| Peak District Rider |
 Peak District Rider L Plate Warrior
 Posted: 18:15 - 01 Aug 2019 Post subject: |
So, in the interests of clarity, you want to fit a switch to allow you to manually turn the fan on sooner than the sensor would?
The fan switch has two terminals. Attach a wire to each of these using a piggy-back terminal and connect one to each ternimal on your switch. So the manual switch is connected in paralell with the fan switch. The fan will come on as normal when the engine overheats. If you flick the switch, it will come on anyway.
Worth considering why you want to do this. Why wouldn't the fan be kicking in when it ought to? Fan switches don't often fail, they are also cheap and easy to replace if they do. So is the coolant level where it should be?
In my head, fitting a manual fan switch is a mental sticking plaster for a blown head gasket. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
| Tankie |
 Tankie Crazy Courier
| MarJay |
 MarJay But it's British!
| raesewell |
 raesewell Traffic Copper
 Posted: 21:50 - 01 Aug 2019 Post subject: |
Do not under any circumstances use scotch Loks, they will fail.
Posi taps are the way to go if you don't use piggy backs.
https://posi-connect.com/collections/posi-tap ____________________ Yamaha FJR 1300 Normanton West Yorkshire |
| Shaft |
 Shaft World Chat Champion
The last post was made 6 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
