Alloy sump plug thread stripped. Urgent! (FIXED)
Riejufixing
PostPosted: 19:03 - 31 Jul 2019    Post subject: Alloy sump plug thread stripped. Urgent! (FIXED) Reply with quote
Well, posting here 'cos it's probably a problem for bikes too, but it's actually on my van.
Decided to change the oil myself, drained the oil, and the plug was tight all the way out. Now it's drained, I can see there's a nice alloy spring (displaced) in the hole, and a couple of intact threads at the top (inside end) of the hole.
I'm thinking of pulling out the stripped thread, and gently screwing a sparking plug in there, and holding it at the outer end with some epoxy, or even RTV silicone, temporarily. Good idea/bad idea/any other ideas?
If anyone knows a supplier of repair kits (tap/oversize plug) in the MK area, I'd love to hear about it. I need to use my van!
ARGH!
BusterGonads
PostPosted: 19:12 - 31 Jul 2019    Post subject: Reply with quote
Whatever you do, make sure that the plug you put in can't work itself loose and dump the oil.... Not only will that kill the engine, it will probably kill a biker riding onto the resulting oil slick.
I know YOU know this, but some random reader may not.... Unlikely - but possible.
Grubscrew
PostPosted: 19:15 - 31 Jul 2019    Post subject: Reply with quote
What ever you try to epoxy in there to create a seal, it’ll have to be thoroughly de greased for the stuff to adhere.
You could try to fold into a tube some aluminium foil, thickness will depend on how chewed up the thread is and wind in the plug perhaps.
Good luck!
FJR1300/CBR1000F
Riejufixing
Yes. I'm just going out to see how many threads are left. Grr (cough National) grr!
PostPosted: 19:16 - 31 Jul 2019    Post subject: Reply with quote
Go to machine mart.
Buy this: https://www.machinemart.co.uk/p/clarke-cht800-drain-plug-thread-repair-kit/
Use it.
Riejufixing
PostPosted: 20:04 - 31 Jul 2019    Post subject: Reply with quote
Thanks, that was the general idea, but need a bodge for tomorrow. Nearest MM is in bldy Luton. Got 3 threads left in hole.
F.
F.
F.
F.
MCN
PostPosted: 20:57 - 31 Jul 2019    Post subject: Reply with quote
B&Q. 1mtr of dowel.
Sand the end to a taper.
Your epoxy of choice. (I'd pick up the fast setting one when getting the dowel)
Brake Clean the plug hole as clean AF.
Slobber the mixed epoxy on your prepared dowel.
Ram/Screw the hoowur in using a pipe wrench/vice-gripes/big pliers.
Light a couple of candles to St. Joseph (Patron Saint of Bodging)
Fill sump and forget.
I've seen loads of shit held together with worserer.
It's a sort of African/Former Socialist Republic bodge/permanent repair.
Robby
Dirty Old Man
PostPosted: 21:39 - 31 Jul 2019    Post subject: Reply with quote
You are not getting that van into a safe condition to drive until you fix the hole properly. So it looks like you're riding to Luton first thing in the morning.
Riejufixing
Hm, I've got some spring toggles (for fixing stuff to plasterboard).
Riejufixing
PostPosted: 21:42 - 31 Jul 2019    Post subject: Reply with quote
No transport at the moment. Might be able to get someone to go, I suppose. I might go and see if the local garage will lend for a payment & big deposit. I doubt it. I ain't pushing the thing there though.
virus
PostPosted: 22:46 - 31 Jul 2019    Post subject: Reply with quote
got a halfords closer?
https://www.halfords.com/motoring/car-parts/engine-parts/sump-plug-sump-pan/halfords-universal-sump-plug-hfx693?istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istFeedId=367c5610-f937-4c81-8609-f84582324cd6&istItemId=rwxatrqr&istBid=t&_$ja=tsid:94971|cid:868641090|agid:42483198623|tid:aud-297219198129:pla-330303157881|crid:203456298918|nw:g|rnd:6043576492803335273|dvc:c|adp:1o1|mt:|loc:1006891&gclid=CjwKCAjw-ITqBRB7EiwAZ1c5U10di9GVfmIzrkYu3Ytm5runGfMC2nMubALoPIyPjpYWQLRi4sUjNhoCjigQAvD_BwE
own: 81 xs1100g...
Old Git Racing
PostPosted: 23:15 - 31 Jul 2019    Post subject: Reply with quote
What Van?
PostPosted: 23:41 - 31 Jul 2019    Post subject: Reply with quote
virus wrote:
Wow! That is so horriffic I can't believe it's actually a thing.
Do it!
virus
PostPosted: 23:44 - 31 Jul 2019    Post subject: Reply with quote
Do it!
whats the worst that can happen? Laughing
own: 81 xs1100g...
Riejufixing
PostPosted: 23:48 - 31 Jul 2019    Post subject: Reply with quote
Old Git Racing wrote:
What Van?
Scudo 2L. Alloy sump, M14x1.25 thread.
Riejufixing
PostPosted: 23:56 - 31 Jul 2019    Post subject: Reply with quote
virus wrote:
got a halfords closer? (Halfords thing)
Wow. It looks a bit better than a plasterboard fixing. Might get me to Luton and back.... might get to Heathrow & back...
ThunderGuts
PostPosted: 12:20 - 01 Aug 2019    Post subject: Reply with quote
Whatever bodge you do, I'd be starting to look on eBay for a replacement sump. You'll probably need a new gasket too.
TG.
Bhud
PostPosted: 12:32 - 01 Aug 2019    Post subject: Reply with quote
I've had this problem before. I tried various "solutions" (although not a helicoil or rethread) and none of them worked. It just resulted in a mess. Oil always finds a way. Buy a replacement sump and sump gasket. Before you do so, check you can reach all the allen bolts from underneath.
Riejufixing
PostPosted: 14:58 - 01 Aug 2019    Post subject: Re: Alloy sump plug thread stripped. Urgent! (fixed) Reply with quote
Riejufixing wrote:
(stripped sump plug thread)
I borrowed (from the local garage!) a sparking-plug repair kit, which contained a stepped M14x1.25 tap (14mm section to guide, plus larger diameter section to cut thread for helicoil), plus a helicoil insert and a helicoil installation tool.
Worked well. Job done.
Tankie
PostPosted: 19:07 - 01 Aug 2019    Post subject: Reply with quote
Now wasn't that easy!
Riejufixing
PostPosted: 22:31 - 01 Aug 2019    Post subject: Reply with quote
It was l the scrabbling about to get the required both fast and near that was the problem. Various bodges would have ensued this afternoon. Favourite possible beer tin or plasterboard fixing.
MCN
PostPosted: 10:35 - 02 Aug 2019    Post subject: Reply with quote
[quote="Riejufixing"]
It was l the scrabbling about to get the required both fast and near that was the problem. Various bodges would have ensued this afternoon. Favourite possible beer tin or plasterboard fixing.[/quote
I'm shocked that no one suggested Sillycunt Sealant. Thinking
ThunderGuts
PostPosted: 16:30 - 02 Aug 2019    Post subject: Re: Alloy sump plug thread stripped. Urgent! (fixed) Reply with quote
I’d be mega careful in future - not usually that many threads on a sump compared with a spark plug socket? Easy to mash up?
TG.
doggone
PostPosted: 16:36 - 02 Aug 2019    Post subject: Reply with quote
Having never done this to any vehicle why is it a rather common problem?
Lack of 'feel' for when it's tight enough?
Trying to stop a drip because new washer was not acquired?
Turning forcefully the wrong way when trying to remove it?
Thinking
PostPosted: 16:40 - 02 Aug 2019    Post subject: Reply with quote
Thinking
Because the garages don't remove them to drain the oil on cars/vans. They suck it out through the dipstick hole then refill it again (leaving all the sludge in the bottom of the engine).
So by the time you've stopped dealer servicing them, they have had 5+ years to electrochemically weld themselves to the alloy and the thread comes out with the plug because you're the first person to touch it since the assembly line when it was put in dry.
The last post was made 6 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.11 - MySQL Queries: 13 - Page Size: 128.96 Kb
