Cracked, and bloody knuckles
thx1138
PostPosted: 00:28 - 10 Mar 2019    Post subject: Cracked, and bloody knuckles Reply with quote
Backs of my hands and my knuckles are sore, bit swollen, rough skin calluses and bleeding a little. Think it's down to being outdoors a lot.
What do?
Hand cream? Embarassed Sick Thumbs Down
Probably going to have to be. Sad so recommendations?
PostPosted: 00:43 - 10 Mar 2019    Post subject: Reply with quote
Hand barrier cream...the pink stuff is what used until I became a man.
Riejufixing
PostPosted: 00:52 - 10 Mar 2019    Post subject: Re: Cracked, and bloody knuckles Reply with quote
What do?
Yes some sort of hand cream, preferably with lanolin in it. If you're outdoors a lot, applying something then would be a good preventative treatment. Vaseline, or even lard.
Kawasaki Jimbo
PostPosted: 00:59 - 10 Mar 2019    Post subject: Reply with quote
Norwegian Formula, as used by rufty tufty trawlermen and Vikings.
Also gloves.
PostPosted: 06:29 - 10 Mar 2019    Post subject: Reply with quote
Broken skin - E45
Dry, itchy skin - Hydrocortizone
E45 sorts most of my skin complaints, mostly dry, sore hands from wire sawing cutting.
stevo as b4
PostPosted: 07:30 - 10 Mar 2019    Post subject: Reply with quote
Welcome to working outside all winter bashing your hands on everything.
Manning up gets you so far, but some of those creams like Pete said or the Norwegian stuff really do help. Its fine to ignore at first but when you can't work in gloves due to detail fine work, and are getting solvents like alcohol and white spirit on your hands it stings a touch and probably isn't that good for you.
Also coming home and touching anything clean like towels or letters and getting blood stains on everything doesn't make for a smooth home life.
Try to wear clean dry gloves outside in low temperatures and use a hand cream if your paws get into a state or just to
prevent them doing so as much as possible.
Sister Sledge
PostPosted: 08:28 - 10 Mar 2019    Post subject: Reply with quote
Just to add: Wet cement and concrete will destroy your hands too.
All of the above creams work.
CCM 404 DS
waffles
PostPosted: 09:56 - 10 Mar 2019    Post subject: Reply with quote
Also gloves.
I second the Norweigan stuff, works wonders.
defblade
PostPosted: 10:15 - 10 Mar 2019    Post subject: Reply with quote
Also gloves.
Thirded!
The only hand cream that actually gains you manpoints Wink
Islander
PostPosted: 12:27 - 10 Mar 2019    Post subject: Reply with quote
Either the Norwegian neutrogena stuff or O'Keefes. Both work really really well. Thumbs Up
Jewlio Rides Again LLB
PostPosted: 12:41 - 10 Mar 2019    Post subject: Reply with quote
O Keefe's, I use it because weight lifting.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
Andy_Pagin
PostPosted: 18:27 - 10 Mar 2019    Post subject: Reply with quote
I find any glycerin based stuff works well, the Norwegian Neutrogena stuff has the joint advantages of being perfume free and an association with a bunch of hard bastards (deep sea fishermen) and therefore in no way effeminent.
Riejufixing
PostPosted: 10:31 - 11 Mar 2019    Post subject: Reply with quote
Here you are, if you order withing 1/2 an hour you get 50% off which makes the £3.95 postage nicer.
https://www.pipingrock.com/skin-care/pure-lanolin-cream-7-fl-oz-207-ml-jar-39243?prd=153ba859&utm_source=criteo&utm_medium=acquisition&utm_campaign=dynamic
What does Lanolin Cream do?
Now you can support your skin’s health and help to protect it from the environment naturally with Piping Rock’s Pure Liquid Cream! A luxurious emollient, our lanolin cream supplies deep moisture to dry, chapped skin. It helps to naturally protect your skin from the elements it comes into contact with every day, such as wind, sun and weather. Promote your skin’s natural beauty from head to toe when you add our Pure Lanolin Cream to your daily routine! This non-greasy formula is suitable to wear beneath sunscreen and make-up.
Go on, protect your skin, you know you want to! Lay off the make up though (perhaps Laughing Wink )....
Sister Sledge
PostPosted: 13:30 - 11 Mar 2019    Post subject: Reply with quote
Lanolin: Squeezed from the sebaceous glands of sheep.
I suppose if it works then use it!
CCM 404 DS
Riejufixing
PostPosted: 14:08 - 11 Mar 2019    Post subject: Reply with quote
It's actually from the wool; lanolin is secreted and coats the wool to make it waterproof and weather-resistant. If you shear sheep or handle "raw" wool, your skin will be supple. Unsure how they get it off the wool. It's good stuff.
A100man
PostPosted: 15:27 - 11 Mar 2019    Post subject: Reply with quote
mpd72 CPT wrote:
https://www.ordinary-joe-muscle-building.com/images/strength-training-diary.jpg
Fine figure of a man - a near reflection of my own magnificent physique.
hellkat
PostPosted: 20:41 - 11 Mar 2019    Post subject: Reply with quote
... from the sebaceous glands ... duh!
Until reasonably recently they used to gently boil it with a bit of Sunlight soap to get off all the dirt, sheepysweat and dags, then the lanolin would float to the top, take out the wool and squeeze it really "dry" ... and then they just simmer the water until its reduced down, what's left is the lanolin. I think modern technology is to use a centrifuge maybe ... Thinking
Really no idea about chemical extraction (if such a thing exists, no doubt it does in this day and age ... )
Sister Sledge
PostPosted: 21:26 - 11 Mar 2019    Post subject: Reply with quote
Nah - they squeeze sheep.
Ducks have an oil gland. Has that stuff been turned into cream too?
CCM 404 DS
PostPosted: 22:58 - 11 Mar 2019    Post subject: Reply with quote
It's a by product from when they make the tape.
Fisty
PostPosted: 16:56 - 12 Mar 2019    Post subject: Reply with quote
https://cdn.aws.toolstation.com/images/141020-UK/800/94125.jpg
This stuff is wonderful. We get it supplied at work and it is magic!
Fatter and faster than Fret
PostPosted: 18:46 - 13 Mar 2019    Post subject: Reply with quote
I have to pay a lot of attention to my hand skin due to working both outside AND in a medical environment where hands need to be clean.
Stop using normal soap, use a pH balanced soap. I use one called baktolin pure.
Use rubber gloves if you do the dishes, washing up liquid is horrible to yuor hands. Use nitrile gloves if you are working on your motorbike because engine oil/brake dust etc is also nasty. The more you get exposed to it, the more likely you are to have a reaction. I've HAD to start wearing gloves because it triggers dermatitis now. Black nitrile gloves are really tough.
Only WASH your hands if they are visibly dirty and even then just wash them in water if you can get away with it. If they are really mucky, you'll have to use that pH balanced soap.
Don't rub your hands dry, pat them dry.
If you need your hands to be CLEAN (eg before eating etc) but they aren't visibly dirty. Use an alcohol handrub. Keep rubbing it until they are dry, don't wipe it off on your trousers/a towel. That way any oils it strips out of your pores are rubbed back in again
I also use Norwegian formula hand cream. I find It works best if the skin is slightly damp (so if you've washed and patted dry your hands, that's a good time to put the handcream on). I have multiple tubes of it about the place (Bathroom, bedroom, kitchen car, work).
If they get really bad, slather them in aqueous cream and put a set of thin cotton gloves on before you go to sleep (pharmacists sell cotton gloves for this exact purpose).
The last post was made 7 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 124.76 Kb
