| SiWard |
 SiWard Derestricted Danger
 Posted: 20:53 - 21 Jul 2019 Post subject: DT125 - Electrical issues - sparks all the time |
Hi All, Im new to the forum and looking for some help..... My son and I bought a DT125R from eBay that had electrical damage to wiring after someone had tried to steal it, mainly all wires ripped off the back of the rev counter and ignition. We reconnected all these (Correctly I have good basic knowledge and can use a meter to test a switch or for continuity) and tested all for continuity including ignition switch, dead mans switch etc, following Haynes manual wiring diagram DT-3RM9, bike actually has loom 3RM20. Anyway with the ignition switch in the off position the bike has a spark !!!!, turning ignition on it sparks once then no spark (the ignition is definitely working, when switched on connects red and brown and also connects blue yellow to blue black (kill switch is shorted for now), with battery disconnected has a spark with ignition on and off.... Mad or what.... most people cant get a spark we get one when we don't want one (by the way bike fully dismantled and not in state to run). I have checked every wire in the loom for continuity so I know these are all OK. The only thing missing from the bike is the reed switch and side stand switch, so I am thinking CDI is knackered or could it be something on the charging unit of the stator providing high voltage to the CDI and killing it, by the way I have checked the resistance on the Source and pulser coils and both are OK, I cant find anything that tells me how to check the lightening/charging coils (when I check continuity from the 4 way plug that connect to the coils I can see that all connections have a resistance to earth on the stator plate (all 4 wires)is this correct?.... Any and all ideas are most welcome as we are completely stuck , Thanks, Simon |
| Easy-X |
 Easy-X Super Spammer
 Posted: 21:42 - 21 Jul 2019 Post subject: |
Has to be a wiring issue. I would have thought that ignition off would route the coil power to ground otherwise what's the point
What year is this BTW? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| SiWard |
| Robby |
 Robby Dirty Old Man
| jaffa90 |
 jaffa90 World Chat Champion
| SiWard |
| Nobby the Bastard |
| Easy-X |
 Posted: 12:07 - 22 Jul 2019 Post subject: |
Ah well, scratch what I said about grounding the coil. That's a thing for older bikes
I take it item 9 on the diagram is the ECU? Looks like that controls the spark directly... and that "knows" to power up via a live feed from the ignition switch.
I think we're all on the same page with this one  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| SiWard |
 Posted: 12:55 - 22 Jul 2019 Post subject: |
yes 9 on the diagram is the ECU, when you say we are all on the same page, are you saying you think its probably an ECU / CDI fault?
Its obviously and expensive thing to replace so im open to testing anything else I can before looking for one
Can anyone think of anything else I could look at....
If the reed switch is cut off / missing, is there something I can put in its place ore can I connect the two wires together?
Thanks,
Simon |
| Easy-X |
 Posted: 13:23 - 22 Jul 2019 Post subject: |
Lol... no I meant there has to be something up with the ignition switch or related wiring
A "reed" switch just describes any magnetically activated switch... its still a switch! So if you have to, wire in a traditional switch for testing or just twist the wires together.
What's this reed switch actually for? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| SiWard |
 Posted: 13:56 - 22 Jul 2019 Post subject: |
The read switch is part of a circuit to restrict the bike to a lower performance. it sits in the beck of the speedo usually, people move it away from the speedo to derestrict it but all forums say don't cut it off..... someone kindly cut ours off for us and I am at a loss as to what to do there now
I have tested the ignition with a multi meter and its doing the right thing in that it connects 2 wires together on one side and 2 wires together on the other. That's why I was looking at the Magneto / Stator to see if the issue could be something there shorting.
Simon |
| Nobby the Bastard |
 - Super Spammer
| SiWard |
| Nobby the Bastard |
| SiWard |
| Robby |
 Robby Dirty Old Man
| SiWard |
 Posted: 18:05 - 22 Jul 2019 Post subject: |
Hi Robby, good advice, lets start at the beginning and work through with some method.
Current state of the bike is its stripped down, frame, engine, forks wheels and wiring loom in place missing is all the lights, speedo and rev counter, side stand switch is missing, dead switch is shorted and REED Switch is missing.
Im happy to go either way, I can put everything back on or strip more off, I left all the lights off to reduce the number of wires to trace while we tried to fix this spark issue but I can easily put all that back on if you think I should start from all built.
When I got the bike they were all on except the reed switch, side stand switch, rev counter and ignition, eBay advert said simply reconnect wires and away you go...... yeah right lol.
This said we (my son and I have had 4 of these in the past 10 years) so we know them pretty well Never seen anything like this before though.
So do I leave it with the minimum running wires or put it all together and work back?
Im in the hands of you guys......
Simon |
| SiWard |
| Robby |
 Robby Dirty Old Man
 - Super Spammer
| SiWard |
| SiWard |
The last post was made 6 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
