Light Up My Garage!
Xarell
PostPosted: 11:41 - 02 Jul 2019    Post subject: Light Up My Garage! Reply with quote
As the title suggests,
I need some opinions / ideas on the best approach to lighting my garage
https://10carbest.com/best-led-garage-lights .
The usual single fluro light just doesn't do it for me as I like to "tinker" on my cars or bikes and there is nothing worse than having to get a work lamp out because you can't bloody see.
Do I use 4 fluros? Except 2 would be hidden if the garage. Door was up?
Also want to be able to see with ease when 2 cars are parked in garage.
Open to suggestions.
Thanks.
Easy-X
PostPosted: 12:26 - 02 Jul 2019    Post subject: Reply with quote
How about some LED spot lights nailed to the wall. Point 'em where ya need 'em Smile
ThunderGuts
PostPosted: 14:02 - 02 Jul 2019    Post subject: Reply with quote
I use these LED striplights https://www.screwfix.com/p/luceco-single-4ft-t8-led-weatherproof-led-batten-1-x-18w-1500lm/2979ts in my garage - they produce a really good light. Nothing stopping you wiring a few onto the walls too?
Don't underestimate the power of painting walls/ceilings (and even floors!) a pale colour either - it massively helps reflect light around.
TG.
I painted my walls white and got some LED lubes. Its plenty bright.
Edit photos added to show off Cool
https://i.imgur.com/hDM7LRu.jpg
https://i.imgur.com/xTGgamM.jpg
https://i.imgur.com/yKIwvMf.jpg
https://i.imgur.com/CaZ8T8b.jpg
https://i.imgur.com/3Cas4wT.jpg
Edit lighting is with 3 of these.
https://www.screwfix.com/p/lap-twin-led-batten-60w-5600lm-5ft/7223v
Also these are wired in with 2 of these one by each door on a 5 minute timer.
https://www.screwfix.com/p/zinc-pir-sensor-360/301fh
I have never had to use the light switch they are great, lights come on as soon as I open either door.
ThunderGuts
PostPosted: 14:15 - 02 Jul 2019    Post subject: Reply with quote
I like the idea of wiring it into a PIR (I'm thinking now for my loft rather than garage) - is it easy enough to do?
TG.
Smiffy77
PostPosted: 14:40 - 02 Jul 2019    Post subject: Reply with quote
Another option if you have sockets about is some fluorescent strips that work with 'smart' hubs which you can set to come on at certain time or when you enter a location.
My mates got some Philips hue strips which he says light up pretty well. As mentioned, paint makes a massive difference too
Smiffy77
PostPosted: 14:42 - 02 Jul 2019    Post subject: Reply with quote
chris-red wrote:
Edit photos added to show off.
Gotta say I'm pretty jealous of your set up
MCN
PostPosted: 17:57 - 02 Jul 2019    Post subject: Reply with quote
LED lights use much less energy than tungsten filament lamps so you can go much higher in brightness for less shillings in your meter.
LED lamps are not cheap. Of course there are cheap Leads but they may not be reliable.
Buy from known makes.
Kawasaki Jimbo
PostPosted: 19:25 - 02 Jul 2019    Post subject: Reply with quote
+1 for white walls. I also lay white-faced fibre boards across the rafters for storage and light reflection. I do miss having a garage with mains lighting and power though.
Sister Sledge
PostPosted: 08:08 - 03 Jul 2019    Post subject: Reply with quote
^^ That.
Paint the walls white and light generated is reflected back into the space. Even if you use that old leftover white emulsion pant that's hidden laying forgotten in a corner it's better than nothing.
Brickwork is super absorbent and painting will take ages to get that first good coat on but it's well worth the effort.
CCM 404 DS
The last post was made 7 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 16 - Page Size: 67.09 Kb
