| Spidey |
 Spidey L Plate Warrior
 Posted: 01:51 - 05 Mar 2019 Post subject: Honda Ps 125i - "died" and won't start |
Hi guys!
I'm having some troubles with my Ps 125i
I had about 50mph, the engine started to make a ...gurgling sound, and lost all acceleration. When bike stopped, engine stopped, then gone.
If I try to start it, it makes a sound, but ... smoother. Dunno how to explain...
Nothing on the exhaust, can't feel an actual compression of the engine.
Took the spark out, burned it, cleaned it with metal brush, no change.
My next step will be to check the gas pump tomorrow, if not, maybe injector?
Any advice? Thoughts?
All help is appreciated
Thank you! ____________________ The quieter you become, the more you are able to hear. |
| Robby |
 Robby Dirty Old Man
| davebike |
 davebike World Chat Champion
 Posted: 09:13 - 05 Mar 2019 Post subject: |
Also check oil ! Low oil kills more engines than anything else! ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| bikenut |
 bikenut World Chat Champion
| Spidey |
 Posted: 13:32 - 05 Mar 2019 Post subject: |
Hi guys! Thank you for your replies!
So, I did about 1900-2000 miles, I have it for 2 months. Previous owner says oil was changed about 200 miles before, so 2200 miles on the oil shouldn't be too much, but I had a doubt too, so I will have a look today
(he's a close friend, wouldn't lie about it)
3 miles before the engine stopped I had about half tank of gas, so Ive added another 2.5L (full).
The spark plug was fine. To be honest, haven't checked before cleaning it, but after was fine and still no difference on the engine
I ...HAD some knowledge about it, changed the piston, segments on few scooters, had a Kawasaki zx4r...
But there's like 5 years since I've touched a bike/scooter, and probably 8-10 years from my last repair
Im trying to remember, HAHA
Compression: Checked with finger when I cleaned the spark plug, and .. nope, didn't push the finger. Very low. But when the engine was running, the scooter had a lot of power, front suspension was lifting when accelerating, even 3-4 miles before - Do segments wear off so easily?
Yes, it's electric start only.
Battery also seemed fine, never had issues, easy start in the morning. OK, it was spinning a bit more in the morning, probably 2-3 seconds in cold mornings before engine starts, but that should be normal
I'll start working on it in about 2 hours. Will check the oil, spark plug and compression (again - was very tired on first attempt)
Would the engine run for 3 miles if gas was mixed or poor quality? I believe its mixing way faster with the previous half ____________________ The quieter you become, the more you are able to hear. |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 13:43 - 05 Mar 2019 Post subject: |
over 2200 miles since last oil change......engine is toast.....
Oil should be changwed every 800 - 1000 miles
How do I know?
I have worked on like 30 of them! ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| cb1rocket |
| doggone |
 doggone World Chat Champion
The last post was made 6 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
