| EazyDuz |
 EazyDuz World Chat Champion
| Easy-X |
 Easy-X Super Spammer
| Confusion |
 Confusion Scooby Slapper
 Posted: 14:00 - 06 May 2019 Post subject: Re: Are braided brakes worth it? |
| EazyDuz wrote: | Recently did a brake fluid change as well as took the caliper off, thoroughly cleaned and lubed the sliders etc. Brakes felt better but they're not brilliant. |
What kind of bike is it? Tokico calipers by any chance?
| Quote: | The brake line is OEM rubber, now 14 years old (Unless changed before my ownership but no record of it). No signs of cracks or any weathering. |
Most service manuals advise changing brake and fuel lines
every four years. I changed mine at 16 years
| Code: | | Would I notice a difference changing to braided... |
Probably not. Changing my old OEM rubber brake lines
for new HEL braided lines made no measurable difference
to my brakes.
| Quote: | ...or would that money be better off spent on some 'sports' pads instead? |
Sports or racing pads/tyres might not be the best choice for
normal road use. They only work well within the optimum temperature
range.
| Quote: | I've read mixed opinions, with some arguing that braided lines only feel better because you're forced to change the fluid at the same time, which is the reason for the better performance. |
At the very least, you can expect good quality braided lines to
be:
As good as the original rubber lines.
Cheaper to buy
Last longer. Some have a 10 year or "lifetime" guarantee.
As you say, new lines often come with new caliper seals
and fresh fluid. ____________________ Bandit 650SA, ZZ-R1100 |
| Fisty |
 Fisty Super Spammer
| WD Forte |
 WD Forte World Chat Champion
| andym |
 andym World Chat Champion
| Kawasaki Jimbo |
| Derek Noakes |
 Derek Noakes Banned
| Nobby the Bastard |
| Teflon-Mike |
 Posted: 21:36 - 07 May 2019 Post subject: |
This is a perenial; but so many that advocate braided line over ~OE rubber, have a skew perception, having swapped out perished crap OE lines for nice new braided... how much of the 'better' is the fact that the lines are nylon and coated in shower braid, and how much 'just' cos they is new!
Having done a back-to-back swap... promted by waking up one morning, climbing on the bike and thinking "That's odd?!" when the brake lever came back to the grip, and discovering 'some-one' had half inched my brake hose.... even more curiously, they removed the brake hose, and put back not just the banjo-bolts on the caliper and master cylinder... they put the copper washers back too! A contientiouse tea-leaf that!
But, fitting brand new Braided, after pretty much brand new OE rubber... yes, there is a pretty big difference; B-U-T, a lot of it is in the sharpness of the brake, doesn't necesserily make it any more powerful.. and would that be a good thing anyway? If it lock the wheel, it will lock the wheel... and that's not usually a good thing, but book-ends the power of the brake you might use. The difference is mainly in the 'feel' and the take up not being so wooly feeling like the effect is more imediete and doing something faster.
For where your at... and I assume this be on a cruiser... where you don't necessarily need or want, direct nerve ending response or feel, the change would probably be no bad thing, if only 'cos it would beg a brake flush and overhaul, and a new hose, of either kind.
A-n-d after-market braided lines are often cheaper than OEM rubber... so pays your money and takes your chances. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| ThatDippyTwat |
| trevor saxe-coburg-gotha |
| redeem ouzzer |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 08:27 - 08 May 2019 Post subject: Re: Are braided brakes worth it? |
| Fisty wrote: | | EazyDuz wrote: | Are braided brakes worth it?. |
Yes.
/thread. |
Not really, however they are significantly cheaper than the OEM rubber brake hoses.
| trevor saxe-coburg-gotha wrote: | Tokico 6 pots |
I wasn't lucky with these. I swapped them for a standard set of Nissin 4 pots, a direct swap, I must say, and haven't had to touch the brakes ever since. No more cleaning every year, no more expensive seal swaps... Braking power was pretty much the same (single finger operation), very predictable which is what you want from a front brake.
And I also sold the said 6 pots, taken apart, so no one would just put them on their bike and kill themselves. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| chris-red |
| Islander |
 Islander World Chat Champion
 Posted: 11:54 - 08 May 2019 Post subject: |
I'd say it depends on the condition of the brake lines, master cylinder and calipers of the system you're planning on changing. If everything is in good condition and the system is properly bled then you're not going to notice any significant difference in normal road use. If the brake lines have started to degrade then you'll probably notice an improvement.
I have braided lines on three of my bikes - one I did myself and thought it was a massive improvement. But then it would have been as the pre-existing lines were obviously badly degraded (in the end one of them actually disintegrated internally and blocked the system completely, hence the replacement).
If they're cheaper than replacement OEM I'd say go for it.  |
| pepperami |
 pepperami Super Spammer
| Kawasaki Jimbo |
| MCN |
 MCN Super Spammer
The last post was made 7 years, 94 days ago. Instead of replying here, would creating a new thread be more useful? |
