DT125 - Electrical issues - sparks all the time
SiWard
PostPosted: 20:53 - 21 Jul 2019    Post subject: DT125 - Electrical issues - sparks all the time Reply with quote
Hi All, Im new to the forum and looking for some help..... My son and I bought a DT125R from eBay that had electrical damage to wiring after someone had tried to steal it, mainly all wires ripped off the back of the rev counter and ignition. We reconnected all these (Correctly I have good basic knowledge and can use a meter to test a switch or for continuity) and tested all for continuity including ignition switch, dead mans switch etc, following Haynes manual wiring diagram DT-3RM9, bike actually has loom 3RM20. Anyway with the ignition switch in the off position the bike has a spark !!!!, turning ignition on it sparks once then no spark (the ignition is definitely working, when switched on connects red and brown and also connects blue yellow to blue black (kill switch is shorted for now), with battery disconnected has a spark with ignition on and off.... Mad or what.... most people cant get a spark we get one when we don't want one (by the way bike fully dismantled and not in state to run). I have checked every wire in the loom for continuity so I know these are all OK. The only thing missing from the bike is the reed switch and side stand switch, so I am thinking CDI is knackered or could it be something on the charging unit of the stator providing high voltage to the CDI and killing it, by the way I have checked the resistance on the Source and pulser coils and both are OK, I cant find anything that tells me how to check the lightening/charging coils (when I check continuity from the 4 way plug that connect to the coils I can see that all connections have a resistance to earth on the stator plate (all 4 wires)is this correct?.... Any and all ideas are most welcome as we are completely stuck Sad, Thanks, Simon
Easy-X
PostPosted: 21:42 - 21 Jul 2019    Post subject: Reply with quote
Has to be a wiring issue. I would have thought that ignition off would route the coil power to ground otherwise what's the point Smile
What year is this BTW?
SiWard
PostPosted: 21:47 - 21 Jul 2019    Post subject: Reply with quote
It’s a 2001
Robby
Dirty Old Man
PostPosted: 23:18 - 21 Jul 2019    Post subject: Reply with quote
Ignition switch, particularly if it's a basic 3-wire one.
All the ignition switch does it dump circuits back to ground in the off position. Ripping the wires out the back does the same job as putting a key in it.
So I would be making sure that the ground wire on the ignition switch is connected to the switch and the loom/frame.
jaffa90
PostPosted: 00:59 - 22 Jul 2019    Post subject: Reply with quote
"""""Anyway with the ignition switch in the off position the bike has a spark !!!!, """""
So where is the live coming from?
A switch is a switch, usually giving a live feed to the fuse box and circuits.
SiWard
PostPosted: 09:29 - 22 Jul 2019    Post subject: Reply with quote
Hi All, thank you for your replies the help is very much appreciated - I have attached the wiring diagram for reference - the ignition is circled.
I cant see that it puts anything to ground though for someone like me its a very complicated drawing.
I have checked every wire goes to or connects to where it should go. The only ones I have issues with are the Reed switch which is missing (so wires open ended on either side of this) and the side stand switch which is also missing (I have had this open and closed), the dead mans switch is shorted at the moment.
There is no fuse box, only fuse is on the live from the battery.
Maybe worth mentioning that when I turn the key to the on position the power valve does its reset (which it should do).
What can I check next?
Thanks, Simon
Nobby the Bastard
Harley Gaydar
PostPosted: 11:08 - 22 Jul 2019    Post subject: Reply with quote
Thanks, Simon
It could still be the ignition switch, not breaking the connection when you turn it off.
Unplug the connector block and see if it stops.
Triumph Sprint ST 1050
Easy-X
PostPosted: 12:07 - 22 Jul 2019    Post subject: Reply with quote
Ah well, scratch what I said about grounding the coil. That's a thing for older bikes Smile
I take it item 9 on the diagram is the ECU? Looks like that controls the spark directly... and that "knows" to power up via a live feed from the ignition switch.
I think we're all on the same page with this one Very Happy
SiWard
PostPosted: 12:55 - 22 Jul 2019    Post subject: Reply with quote
yes 9 on the diagram is the ECU, when you say we are all on the same page, are you saying you think its probably an ECU / CDI fault?
Its obviously and expensive thing to replace so im open to testing anything else I can before looking for one Smile
Can anyone think of anything else I could look at....
If the reed switch is cut off / missing, is there something I can put in its place ore can I connect the two wires together?
Thanks,
Simon
Easy-X
PostPosted: 13:23 - 22 Jul 2019    Post subject: Reply with quote
Lol... no I meant there has to be something up with the ignition switch or related wiring Smile
A "reed" switch just describes any magnetically activated switch... its still a switch! So if you have to, wire in a traditional switch for testing or just twist the wires together.
What's this reed switch actually for?
SiWard
PostPosted: 13:56 - 22 Jul 2019    Post subject: Reply with quote
The read switch is part of a circuit to restrict the bike to a lower performance. it sits in the beck of the speedo usually, people move it away from the speedo to derestrict it but all forums say don't cut it off..... someone kindly cut ours off for us and I am at a loss as to what to do there now Smile
I have tested the ignition with a multi meter and its doing the right thing in that it connects 2 wires together on one side and 2 wires together on the other. That's why I was looking at the Magneto / Stator to see if the issue could be something there shorting.
Simon
Nobby the Bastard
Harley Gaydar
PostPosted: 15:01 - 22 Jul 2019    Post subject: Reply with quote
Simon
Does the ignition switch break the connections when you turn it in the off position?
SiWard
PostPosted: 16:51 - 22 Jul 2019    Post subject: Reply with quote
Hi Nobby, ignition off breaks all connections...… ignition on connects red and brown and also connects blue/yellow to blue/black.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:09 - 22 Jul 2019    Post subject: Reply with quote
Have you actually tested this?
SiWard
PostPosted: 17:21 - 22 Jul 2019    Post subject: Reply with quote
yes I have tested it, via a multi meter for continuity to all the wires, the switch is definitely working as it should. (I am 100% positive)
The spark only stops when we connect the battery up, if we disconnect the rectifier, ignition, the stator charging wires, the battery and the power valve it still sparks.
Its doing our heads in...…….
Robby
Dirty Old Man
PostPosted: 17:54 - 22 Jul 2019    Post subject: Reply with quote
First off, one problem at a time. When everything is installed and connected up properly, does it work normally? Are we chasing a real problem here?
Secondly, I'd be looking for a frame earthing problem. If it behaves when the battery is connected, then something is managing to use the loom earth back to the battery. If the loom isn't connected to the battery, then it can't do that.
Frame earths are always a pain in the arse. Hidden away behind things, often where rotten wires get pulled out of crimps when you dismantle something else. The good side is that it's easy to add more. I tend to add a new earth cable from the battery negative to the frame, and also add in a new earth from the loom to frame at the headlight and tail light.
SiWard
PostPosted: 18:05 - 22 Jul 2019    Post subject: Reply with quote
Hi Robby, good advice, lets start at the beginning and work through with some method.
Current state of the bike is its stripped down, frame, engine, forks wheels and wiring loom in place missing is all the lights, speedo and rev counter, side stand switch is missing, dead switch is shorted and REED Switch is missing.
Im happy to go either way, I can put everything back on or strip more off, I left all the lights off to reduce the number of wires to trace while we tried to fix this spark issue but I can easily put all that back on if you think I should start from all built.
When I got the bike they were all on except the reed switch, side stand switch, rev counter and ignition, eBay advert said simply reconnect wires and away you go...... yeah right lol.
This said we (my son and I have had 4 of these in the past 10 years) so we know them pretty well Smile Never seen anything like this before though.
So do I leave it with the minimum running wires or put it all together and work back?
Im in the hands of you guys......
Simon
SiWard
PostPosted: 18:09 - 22 Jul 2019    Post subject: Reply with quote
By the way I have had the loom off the bike and tested every wire and connection, end to end for continuity. then put it back on the bike with the same result as I started with, personally I don't think its a wiring problem unless it relates to the reed switch but I cant see that cutting that off would do this.
Robby
Dirty Old Man
PostPosted: 08:41 - 23 Jul 2019    Post subject: Reply with quote
Its hard enough to trace a wiring diagram normally. Its even harder when bits aren't plugged in. Even worse when some bits earth direct to the frame, but the wiring diagram doesn't show it (does happen, if it earths by having the unit bolted to the frame rather than by using a wire).
So put it all together and see if it starts behaving. Something in the current setup must be providing 12v to the CDI down the blue and yellow wire.
If it was me, I would be replacing the ignition switch.
SiWard
PostPosted: 20:18 - 24 Jul 2019    Post subject: Reply with quote
Thanks for all the ideas and replies, I’m planning to do more investigation tomorrow and will update on how things go.
Simon
SiWard
PostPosted: 19:41 - 25 Jul 2019    Post subject: Reply with quote
All, Its been a good day, I have managed to fix the bike, the problem was traced to a wire in the loom that was broken but made an intermittent connection, As I said I had already removed all the wiring loom and laid it out then tested each and every wire for continuity, all checked out OK, put it back on the bike and wired everything up but still didn't work, so today I worked through it again on the bike testing each and every wire and suddenly found one that didn't have continuity it was broken where it wrapped around a bend on the frame.... very frustrating but very satisfying to hear it run.....
Thanks to everyone for their suggestions and help,
Simon
The last post was made 6 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.33 - MySQL Queries: 13 - Page Size: 119.27 Kb
