fitting a monoshock
leolion
PostPosted: 18:51 - 11 Jun 2019    Post subject: fitting a monoshock Reply with quote
Easy job?
Does the swing arm collapse when the shocks removed?
Do i need a spring compressor?
Might upgrade to a ktech at some point and id like to do it myself.
Old Git Racing
PostPosted: 19:02 - 11 Jun 2019    Post subject: Reply with quote
Yes it does. No you dont.
What bike?
OGR
RhynoCZ
PostPosted: 20:10 - 11 Jun 2019    Post subject: Reply with quote
Why do you replace it?
johnsmith222
PostPosted: 12:41 - 12 Jun 2019    Post subject: Reply with quote
It's not particularly difficult if you have a way of supporting the bike when the shock is removed.
e.g. centre stand, or swingarm bolt stand (like ABBA, NWS etc)
You might want to consider greasing your shock linkage while you're at it though.
c_dug
PostPosted: 13:09 - 12 Jun 2019    Post subject: Reply with quote
A friend to help makes it easier, but perfectly possible to do alone if you have an appropriate stand.
PostPosted: 15:42 - 12 Jun 2019    Post subject: Reply with quote
Some are easier than others. Some bikes with single-side swingarms can be a total sod, for example VFR750s are near impossible until you find out that you need to remove the battery and undo a special hatch in the bottom of the battery box to lift it out through.
leolion
PostPosted: 15:55 - 12 Jun 2019    Post subject: Reply with quote
MT 07 original going rusty
johnsmith222
PostPosted: 14:07 - 13 Jun 2019    Post subject: Reply with quote
If rust is the only issue, and you are happy with the handling, then you might as well just keep it on there. You could perhaps paint the spring to clean it up.
Of course if this is dangerous corrosion then definitely get it replaced.
The last post was made 7 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 54.8 Kb
