| vitus detritus |
 vitus detritus Derestricted Danger
 Posted: 20:10 - 28 May 2019 Post subject: CBR929RR bypassing the charging loom |
My Stator/rectumfryer are toast. I'm sorting parts but there was a thread here https://www.bikechatforums.com/viewtopic.php?t=278089 where The Tot said 'Bypassed the internal charging loom, so my battery is effectively connected to the reg rec and alternator directly'.
Does anyone (the Tot?) know how to go about doing this ?
Thanks - ____________________ if it ain't broke, don't fix it |
 Posted: 20:36 - 28 May 2019 Post subject: |
What, to run on a total loss?
I'd have thought that would simply be a case of unplugging the reg/rec on most bikes. Then making sure you have enough charge to get where you're going. I'd suggest not using the lights or starter motor if you're going to do that.
However can you switch the headlights off on a 929? Battery wont last long if you can't. Maybe disconnect the lighting fuse too?
EDIT: Maybe I misunderstood your question.
I suspect he means he made a new sub-loom using new wire for the connections between the stator the reg/rec and the battery on the assumption he had a short somewhere in the main loom.
If it's like every other honda. Three yellow wires go from the stator to the reg/rec. Reds to the battery positive. Greens to earth. if there are more than one red or green, it is a red herring to confuse you and make you think its a more special part than it is, they all go to the same place. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kawasaki Jimbo |
 Posted: 20:43 - 28 May 2019 Post subject: |
Post #4 on a Triumphrat.net thread. There's shed-loads more info there too.
The idea is to use slightly thicker wire than stock (because manufacturers are cheapskates) and connect the two-pin +/- output of the reg/rec (image low down in post #1) via the shortest route to the battery terminals instead of via the loom. It also eliminates one connector, which is a good thing. |
| vitus detritus |
| Nobby the Bastard |
| vitus detritus |
| vitus detritus |
The last post was made 6 years, 315 days ago. Instead of replying here, would creating a new thread be more useful? |
