| Riejufixing |
| colink98 |
 colink98 Could Be A Chat Bot
| Robby |
 Robby Dirty Old Man
| Riejufixing |
| Riejufixing |
| ThatDippyTwat |
| Riejufixing |
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Riejufixing |
 Posted: 00:10 - 01 Jul 2019 Post subject: |
| UnknownStuntman wrote: | I see your beef with the design, but it's like that to add strength. The ones you've ground down will be wibbly before you know it. As above, proper rim protectors should sort any damage. |
I'm not at all sure it'll be "wibbly"; the grinding sparks & process indicate a highish-carbon steel, and the metal itself is hard, tough and springy (as implied in OP). It "rings". I was wondering about buying another lever for a knife or something, but I can't remember where I bought them. I think they're "Silverline", so I was surprised because I expected monkey metal. I'll look tomorrow. We'll see. I use thin PET (!) for rim protectors anyway, but the beauty of the rounded edges is more in the hugely reduced tendency to cut the bead.
If I do buy another lever or pair for experimentation, I'll post!
Extra note: the chromium-plated finish is crap. Very thin, apparently deposited over mill scale, which means it flakes (well as much as thin chrome *can* flake). |
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 19:53 - 01 Jul 2019 Post subject: |
I have the same type ... I did the same as you and ground the strengthening ridges down, although not as far up as you have done.
Regards using with rim protectors ... I always use them and the ridges tend to dig into the plastic and can cut through them eventually ... hence the reason I ground them down.
The levers are relatively cheap and a bit of grinding and they become good levers
All the best ... Barry
P.S. Yes the finish is crap ... but I can live with that. |
| ThatDippyTwat |
| Riejufixing |
| G |
 G The Voice of Reason
| A100man |
 A100man World Chat Champion
 Posted: 14:40 - 02 Jul 2019 Post subject: |
| BanditsHigh wrote: | I have the same type ... I did the same as you and ground the strengthening ridges down, although not as far up as you have done.
Lol! ^^ +1 ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| Suntan Sid |
 Posted: 16:05 - 02 Jul 2019 Post subject: |
Last time I found myself without tyre levers, I went out and bought three large flat screwdrivers, less than 2 euros each, smoothed the sharp edges off, they worked fine. ____________________ "Everybody needs money, that's why they call it money!"  |
| Riejufixing |
The last post was made 6 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
