| Jamesthebutle... |
 Jamesthebutle... Two Stroke Sniffer
 Posted: 09:17 - 26 Apr 2019 Post subject: Need help please |
Im going to cut a long story short Smile My wife bought me a semi used bike with 9000km as a gift. It was dropped off at my home by seller qnd his wife. Just for the record; my wife knows nothing about bikes. She really just wanted to surprise me. Problem is bike has some issues and I would like to hear and get some info and advice before doing anything to it.
Its a KSR Grs 125cc 2017 QJ157FMI-2B.
From what Ive read this is a chineese copy of the Suzuki GS125 engine
These are the problems:
1st gear+2nd gear bike pulls and rides ok. ( at least i think it feels ok for a 125cc )
3rd gear gets to about 61/67 km/h but it takes long to reach that speed depending on head wind. Road is a flat. I would think that this is very little.
4th gear top speed +- 71/76 km/h. Really feels like its lacking power and struggles to keep that speed.
5th gear : forget about it. Speed drops down queit a bit:
This is the speedometer reading of speed in km/h
From what I have read , bike should do around 95 km/h. I know its a small bike, im a heavy bloke (103kg pure beer belly::: i mean pure muscle) Smile , but surely it should reach 90 km/h no problem. I have read some ppl get 100/110 km/h out of this bike.
I can change gears no problem, but I have also noticed that cluch feels like its worn. If you are riding and pull clutch in and drop it quickly, you should feel that jerk of engagment, but it almost feels like a slip disk clutch (hope im making sense ). It takes long for clutch to engage again and its on the end of the lever;
Could that be the problem of lack of speed and power?
I checked the air filter today. Its a new one.
I checked spark plug and compared to chart and its burning ok. Looks new. It is correct spark plug according to manual.
I checked the chain tention and i tightened it to spec as it was very loose.
Engine turns and sounds healthy. If I open choke with motor warm, it cuts out engine, which is normal.
Saturday im going to open up to have a look at clutch for signs of wear and tear.
Hope Ive been able to explain well enough. Any questions feel free to ask.
*** UPDATE ***
26/04/2019 : 11h26
Just a small update. Ive taken apart the bike to reach the carb to clean it. There is a small black box that goes to engine and main air filter intake pipe. I noticed it had water in it. It has a little tap connected to it. I opened it up and drained water. Guess it is not supposed to be with water. After lunch I will be cleaning carb.
26/04/2019 : 13h50
Cleaned carburator out. Did have some brownish like dirt water markings in float cup. Assembled it back together and took it for a spin. Little better but still 4th in the 76/78 km/h range.
26/04/2019 : 14h55
Took out filter from inside filter box. Took it for a spin and it did have peak moments of 85 km/h. So more air intake = little more speed/power
26/04/2019 : 17h29
Had time to have a look at clutch plates. I have compared it to new ones online and it looks pretty much ok still to me. What do you guys think? If it is ok, then it rules out the possibility of being the cause of bike being so slow. I watched a vid on Youtube today on somebody doing a review of this bike model, and it clearly shows him easily getting to 95/103km/h with stock bike.
https://i.postimg.cc/Qd55Yvk7/clutch.jpg
28/04/2019 : 15h32
Inbetween yesterday and today I decided to change oil/filter. Used recomended oil.
Then I decided to check the valves and reset them. I tried different combinations with feeler gauge and set Exhaust/Intake from 0.03mm to 0.08mm. Each time I set them would start the bike and listen. 0.06mm to 0.08mm I would get ticking sound. 0.05mm in cold no ticking; but with engine hot, very slight ticking sound. Let it cool down again and then set it at 0.04mm. Is working fine now.
| toby1 |
 toby1 Scooby Slapper
 Posted: 09:35 - 26 Apr 2019 Post subject: |
It's a 125...........  |
| Jamesthebutle... |
| Minty |
 Minty World Chat Champion
| MCN |
 MCN Super Spammer
| MCN |
 MCN Super Spammer
| Jamesthebutle... |
| MCN |
 MCN Super Spammer
| Jamesthebutle... |
| Riejufixing |
| Jamesthebutle... |
| Riejufixing |
| Jamesthebutle... |
| toby1 |
| MCN |
 MCN Super Spammer
| Robby |
 Robby Dirty Old Man
| Jamesthebutle... |
| MCN |
 MCN Super Spammer
| WD Forte |
 WD Forte World Chat Champion
 Posted: 17:00 - 26 Apr 2019 Post subject: |
Had to translate the speed to real money
as our new friend is in Belgium
76 km/h = 47 mph
100 km/h = 62 mph
What colour is the plug?
this can help tell you if its fuelling properly
Black/sooty over fuelling, white running lean sort of thing
Is there play in the clutch lever?
There should always be a few mm in lever movement before it takes up tension
on the cable, if it's too tight it can cause the clutch to slip
My lads have had a few chinese bikes and while 125s aren't that exciting, you should be
able to get 60 mph 100 km/h out of it assuming it isnt worn out
This the ksrgrs and a Bennets review said
"During the road test the GRS behaved impeccably, despite still needing to be run in the bike would
hit 60mph ( 100km/h) quite easily, so expect to see a bit more once loosened up"
https://www.bennetts.co.uk/-/media/import/5719_images/660_img_8158.ashx?la=en&hash=7EB0052632647977BA08664C15A4AB3E1854273D ____________________ bikers smell of wee |
| Jamesthebutle... |
 Posted: 18:59 - 26 Apr 2019 Post subject: |
| WD Forte wrote: | Had to translate the speed to real money
76 km/h = 47 mph
100 km/h = 62 mph
https://www.bennetts.co.uk/-/media/import/5719_images/660_img_8158.ashx?la=en&hash=7EB0052632647977BA08664C15A4AB3E1854273D |
Hi WD Forte. Sorry for not posting in mph. Could have easily done that.
The spark plug looks ok to me. What do you think?
Im running out of ideas right now as I thought clutch could be worn out and for that reason not gaining speed. But clutch looks ok too.
1st + 2nd really pull well, but when you put in 3rd it really struggles to reach 47 mph. 4th just maintains the 45/47 mph
And yes from what I have read and seen, it should easily do 62 mph
https://i.postimg.cc/Gp7PwGVw/spark-plug.jpg |
| Jamesthebutle... |
| Jamesthebutle... |
| wr6133 |
 wr6133 World Chat Champion
| Jamesthebutle... |
| Sister Sledge |
The last post was made 7 years, 59 days ago. Instead of replying here, would creating a new thread be more useful? |
