Changing fork oil, top caps...
EazyDuz
PostPosted: 17:53 - 01 Jun 2019    Post subject: Changing fork oil, top caps... Reply with quote
There must be an easier way of doing this than what I did today. I wanted to change the fork oil so:
1. Jack front end up so wheel is off the ground
2. Undo top caps with a towel over the top so they dont shoot into outer space
3. Used a vacuum pump to remove old oil, refilled with new stuff
4. Attempt to put top caps back on.
What a fukin nightmare. The main issues are:
- The springs stick out 2-3 inches
- The spring seats on the inner RIM of the top cap, so it slides off and goes flying far too easily
- The threads are very fine and made of butter
They look like this, but imagine on the underside there is about a 4mm wide rim in which the spring must sit flush on, while you push them down:
https://www.picclickimg.com/d/l400/pict/323247794193_/2007-06-09-Suzuki-Vl800-C50-Boulevard-Fork-Caps.jpg
I did eventually do it, after 3 hours trying by myself before getting a second pair of hands, and even then it took several goes.
Are a lot of bikes designed this way or is this just a Suzuki thing? I hope I never have to take them off again and if I do i'll buy new ones because they're not in the best shape after so many failed attempts
Islander
PostPosted: 18:40 - 01 Jun 2019    Post subject: Reply with quote
Next time drop the forks out of the bike - it's much easier. Doing it that way you can hold the cap and compress the spring with one hand while you rotate the stanchion to catch the start of the thread with the other. Thumbs Up
ETA:
Also, the spring doesn't usually bear on the cap. There's the spring then a spring cap then usually a tubular spacer with the fork cap bearing on the top of the spacer.
EazyDuz
PostPosted: 18:48 - 01 Jun 2019    Post subject: Reply with quote
Well I'm both confused and concerned now. I looked in the Haynes and found this:
https://imgur.com/31Iwycd
https://imgur.com/bej6KHc
Granted it says on models 'so equipped'. But over on the US forum I've not seen anyone complain about getting the top caps back on which makes me think they all have this spring stopper on there. So why doesn't mine have that? And is it a bit dangerous having the continuous spring pressure, especially over speed bumps etc, pushing against the top cap with only 1cm of fine thread on it? I dont get why some bikes would have this retaining bolt under the cap and others not, other than to piss off the DIY mechanic.
Robby
Dirty Old Man
PostPosted: 20:06 - 01 Jun 2019    Post subject: Reply with quote
If you didn't take the forks off and pump out the old oil, you didn't get it all out.
Islander
PostPosted: 20:14 - 01 Jun 2019    Post subject: Reply with quote
There's that too...
Islander
PostPosted: 20:26 - 01 Jun 2019    Post subject: Reply with quote
It really doesn't take that much effort to compress the spring and engage the thread, and the thread/cap arrangement is typical - it won't fail unless you're daft enough to cross thread it.
The reason it was hard was that you didn't drop the forks out of the clamps. Your forks are much the same arrangement as the ones in my 1200 Bandit and I've never had a problem with those Smile
EazyDuz
PostPosted: 20:34 - 01 Jun 2019    Post subject: Reply with quote
Delboys garage already proved that wrong. He drained one fork by turning it upside down and the other using a vacuum pump with a narrow tube, both removed the exact same amount.
Same with car oil from the dipstick hole, if you do it right you get it all out.
Islander
PostPosted: 20:53 - 01 Jun 2019    Post subject: Reply with quote
I wouldn't take Delboy's word on that - he's full of shite sometimes. Turning it upside down still doesn't get it all, Robby is right. Pump it out, refill and pump again to get the air out.
EazyDuz
PostPosted: 21:53 - 01 Jun 2019    Post subject: Reply with quote
The way this guy does it is nothing like how it went for me:
https://www.youtube.com/watch?v=OpHpPuFMV1o
at 4:25. He did that with one hand and the spring wasnt even sticking out. On mine it was sticking out a fair bit so was much more difficult to push down hard on it, and making sure it was sat flush before tightening.
Maybe mine doesnt have OEM springs
Tdibs
PostPosted: 22:24 - 01 Jun 2019    Post subject: Reply with quote
Nah depending on the model you are likely to have more spacer sticking out the top.
Dont most manuals say to air gap the fork oil level with the fork compressed (spring removed) anyhow? Need to take the forks off to do it properly imo.
Sister Sledge
PostPosted: 07:29 - 02 Jun 2019    Post subject: Reply with quote
You have to remember that with Delboy he's sponsored to the hilt by various suppliers. It's quite obvious that he's going to show that a device works perfectly. Editing removes all of the failures remember..
Think of it this way: You have a bottle and want to empty it of fluid. Unfortunately the bottle also has some gears, a few springs and a bolt inside.
Tip the bottle and all of the fluid flows past the items inside and eventually drips out. Use a straw/vacuum and fluid will always gather around and under things in the bottle.
CCM 404 DS
PostPosted: 08:14 - 02 Jun 2019    Post subject: Reply with quote
Next time you do it get a 6-point socket and long extension on a T-bar. stick some tape around the hex so it jams in the socket then all you have to do it put one hand on the T-bar for pushing and turning and use the other to steady it all by holding the extension.
PostPosted: 20:05 - 03 Jun 2019    Post subject: Reply with quote
You can also put a ratchet spanner on the hex then use a 2-leg puller hooked under the edge of the top-yoke to compress the top-cap as you turn it.
It's best to put something under the puller bolt to stop it marking the top cap.
If you think that's a bastard, you should try some kawasakis where it's just a steel plug you have to push in then fit a circlip above it.
EazyDuz
PostPosted: 16:16 - 04 Jun 2019    Post subject: Reply with quote
I think the ratchet spanner might be a worthwhile investment. Most of the issue was the hand pain from the normal ratchet digging into the palm.
Anyway was well worth doing it's completely changed how the bike behaves. It was nosediving all the time before. Didn't think a change in oil would make such a dramatic difference
ThatDippyTwat
PostPosted: 18:24 - 04 Jun 2019    Post subject: Reply with quote
Delboy's been proved wrong many, many times, gets butthurt, calls police, much boo-hoo'ing. The man is a fucking knobstain. Ignore anything you see on his channel, it's probably sponsored, irrespective of him declaring it or not.
EazyDuz
PostPosted: 12:23 - 05 Jun 2019    Post subject: Reply with quote
Lol sounds like there is a story behind this. Was he a member here or something?
ThatDippyTwat
PostPosted: 17:04 - 05 Jun 2019    Post subject: Reply with quote
Another channel called him on his bullshit. He got butthurt, called the police, lying through his teeth. There's video's about it. Also known for trying to get several channels nuked, video's deleted and/or demonetised.
sickpup
Old Timer
PostPosted: 10:35 - 09 Jun 2019    Post subject: Reply with quote
Links?
sickpup
Old Timer
PostPosted: 14:27 - 09 Jun 2019    Post subject: Reply with quote
How did you jack up the front?
I'm wondering as you need to push down pretty hard and with consistant pressure to thread the fork caps back on. Usual is a breeze block under the exhaust and someone to hold the back of the bike down while you push but it doesn't look like you did this.
The last post was made 6 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 106.36 Kb
