Are braided brakes worth it?
EazyDuz
PostPosted: 11:13 - 06 May 2019    Post subject: Are braided brakes worth it? Reply with quote
Recently did a brake fluid change as well as took the caliper off, thoroughly cleaned and lubed the sliders etc. Brakes felt better but they're not brilliant.
The brake line is OEM rubber, now 14 years old (Unless changed before my ownership but no record of it). No signs of cracks or any weathering.
Would I notice a difference changing to braided, or would that money be better off spent on some 'sports' pads instead? I've read mixed opinions, with some arguing that braided lines only feel better because you're forced to change the fluid at the same time, which is the reason for the better performance.
Easy-X
PostPosted: 13:36 - 06 May 2019    Post subject: Reply with quote
There's a faint possibility that, although the pipe looks good i.e. no cracking, that it's weak in some spot. As you squeeze the brake lever there's a fair bit of pressure in the fluid and this weak spot might "balloon" slightly.
At 14 years it's probably 8 or 9 years past when you should have changed them anyway!
Confusion
PostPosted: 14:00 - 06 May 2019    Post subject: Re: Are braided brakes worth it? Reply with quote
What kind of bike is it? Tokico calipers by any chance?
Most service manuals advise changing brake and fuel lines
every four years. I changed mine at 16 years Embarassed
Code:
Would I notice a difference changing to braided...
Probably not. Changing my old OEM rubber brake lines
for new HEL braided lines made no measurable difference
to my brakes.
...or would that money be better off spent on some 'sports' pads instead?
Sports or racing pads/tyres might not be the best choice for
normal road use. They only work well within the optimum temperature
range.
At the very least, you can expect good quality braided lines to
be:
As good as the original rubber lines.
Cheaper to buy
Last longer. Some have a 10 year or "lifetime" guarantee.
As you say, new lines often come with new caliper seals
and fresh fluid.
Bandit 650SA, ZZ-R1100
Fisty
PostPosted: 14:27 - 06 May 2019    Post subject: Re: Are braided brakes worth it? Reply with quote
EazyDuz wrote:
Are braided brakes worth it?.
Yes.
/thread.
Fatter and faster than Fret
WD Forte
PostPosted: 15:05 - 06 May 2019    Post subject: Reply with quote
Its bit like chains and weakest links
If your master cylinder seals are leaky or its bore worn and scored, then the efforts from your grubby wee fist
wont be efficiently translated to pressure on the disc/s
Even slight ballooning of old rubber lines will waste pressure too so braided hoses
or good new rubber ones will help.
If they're really knackered you can feel them swell as you apply the brake.
Sticky corroded old pistons will resist movement.
The slightest amount of air trapped in the system will waste efforts too.
Crap disc pads wont help either, but expensive pads on a poor system are waste of time and money
where decent affordable pads on a good sytem will be better.
Badly worn and grooved discs will reduce contact area
what fookin bike?
bikers smell of wee
andym
PostPosted: 17:08 - 06 May 2019    Post subject: Re: Are braided brakes worth it? Reply with quote
Fisty wrote:
Yes.
/thread.
I recently changed mine and haven't noticed any difference.... so I'd say no they aren't worth it (17 year old ninja)
Kawasaki Jimbo
PostPosted: 17:55 - 06 May 2019    Post subject: Reply with quote
I was disappointed when I changed mine after a similar amount of time, done as part of a general bike refurb. In hindsight, unless the old hose was visibly ballooning I don't think I'd notice a difference.
OE is no longer available and I'd be hard-pressed to find a non-braided aftermarket kit unless I wanted to make a set from scratch.
Steel braid looks nice but is probably more abrasive if it rubs on mudguards, and you can't inspect the rubber for damage.
OE hose is reinforced internally with nylon. I don't know or sure but I would guess that aftermarket suppliers use cheaper rubber hose and sheath it in stainless steel for the same effect.
Derek Noakes This post is not being displayed because the poster is banned. Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:05 - 06 May 2019    Post subject: Reply with quote
Some users find braided pipes to give a wooden feel (attributable to lack of flex on the pipesl but I've never noticed a difference. Newer is better in any case.
Triumph Sprint ST 1050
Teflon-Mike
tl;dr
PostPosted: 21:36 - 07 May 2019    Post subject: Reply with quote
This is a perenial; but so many that advocate braided line over ~OE rubber, have a skew perception, having swapped out perished crap OE lines for nice new braided... how much of the 'better' is the fact that the lines are nylon and coated in shower braid, and how much 'just' cos they is new!
Having done a back-to-back swap... promted by waking up one morning, climbing on the bike and thinking "That's odd?!" when the brake lever came back to the grip, and discovering 'some-one' had half inched my brake hose.... even more curiously, they removed the brake hose, and put back not just the banjo-bolts on the caliper and master cylinder... they put the copper washers back too! A contientiouse tea-leaf that!
But, fitting brand new Braided, after pretty much brand new OE rubber... yes, there is a pretty big difference; B-U-T, a lot of it is in the sharpness of the brake, doesn't necesserily make it any more powerful.. and would that be a good thing anyway? If it lock the wheel, it will lock the wheel... and that's not usually a good thing, but book-ends the power of the brake you might use. The difference is mainly in the 'feel' and the take up not being so wooly feeling like the effect is more imediete and doing something faster.
For where your at... and I assume this be on a cruiser... where you don't necessarily need or want, direct nerve ending response or feel, the change would probably be no bad thing, if only 'cos it would beg a brake flush and overhaul, and a new hose, of either kind.
A-n-d after-market braided lines are often cheaper than OEM rubber... so pays your money and takes your chances.
ThatDippyTwat
PostPosted: 06:36 - 08 May 2019    Post subject: Reply with quote
Yes.
BUT...
You really need to rebuild your master cylinder at the same time. No point getting rid of lines that expand etc it your master can't build pressure properly.
trevor saxe-coburg-gotha
PostPosted: 07:52 - 08 May 2019    Post subject: Reply with quote
I recently replaced the lines on my v-reg zx9r w/ Hel braideds and so have had cause to reflect on this question.
The difference isn't night and day - that's the first thing I'd say. Secondly, it may be that a decent bleed (by a mechanic who's got decent equipment to do this) is the main reason for the improvement I'm feeling.
Thirdly, I'd estimate that the improvement in the front is between 5 and 10%, and the rear around 20% (somewhat marginal gains - but in the context of an important function).Suffice to say, I wish it was the other way around!
This is w/ the original 6 pot tokicos still installed. I recently bought a pair of newly refurb'd nissin 4 pots for £160 - and am hoping these will provide stronger stopping power at the front.
I don't want to think how far into this bike's brakes I am, quids-wise. I already replaced 24 seals and twelve pistons on the original toks. That was a dear do.
The irony is I don't really have an issue with the bike's brakes as such - because I don't actually use them that much. Or try not to. I mean, I only ride on the road. If I find myself braking hard it's invariably because I've cocked up. However, when I compare the bike's brakes to almost every other bike I've owned, I know they can and should be better.
redeem ouzzer
PostPosted: 08:14 - 08 May 2019    Post subject: Reply with quote
New rubber hoses are better than braided PTFE in my opinion, but OEM hoses cost a bloody fortune. Also most twin calliper setups use a splitter in standard form so changing to braided is a good excuse to ditch the splitter and save a bit of weight.
Be a REAL MAN!
RhynoCZ
PostPosted: 08:27 - 08 May 2019    Post subject: Re: Are braided brakes worth it? Reply with quote
Fisty wrote:
Yes.
/thread.
Not really, however they are significantly cheaper than the OEM rubber brake hoses.
trevor saxe-coburg-gotha wrote:
Tokico 6 pots
I wasn't lucky with these. I swapped them for a standard set of Nissin 4 pots, a direct swap, I must say, and haven't had to touch the brakes ever since. No more cleaning every year, no more expensive seal swaps... Braking power was pretty much the same (single finger operation), very predictable which is what you want from a front brake.
And I also sold the said 6 pots, taken apart, so no one would just put them on their bike and kill themselves.
PostPosted: 10:35 - 08 May 2019    Post subject: Re: Are braided brakes worth it? Reply with quote
I've recently goen from an 02 TDM with 100k miles on it that has had braided line for 80k miles. To a 07 TDM with 60k miles and what I assume are the original OEM Rubber lines. The braided lines gave much more feeling. The 02 bike had setup suspension a power commander and many other upgrades. The first thing I will be swapping is the braided lines.
Islander
PostPosted: 11:54 - 08 May 2019    Post subject: Reply with quote
I'd say it depends on the condition of the brake lines, master cylinder and calipers of the system you're planning on changing. If everything is in good condition and the system is properly bled then you're not going to notice any significant difference in normal road use. If the brake lines have started to degrade then you'll probably notice an improvement.
I have braided lines on three of my bikes - one I did myself and thought it was a massive improvement. But then it would have been as the pre-existing lines were obviously badly degraded (in the end one of them actually disintegrated internally and blocked the system completely, hence the replacement).
If they're cheaper than replacement OEM I'd say go for it. Thumbs Up
pepperami
PostPosted: 12:22 - 08 May 2019    Post subject: Reply with quote
Hmm?
After doing a brake refurbishment on any of the bikes I have owned, I have always changed the hoses to braided.
I can only speak for myself, but the brakes always felt better and with more bite.
Kawasaki Jimbo
PostPosted: 21:46 - 08 May 2019    Post subject: Reply with quote
pepperami wrote:
Hmm?
FTFY, and the OP alluded to the same.
MCN
PostPosted: 01:14 - 11 May 2019    Post subject: Re: Are braided brakes worth it? Reply with quote
Yes braided lines will make a lot of difference to braking feel and application time (if you split hairs), possibly braking control too.
There should be less expansion of the hose with metal braided hose then standard fiber braided hose (kevlar/rayon).
I would not replace un-braided hose with anything other than steel braided hose
The last post was made 7 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 111.37 Kb
