Frame damage, MOT failure or not, fix?
Riejufixing
PostPosted: 20:12 - 25 Apr 2019    Post subject: Frame damage, MOT failure or not, fix? Reply with quote
Another wreck, this one has some small frame damage, not disclosed, so not written off.
When whoever did whatever, the steering was turned hard right, breaking off the lock stop on the bottom yoke (yet another one!), but worse putting a small dent in the outside apex of the offside triangular cross-section top frame tube, as if someone had pushed the ball of their thumb into it by about 1mm.
Unfortunately, the dent is right in the middle of the VIN sticker!
A full frame where the VIN sticker can be seen as well as the frame tube arrangement is pictured here: https://www.ebay.co.uk/itm/RIEJU-RS3-125-FULL-FRAME-WITH-V5-REG-PLATE/283235065597?hash=item41f2201efd:g:bxIAAOSwN3lco05-
Is this an MOT failure?
It would be possible to:
1) Remove the sticker (VIN is also stamped into steering head), fill, spray.
2) Make a small hole in the flattish back of the triangular tube, insert a thin drift, tap the dent out.
Perhaps there are other possibilities.
Close-up pics:
PostPosted: 20:57 - 25 Apr 2019    Post subject: Reply with quote
Just make out like the plate has partially rubbed off by a hose or something. I'd take it for a test and see what's what. I can't see it being an issue personally but I'm not an MOT tester.
Bloggsy
PostPosted: 21:11 - 25 Apr 2019    Post subject: Reply with quote
as the vin number can still be read I cant see a problem
If It Aint broke Don't Fix It
Riejufixing
PostPosted: 22:24 - 25 Apr 2019    Post subject: Reply with quote
It's the slight dent that worries me. The sticker I think could go, the VIN is stamped on the side of the steering-head.
PostPosted: 22:34 - 25 Apr 2019    Post subject: Reply with quote
There's no apparent structural integrity issue in the pic I can't see a tester being bothered at all by it.
Sister Sledge
PostPosted: 07:17 - 26 Apr 2019    Post subject: Reply with quote
I'm not an expert but personally I wouldn't think too far into this one. At first I was expecting a snapped frame member!
Is there a wire or even a fake piece of wiring loom that could be routed over that section?
Binning the sticker - They can be remade.
CCM 404 DS
PostPosted: 10:01 - 26 Apr 2019    Post subject: Reply with quote
I agree with the above. They WILL fail it on a broken lock-stop though.
PostPosted: 10:20 - 26 Apr 2019    Post subject: Reply with quote
The lock stop is on the yoke, so a new yoke should be grand.
Riejufixing
PostPosted: 11:15 - 26 Apr 2019    Post subject: Reply with quote
The bottom yoke's a bit of a side-issue, really; however! I bought a good intact used one (hen's teeth!) a little while ago for £30 including a decent inner ring + rollers still attached, but look at this if you can bear it:
https://www.ebay.co.uk/itm/RIEJU-RS3-125-2011-2012-2013-2014-2015-BOTTOM-YOKE-USED-MOTORCYCLE-PARTS/192887978876?hash=item2ce904fb7c:g:N2AAAOSwz7NcsJkH
Mouseover both pics for the full horror. I only include that for entertainment. I am not going to buy the poxy thing!!
The last post was made 7 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.78 - MySQL Queries: 13 - Page Size: 62.35 Kb
