Tyre levers reworked.
Riejufixing
PostPosted: 21:04 - 28 Jun 2019    Post subject: Tyre levers reworked. Reply with quote
Bought some tyre levers like the below.
Don't buy. Avoid. The elongated figure-of-8 cross section causes rim damage, and the sharp edges of the ends damage tyres.
So, the "straight" ends were ground down flat with an angle grinder, the edges rounded, and then smoothed with a belt sander, and now they're good. The metal itself is excellent, but the design is appalling.
There are lots of used tyre levers on e-Bay, with flat ends. I'd buy those if I needed more.
colink98
PostPosted: 07:41 - 29 Jun 2019    Post subject: Reply with quote
where the picture of the reworked ones ?
that's the point of interest.
Ride it like you stole it.
Robby
Dirty Old Man
PostPosted: 10:14 - 29 Jun 2019    Post subject: Reply with quote
I use levers like that all the time. You need rim protectors and soap.
Riejufixing
PostPosted: 10:35 - 29 Jun 2019    Post subject: Reply with quote
ColinK98 wrote:
where the picture of the reworked ones ? that's the point of interest.
Aha. Here:
Riejufixing
PostPosted: 10:41 - 29 Jun 2019    Post subject: Reply with quote
If you smooth them down, they're much, much better. It's not just the "flanges" damaging the rims (I use plastic rim protectors anyway), it's that they don't cut the bead. Well worth doing.
ThatDippyTwat
PostPosted: 17:27 - 29 Jun 2019    Post subject: Reply with quote
Motion Pro bedbreakers. Job done. They "just work".
Not cheap, but 2-3 visits to have loose tyre fitted would be about the same.
Riejufixing
PostPosted: 18:30 - 29 Jun 2019    Post subject: Reply with quote
I don't like the look of those at all, sorry, not for breaking the bead, although the tyre levering end might be OK.
UnknownStuntm...
PostPosted: 22:24 - 30 Jun 2019    Post subject: Reply with quote
I see your beef with the design, but it's like that to add strength. The ones you've ground down will be wibbly before you know it. As above, proper rim protectors should sort any damage.
Riejufixing
PostPosted: 00:10 - 01 Jul 2019    Post subject: Reply with quote
I'm not at all sure it'll be "wibbly"; the grinding sparks & process indicate a highish-carbon steel, and the metal itself is hard, tough and springy (as implied in OP). It "rings". I was wondering about buying another lever for a knife or something, but I can't remember where I bought them. I think they're "Silverline", so I was surprised because I expected monkey metal. I'll look tomorrow. We'll see. I use thin PET (!) for rim protectors anyway, but the beauty of the rounded edges is more in the hugely reduced tendency to cut the bead.
If I do buy another lever or pair for experimentation, I'll post!
Extra note: the chromium-plated finish is crap. Very thin, apparently deposited over mill scale, which means it flakes (well as much as thin chrome *can* flake).
BanditsHigh
Worse than a woman
PostPosted: 19:53 - 01 Jul 2019    Post subject: Reply with quote
I have the same type ... I did the same as you and ground the strengthening ridges down, although not as far up as you have done.
Regards using with rim protectors ... I always use them and the ridges tend to dig into the plastic and can cut through them eventually ... hence the reason I ground them down.
The levers are relatively cheap and a bit of grinding and they become good levers Thumbs Up
All the best ... Barry
P.S. Yes the finish is crap ... but I can live with that.
ThatDippyTwat
PostPosted: 20:13 - 01 Jul 2019    Post subject: Reply with quote
You may not like the look, but they work exceedingly well. Popped the bead on a 20yr old tyre when other methods, including cheap levers, failed dismally.
Riejufixing
PostPosted: 22:01 - 01 Jul 2019    Post subject: Reply with quote
Same here. The metal's still about 5mm thick
The ones I have do not have a name or anything on them.
PostPosted: 13:25 - 02 Jul 2019    Post subject: Reply with quote
Or just get some spoon-type ones in the first place?
Much better for bikes I'd say.
https://images-na.ssl-images-amazon.com/images/I/519xPhsybIL._SY355_.jpg
A100man
PostPosted: 14:40 - 02 Jul 2019    Post subject: Reply with quote
Lol! ^^ +1
Suntan Sid
PostPosted: 16:05 - 02 Jul 2019    Post subject: Reply with quote
Last time I found myself without tyre levers, I went out and bought three large flat screwdrivers, less than 2 euros each, smoothed the sharp edges off, they worked fine.
Riejufixing
PostPosted: 19:37 - 02 Jul 2019    Post subject: Reply with quote
See OP. Yes, I'd get those, but I don't like the "handles" at all. These sorts here are quite nice:
https://www.ebay.co.uk/itm/Vintage-Renshaw-8-1-2-tyre-lever/283527692230?hash=item4203913fc6:g:82wAAOSwf71dEkDe
The edges are decent. Had I not already got a set of tyre levers, I'd buy them! Bargain!
The last post was made 7 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 88.81 Kb
