| TravisBickle |
 TravisBickle World Chat Champion
 Posted: 18:24 - 11 Jun 2019 Post subject: Chain master link? |
Can someone help me please?
I booked my 2002 Fazer 600 in to have the chain and sprockets changed, I supplied the parts, now the garage has rung me saying I've ordered the wrong chain because it doesn't have a master link and so it won't go round the swinging arm.
Am I being dumb or is it him? I wouldn't have thought threading the chain through the hole in the swinging arm with the chain doubled-up would have been a problem?
If I need to order a new chain is there something specific I need to enter into the search in order to get one with a master link? The chain I ordered was DID gold X-ring 530 with 110 links https://www.ebay.co.uk/itm/DID-Gold-X-Ring-Drive-Chain-Pitch-530-110-Links-Yamaha-XJR-1300-2011/292356397379?hash=item4411cc9943:g:80MAAOSwWCZaJHZ2&frcectupt=true
It's the model before the fox eye face lift in case that makes a difference! The first incarnation with the square headlights.
Cheers! |
 Posted: 18:36 - 11 Jun 2019 Post subject: |
The chain is endless out of the box? Seems odd but I suppose it could happen. Usually the master link comes in a packet in the box.
I wonder if it actually HAS got a rivet link fitted but not riveted and they haven't spotted that?
If it is the case then they are right they will not be able to fit the chain without cutting it. One option you have is to buy a rivet master link and ask them to cut one link out and use that. Make sure you get the correct one. ____________________ a.k.a 'Geri'
| TravisBickle |
| TravisBickle |
 Posted: 18:46 - 11 Jun 2019 Post subject: |
Will do, thank you.
Sounds increasingly like either a fake or a returned item  |
| davebike |
 davebike World Chat Champion
 Posted: 11:44 - 12 Jun 2019 Post subject: |
Looks like a chain sold as a loop A few owners like them Swing arm has to come out to fit Or you order the Correct soft link and cut and rejoin
I REALLY love customers that get the parts I take the Swing arm out and fit say 4 hours and £200 ! ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Bhud |
 Bhud World Chat Champion
 Posted: 15:51 - 12 Jun 2019 Post subject: |
As above, you CAN buy endless chains but the swingarm needs to be removed to fit it.
In fairness, it doesn't need to be entirely removed, you can simply take the long bolt out and move it to one side a bit in most cases, you just need a big enough gap to feed the chain through. I've done it at the side of the road before when all I could get was an endless after my chain snapped. When I've done it, I never removed the wheel or shock, just the swingarm pivot bolt and one of the chainguard bolts. From memory, I might not even have taken the pivot all the way out.
If it's for an XJR, you'd need to take one of the shocks off too.
In fact, I'd go so far as to say it might actually be quicker than fucking about with a chain rivetting tool in many cases.  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| TravisBickle |
 Posted: 23:35 - 12 Jun 2019 Post subject: |
Thanks guys, input much appreciated.
No it's not for an XJR, that's just what it's advertised that it's for on their eBay listing. I done some research and decided on the chain I wanted and typed the specs into the eBay search and that was the cheapest one that came up. I just assumed if the pitch, width and number of links were correct then it would be compatible regardless.
This is the response the seller gave:
| bikeaholics_uk wrote: | Hi,
Thank you for your email and your purchase.
We are sorry to hear that you have a problem with the item you bought from us.
We will send you a genuine DID rivet type master link ASAP
This is an endless chain.
It is regularly used on high-performance bikes as there is no weak link.
All links closed by the manufacturer in the best possible way.
Brand new bikes also fitted with endless chains.
Please check our buying guide:
https://www.ebaystores.co.uk/bikeaholicscouk/pages/chains
If you require any further information or have any questions, please do not hesitate to contact us.
Regards,
bikeaholics_uk |
We'll see what the garage say when this link turns up. He said he didn't want to start chopping up a brand new chain but seems he doesn't want to remove the swingarm so I guess this is the next best thing right? |
| Bhud |
| TravisBickle |
| TravisBickle |
| Bhud |
| TravisBickle |
| TravisBickle |
| Bhud |
The last post was made 7 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
