Chain master link?
TravisBickle
PostPosted: 18:24 - 11 Jun 2019    Post subject: Chain master link? Reply with quote
Can someone help me please?
I booked my 2002 Fazer 600 in to have the chain and sprockets changed, I supplied the parts, now the garage has rung me saying I've ordered the wrong chain because it doesn't have a master link and so it won't go round the swinging arm.
Am I being dumb or is it him? I wouldn't have thought threading the chain through the hole in the swinging arm with the chain doubled-up would have been a problem?
If I need to order a new chain is there something specific I need to enter into the search in order to get one with a master link? The chain I ordered was DID gold X-ring 530 with 110 links https://www.ebay.co.uk/itm/DID-Gold-X-Ring-Drive-Chain-Pitch-530-110-Links-Yamaha-XJR-1300-2011/292356397379?hash=item4411cc9943:g:80MAAOSwWCZaJHZ2&frcectupt=true
It's the model before the fox eye face lift in case that makes a difference! The first incarnation with the square headlights.
Cheers!
PostPosted: 18:36 - 11 Jun 2019    Post subject: Reply with quote
The chain is endless out of the box? Seems odd but I suppose it could happen. Usually the master link comes in a packet in the box.
I wonder if it actually HAS got a rivet link fitted but not riveted and they haven't spotted that?
If it is the case then they are right they will not be able to fit the chain without cutting it. One option you have is to buy a rivet master link and ask them to cut one link out and use that. Make sure you get the correct one.
TravisBickle
PostPosted: 18:42 - 11 Jun 2019    Post subject: Reply with quote
Ok that's interesting, thank you.
He did mention that although the chain is clearly unused, it was loose in the box and said they usually come shrink-wrapped. Could this possibly be an item that someone has riveted closed into a complete loop before fitting, realised their mistake and returned it to the seller I wonder...
PostPosted: 18:44 - 11 Jun 2019    Post subject: Reply with quote
He's right, if it's a genuine DID then it would be in a greasy packet, and so would the link. Why not have him check to see if there is already a rivet link fitted?
TravisBickle
PostPosted: 18:46 - 11 Jun 2019    Post subject: Reply with quote
Will do, thank you.
Sounds increasingly like either a fake or a returned item Sad
davebike
PostPosted: 11:44 - 12 Jun 2019    Post subject: Reply with quote
Looks like a chain sold as a loop A few owners like them Swing arm has to come out to fit Or you order the Correct soft link and cut and rejoin
I REALLY love customers that get the parts I take the Swing arm out and fit say 4 hours and £200 !
Dave
NC750Xdct + others at work !
[email protected]
Bhud
PostPosted: 11:55 - 12 Jun 2019    Post subject: Reply with quote
I have an endless chain in storage. It's vacuum-packed and a genuine item (Honda stamp and serial number). However, it's not a DID chain.
PostPosted: 15:51 - 12 Jun 2019    Post subject: Reply with quote
As above, you CAN buy endless chains but the swingarm needs to be removed to fit it.
In fairness, it doesn't need to be entirely removed, you can simply take the long bolt out and move it to one side a bit in most cases, you just need a big enough gap to feed the chain through. I've done it at the side of the road before when all I could get was an endless after my chain snapped. When I've done it, I never removed the wheel or shock, just the swingarm pivot bolt and one of the chainguard bolts. From memory, I might not even have taken the pivot all the way out.
If it's for an XJR, you'd need to take one of the shocks off too.
In fact, I'd go so far as to say it might actually be quicker than fucking about with a chain rivetting tool in many cases. Thinking
TravisBickle
PostPosted: 23:35 - 12 Jun 2019    Post subject: Reply with quote
Thanks guys, input much appreciated.
No it's not for an XJR, that's just what it's advertised that it's for on their eBay listing. I done some research and decided on the chain I wanted and typed the specs into the eBay search and that was the cheapest one that came up. I just assumed if the pitch, width and number of links were correct then it would be compatible regardless.
This is the response the seller gave:
bikeaholics_uk wrote:
Hi,
Thank you for your email and your purchase.
We are sorry to hear that you have a problem with the item you bought from us.
We will send you a genuine DID rivet type master link ASAP
This is an endless chain.
It is regularly used on high-performance bikes as there is no weak link.
All links closed by the manufacturer in the best possible way.
Brand new bikes also fitted with endless chains.
Please check our buying guide:
https://www.ebaystores.co.uk/bikeaholicscouk/pages/chains
If you require any further information or have any questions, please do not hesitate to contact us.
Regards,
bikeaholics_uk
We'll see what the garage say when this link turns up. He said he didn't want to start chopping up a brand new chain but seems he doesn't want to remove the swingarm so I guess this is the next best thing right?
Bhud
PostPosted: 23:52 - 12 Jun 2019    Post subject: Reply with quote
What they wrote to you is correct. However, you are also correct insofar as any chain with the right pitch and number of links will do the job. I would just recommend never going for the cheapest chain - even if it's DID. DID's cheapest tends to rust fast (in my experience) and doesn't last that long. Not that it will cause a problem - it's just something I found. As I don't use garages for regular maintenance tasks I prefer endless chains because the thought of one breaking on me while riding because of a failed master link or because of a bad rivet contorting it fills me with dread. However, if a garage is fitting your chain it doesn't matter.
TravisBickle
PostPosted: 00:02 - 13 Jun 2019    Post subject: Reply with quote
Sorry I should have been clearer, this wasn't simply the cheapest compatible DID chain (of any type) I could find, I chose the best DID chain available for my bike and then went about finding the cheapest place to get it from. It's the gold-coloured heavy duty X-ring chain. Cost just under £100.
TravisBickle
PostPosted: 00:05 - 13 Jun 2019    Post subject: Reply with quote
Not that I suppose it makes a difference but the gold coloured ones are slightly more expensive than the grey ones. But it matches my red and gold sprocket so I'm happy :-p
Bhud
PostPosted: 00:11 - 13 Jun 2019    Post subject: Reply with quote
I got the longest life out of any chain I've ever had from a gold DID X-ring chain. It lasted an incredibly long time, and I didn't even lubricate it with dedicated chain lube - I used a "substitute". Embarassed
When it failed it did so all at once though. I remember that. If memory serves, it had tens of thousands of miles on it and still looked new, when it suddenly developed not one but several very stiff links. It was like it just happened overnight. That's a great chain - I had it on a heavily modded XJ600. The Japanese recommend changing these at much shorter intervals but I don't think anyone does that in the UK.
TravisBickle
PostPosted: 00:15 - 13 Jun 2019    Post subject: Reply with quote
With the mileage I do (not very much), to be honest I'd be perfectly happy to change it once a year just for peace of mind. Not that expensive really.
TravisBickle
PostPosted: 00:24 - 13 Jun 2019    Post subject: Reply with quote
So what was the substitute you were using?
Bhud
PostPosted: 00:32 - 13 Jun 2019    Post subject: Reply with quote
Used engine oil, applied about once a week, after the bike had been ridden back home. It prevents some rust and cleans off some dirt but I don't recommend this because the oil gets flicked away as soon as you ride away again. I believe, and I haven't tested this, that chain waxes offer the best chain protection because they stick to the chain. Chain cleaning, on the other hand, is just to wipe away particles and moisture. As you say, chains are consumable items and they will deteriorate and need replacement anyway. If you ride in the rain (I used to commute by bike) then chain cleaning and protection should be a major concern. Otherwise, I wouldn't worry about it apart from a wipedown because the links are sealed and you know the chain is wearing away anyway. Everyone has their own attitude about chains but it matters the most to commuters, who ride in all weathers and especially in the winter.
The last post was made 7 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 90.27 Kb
