| 2StrokeNoob |
 2StrokeNoob L Plate Warrior
 - Super Spammer
 Posted: 08:41 - 14 Jun 2019 Post subject: |
As you've posted nothing about it's history with regards to mileage and piston/ring changes, i'd start by checking compression or taking the barrel off and measuring the clearance between barrel and piston skirt at the bottom.
If you don't know when the piston and rings were last changed, this needs doing anyway, otherwise it could go bang at any moment and cause further damage to the cylinder and crank.
Other options are a dirty carb, blocked carb jets and passageways, or a clogged air filter. It's also possible for the expansion chamber and silencer to get clogged with soot and oily deposits. The expansion chambers cam be taken off and either filled with caustic soda or set fire to, in order to burn off the internal soot. The silencer depends if it has baffling material or not. Some allow the material to be taken out and changed. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| 2StrokeNoob |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
 - Super Spammer
 Posted: 14:00 - 14 Jun 2019 Post subject: |
Has it got KIPS, Their version of power valve?
If it hasn’t got the servo and just a blanking plate, rotating it to fully open will lose a bit of low to mid range but up the top end by a fair whack.
https://www.bikechatforums.com/viewtopic.php?t=85130#post_1010430 ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| stevo as b4 |
The last post was made 7 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
