| EazyDuz |
 EazyDuz World Chat Champion
 Posted: 18:53 - 01 Jun 2019 Post subject: Changing fork oil, top caps... |
There must be an easier way of doing this than what I did today. I wanted to change the fork oil so:
1. Jack front end up so wheel is off the ground
2. Undo top caps with a towel over the top so they dont shoot into outer space
3. Used a vacuum pump to remove old oil, refilled with new stuff
4. Attempt to put top caps back on.
What a fukin nightmare. The main issues are:
- The springs stick out 2-3 inches
- The spring seats on the inner RIM of the top cap, so it slides off and goes flying far too easily
- The threads are very fine and made of butter
They look like this, but imagine on the underside there is about a 4mm wide rim in which the spring must sit flush on, while you push them down:
https://www.picclickimg.com/d/l400/pict/323247794193_/2007-06-09-Suzuki-Vl800-C50-Boulevard-Fork-Caps.jpg
I did eventually do it, after 3 hours trying by myself before getting a second pair of hands, and even then it took several goes.
Are a lot of bikes designed this way or is this just a Suzuki thing? I hope I never have to take them off again and if I do i'll buy new ones because they're not in the best shape after so many failed attempts ____________________ To shreds you say? Tss tss tss |
| Islander |
 Islander World Chat Champion
 Posted: 19:40 - 01 Jun 2019 Post subject: |
Next time drop the forks out of the bike - it's much easier. Doing it that way you can hold the cap and compress the spring with one hand while you rotate the stanchion to catch the start of the thread with the other.
ETA:
Also, the spring doesn't usually bear on the cap. There's the spring then a spring cap then usually a tubular spacer with the fork cap bearing on the top of the spacer. |
| EazyDuz |
| Robby |
 Robby Dirty Old Man
| Islander |
| Islander |
| EazyDuz |
| Islander |
| EazyDuz |
| Tdibs |
 Tdibs Traffic Copper
| Sister Sledge |
 Sister Sledge World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 09:14 - 02 Jun 2019 Post subject: |
Next time you do it get a 6-point socket and long extension on a T-bar. stick some tape around the hex so it jams in the socket then all you have to do it put one hand on the T-bar for pushing and turning and use the other to steady it all by holding the extension. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 21:05 - 03 Jun 2019 Post subject: |
You can also put a ratchet spanner on the hex then use a 2-leg puller hooked under the edge of the top-yoke to compress the top-cap as you turn it.
It's best to put something under the puller bolt to stop it marking the top cap.
If you think that's a bastard, you should try some kawasakis where it's just a steel plug you have to push in then fit a circlip above it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| EazyDuz |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| EazyDuz |
| ThatDippyTwat |
| sickpup |
 sickpup Old Timer
| sickpup |
 sickpup Old Timer
The last post was made 6 years, 307 days ago. Instead of replying here, would creating a new thread be more useful? |
