Anyone using these?
Ammoman
PostPosted: 19:59 - 06 Apr 2019    Post subject: Anyone using these? Reply with quote
Anyone using these and can review. Thanks
https://www.youtube.com/watch?v=MotEK4jYvvQ&t=7s
2013 ZZR1400 & Honda CG125 1986..
PostPosted: 20:04 - 06 Apr 2019    Post subject: Reply with quote
Please be a wiper...
Ah crap. Crying or Very sad It's a Michelin Tyre Pressure Monitoring System.
https://fit2gotpms.com/product/michelin-tpms-bike/
Kawasaki Jimbo
PostPosted: 20:56 - 06 Apr 2019    Post subject: Reply with quote
When riding I can feel when the tyre pressures are significantly low, so no. I think I've gone through the gadget phase and now appreciate simplicity. Also, the previous owner of the R1 fitted anodised valve caps which were noteably heavy and may have been the cause of a split in the base of the valve stem, causing a slow leak. It's one reason I avoid 90 valve stem fittings.
kramdra
PostPosted: 21:43 - 06 Apr 2019    Post subject: Reply with quote
I want a proper bike TPMS and looked at the options 6 months ago. This requires removing the tire and fitting a new stem with the sensor on the inside. I could not find any that fit normal jap bike wheels - bmw are different size valve hole.
The most common are shitty valve cap types. They hold the valve open, also add quite a bit of weight - best with a metal bolted stem not a rubber push fit. This seems to be another valve cap type and would be very sceptical if it is any better than the chinese offerings.
thx1138
PostPosted: 22:06 - 06 Apr 2019    Post subject: Reply with quote
No I never check my tyre pressure as I have mousses
PostPosted: 22:19 - 06 Apr 2019    Post subject: Reply with quote
We Found 39 Clips With "I Have Mousses"
Sister Sledge
PostPosted: 22:30 - 06 Apr 2019    Post subject: Reply with quote
Mousses. Am I missing something here? Tyre foam??
I just see those sensors as extra weight, cost and complexity.
Check before riding, possibly during (if you suspect) and after.
CCM 404 DS
flearider
PostPosted: 22:38 - 06 Apr 2019    Post subject: Reply with quote
check once a week .. how is that a problem ?
pull into garage put 50p into air .. check tires .. then fill up ?
Courier265
PostPosted: 23:28 - 06 Apr 2019    Post subject: Reply with quote
I check my tyres DAILY... don't need a fancy gizmo.
CBF500 - 2 x Inazuma 250
WD Forte
PostPosted: 23:46 - 06 Apr 2019    Post subject: Reply with quote
Real men kick their tyres
bikers smell of wee
Shaft
PostPosted: 00:47 - 07 Apr 2019    Post subject: Reply with quote
Yep, then I check the pressures when I think the handling doesn't feel right, so probably once a month.
Potholes and speed humps don't do much for maintaining tyre pressure, but I don't need a gadget to tell me that, just the seat of my pants.
PostPosted: 01:20 - 07 Apr 2019    Post subject: Reply with quote
WD Forte wrote:
Real men
https://i.imgur.com/QrBh6Yb.png
MCN
PostPosted: 02:41 - 07 Apr 2019    Post subject: Reply with quote
I have tpms on one bike but not on the other.
I like on the one bike but it's not really something I miss on the other.
Heat grips are better value. 😂
Real Men use Heated Grips ya cunts...
Easy-X
PostPosted: 02:49 - 07 Apr 2019    Post subject: Reply with quote
It's selling to the OCD generation... not a great target audience when it comes to bikes TBH!
PostPosted: 10:54 - 07 Apr 2019    Post subject: Reply with quote
My Triumph has them. It also comes with a bill of £150 (+ wheel/tyre removal) every 3or 4 years when the batteries run flat.
That saying I do like having them as you can have the pressures on the dash board or just rely on warning light when they drop about 5 psi.
andym
PostPosted: 12:08 - 07 Apr 2019    Post subject: Reply with quote
I'm verging on OCD with my tyre pressures Rolling Eyes
I leave it up to the fitter to put the correct pressure in when I buy a new tyre, although maybe I will start checking them regularly because I'm fed up of being killed every day because I don't check them
MCN
PostPosted: 15:44 - 07 Apr 2019    Post subject: Reply with quote
You can dig out the old button cell and ram a new cell in.
Use araldite or better to hold the new cell in. Push the cell down with a paper clip until the epoxy is set.
They use those bastirt cells that have a contact spot welded to it.
Just snip that off.
I have replaced one sensor on the rear due to the valve stem corroding.
I slabbered some ACF-50 on the new sensor when I replaced it.
I haven't used the bike for about 10 months but the last time I was on it the TPMS worked fine and the beast is 8yrs old now 20K miles.
iooi
PostPosted: 16:01 - 07 Apr 2019    Post subject: Reply with quote
Nice to see bikers still getting ripped off. Cars run for a lot longer...
thx1138
PostPosted: 18:05 - 07 Apr 2019    Post subject: Reply with quote
not foam as in a spray, but a solid inner tube that doesn't require air, and can't puncture
Sister Sledge
PostPosted: 18:15 - 07 Apr 2019    Post subject: Reply with quote
Learn something new every day. Cheers!
CCM 404 DS
MCN
PostPosted: 19:44 - 07 Apr 2019    Post subject: Reply with quote
https://youtu.be/Jeu72y0f4Kc
Nobby the Bastard
Harley Gaydar
PostPosted: 19:53 - 07 Apr 2019    Post subject: Reply with quote
There's a moose loose about this hooose...
(Edit, Saw mcn's link after posting.....)
Triumph Sprint ST 1050
The last post was made 7 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 113.15 Kb
