that an engine oil can have too high an amount of detergent?
The internet of lies....the internet, told me that a very high detergent level can remove the sacrificial layer of zinc/boron designed to protect surfaces from impact.
I've noticed that Motorbike oils tend to have around 2700-3200ppm of Calcium as a detergent. BUT they also have 1300 - 2500 ppm of zinc / boron as a protective / sacrificial layer.
Whereas car engine oils (the API SN) tend to have 2600-2900ppm Calcium but only 1000ppm zinc.
I don't know if its "simply" that car oils tend to lead development, so use the newer API specs and so need to have a lower zinc content as per the spec.
And if bike oils can't be bothered to move to newer specs because the money isnt there. Or if the older spec oils which allow more zinc are in fact better suited to motorbikes.
Or none of the above Smile
EDIT:
I've used a 50/50 mix of Total Quartz 9000 5w40 and 10w50 on 1 bike for 25k miles and another 2 bikes for 3k miles each.
About £4.60 a litre.
The last post was made 7 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 97.54 Kb
