YBR 125 starting issues fault code 19
flabdog
PostPosted: 17:46 - 07 Mar 2019    Post subject: YBR 125 starting issues fault code 19 Reply with quote
Hi all 16 plate ybr 125 causing a bad head at the mo. Put the key in the ignition switch to on and half the time nothing. Switching between on and off and eventually the dash lights up ready to go. The bike now and again just turns over and wont start. I have noticed the engine light blinks once followed by 9 short blinks. Looking at other posts I am guessing this is error code 19. Does this sound like my ignition barrel is shot causing the error code ?
Meatybeaty
PostPosted: 17:56 - 07 Mar 2019    Post subject: Reply with quote
Check Black/White wire from Ignition switch to ECM (code 19)
flabdog
PostPosted: 17:57 - 07 Mar 2019    Post subject: Reply with quote
Looking for a break in the wire I take it ?
Meatybeaty
PostPosted: 18:30 - 07 Mar 2019    Post subject: Reply with quote
Yes matey , betting on ignition end ,loose connection
flabdog
PostPosted: 18:35 - 07 Mar 2019    Post subject: Reply with quote
Yes matey , betting on ignition end ,loose connection[/quote]
Thumbs Up thanks for that Thumbs Up
flabdog
PostPosted: 19:30 - 08 Mar 2019    Post subject: Reply with quote
Checked all connections and all seems fine. Fitted a new barrel and now it powers up but shows no neutral light on the dash and is dead when the starter button is pressed.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:23 - 08 Mar 2019    Post subject: Reply with quote
So you are following the 'randomly replacing bits to see if it works' method of diagnosis.
Can I suggest that you replace the fairings on my bike next in the hopes it fixes yours?
Triumph Sprint ST 1050
jaffa90
PostPosted: 23:29 - 08 Mar 2019    Post subject: Reply with quote
"""Checked all connections and all seems fine."""
How are you doing this?
I suggest you get a multi/meter to test the original switch and connection to the fuse box when switching on with the battery disconnected so not to upset the brain. (e.c.u.)
Q, has somebody tried to steal this bike at any time?
Meatybeaty
PostPosted: 08:20 - 09 Mar 2019    Post subject: Reply with quote
Take the Light blue wire off the Neutral switch and earth it , check that the neutral light comes on
flabdog
PostPosted: 18:38 - 09 Mar 2019    Post subject: Reply with quote
As a newbie thought id try the barrel as a lot of other forum posters have done the same with success. Wont bother changing any farings ill just follow sensible and helpful advice ta. Theres always one Neutral
flabdog
PostPosted: 18:40 - 09 Mar 2019    Post subject: Reply with quote
As far as I know there has been no attempted theft of the bike previously. Thanks for the advice though Ill get me multimeter out Thumbs Up
flabdog
Will do that. Thanks again Thumbs Up
Sparky700
PostPosted: 20:43 - 20 Mar 2019    Post subject: Reply with quote
I'm thinking of forming an emotional support group called code 19!
With code 19 it will turn over but not spark
I too have had the neutral light on and then off. It looks like once the ecu gets code 19 in it's head then bugger all will change it's mind
Sparky700
PostPosted: 20:33 - 08 Jun 2019    Post subject: Reply with quote
Did you sort, mines still not sparking!
WD Forte
PostPosted: 15:56 - 09 Jun 2019    Post subject: Reply with quote
We seem to get a lot of that error 19
https://www.bikechatforums.com/viewtopic.php?t=327690
bikers smell of wee
The last post was made 6 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.26 - MySQL Queries: 13 - Page Size: 81.31 Kb
