speedy carbs!
Speedy2
PostPosted: 22:23 - 24 Mar 2005    Post subject: speedy carbs! Reply with quote
hey my fellow bike buddys! does n e 1 have n e knolladge about peoguet carbs, i got a pretty high performance speedy 50, its got most the usual aftermarket parts but i cant afford (at the mo) a 17.5mm carb. can the original main jet be replaced or not? n if so wat mm does it need...4mm...5mm or 6mm???
Confused
The L plate Worrier! Apparently?
TheShaggyDA
Repost Police
PostPosted: 22:41 - 24 Mar 2005    Post subject: Re: speedy carbs! Reply with quote
Speedy2 wrote:
Hey, my fellow bike buddies! Does anyone have any knowledge about Peugeot carbs? I've got a pretty high performance Speedy 50 - it's got most of the usual aftermarket parts - but I can't afford (at the mo) a 17.5mm carb. Can the original main jet be replaced? If so, what size does it need - 4mm, 5mm or 6mm?
Oh hang on, no he didn't.
Speedy2
PostPosted: 22:53 - 24 Mar 2005    Post subject: evenin Reply with quote
ha ha, that doesnt reeli help me, but fanks 4 postin a reply
stevo as b4
PostPosted: 22:56 - 24 Mar 2005    Post subject: Reply with quote
You should be able to get a 17.5mm PVHA cheap from a crashed SF100. I can have a look in my Garage to see if ive still got my old SF100 carb as well, as if i do you can have it. I dont know what settings you would need to use to get it working properly with a 50 or 70cc cyl though. If your considering getting a Malossi Carb kit thats pre-jetted for your engine, then i would not assume it's anywhere near right either. The 21mm carb i fitted to my SF100 was so far out on the jetting that it took 2-3hours of dyno time (bloody expensive!) at Taffspeed to get it set up right. TBH ive had very little luck with trying to set up the carburation myself on a 2stroke, as to someone uneperienced its very easy to cause damage from running it too lean, and sometimes you think from looking at plug colours that the mixture is too rich or lean, and from the way it runs and sounds, and the reality is that the opposite is true. Also the different circuits have a big effect on each other, and for example if you have the needle jet, and jet needle set up too rich in the midrange, you have to compensate by going leaner than ideal with the main jet, which means when you do get the other circuits somewhere near right, the fueling on the main jet is going on the lean side etc. Unless you have experience with 2stroke jetting and a Dyno with an AFR sniffer inserted up the exhaust, then id leave 2stroke jetting to a professional every time!
Speedy2
PostPosted: 23:56 - 24 Mar 2005    Post subject: speedy man! Reply with quote
ummmm wats an sf100? i no my stuff about bikes but not evry bike under the sun lol, is the 17.5mm carb your on about an Arreche amal carb? if it is that shld probably bolt straight on but i'd have 2 get the after market manifold.
R4nger
PostPosted: 00:09 - 25 Mar 2005    Post subject: Reply with quote
a? ru sure that is txtalk?
Now, being very polite I suggest you learn some english words.
stevo as b4
PostPosted: 00:20 - 25 Mar 2005    Post subject: Reply with quote
SF100= Speedfight 100cc. Im assuming your bike is a Speedfight 50? Im not sure if i have the old carb still, or if i sold it with the bike. I'll have a look tomorrow when im home from work, and let you know ok. The 100cc uses a Dellorto PHVA 17.5mm, with an auto choke. It may fit you existing inlet manifold, if the carb OD (outside diameter) is similar to your existing carb. If ive got the manifold, you can have that too.
Speedy2
PostPosted: 16:43 - 26 Mar 2005    Post subject: speedyMAN! Reply with quote
That sounds perfect, yeah it is the speedy 50 but i would guess the 100 and 50 are almost identicle anyway. top banan! Thumbs Up
The last post was made 21 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 56.08 Kb
