Suzuki GS500 Oil Filter nut spinning
dan.porter15
PostPosted: 11:52 - 10 Aug 2019    Post subject: Suzuki GS500 Oil Filter nut spinning Reply with quote
Hi all,
Just attempted to remove my oil filter and one of the nuts is just spinning: https://imgur.com/a/DDuBPSG
I'm assuming the nut is stuck to the bolt. I've tried to wedge a screwdriver under it and using a socket to get it off with no luck, also tried getting some pliers on it and twisting/pulling.
Done a bit of googling and seems to be a common problem with these bikes, but other posts seem to have got the nut off which I'm not having much luck with.
Any ideas?
Riejufixing
PostPosted: 14:10 - 10 Aug 2019    Post subject: Reply with quote
Can you get a nut splitter on it (or even the jaws of a bolt cropper)? If not, is it possible to support the nut on one side (with e.g. a hammer head) while you drive a (sharp) cold chisel into it from the other? You split the thing "across", by the way, from one side to the other.
8< #////=====
8< Bolt cropper
# Nut
/ threads
= bolt
dan.porter15
PostPosted: 18:03 - 10 Aug 2019    Post subject: Reply with quote
Thanks for your response, I managed to get it off by wedging a screwdriver under the oil filter cover, and slowly bringing the nut out with a socket.
My issue now is the thread has been completely chewed off, I'm struggling to get the stud out: https://imgur.com/a/kYOv4ZI
Attempted to stick two nuts on and lock them together to bring it out, but as you can see from the photos there's not a lot of thread for the nuts to grab. Mole grips and pliers don't seem to work either, and I'm at a bit of a loss again.
I don't own a dremel or anything like that to try get it off that way, and my nearest shop which would sell one (halfords, which is a bus journey away Rolling Eyes ) is shut now.
Any clever methods of getting these things off that doesn't involve power tools? Very Happy
Previous: 2010 Sinnis Max 125, 2009 Sym XS 125
Current: 1992 Suzuki GS500E, 2005 Honda CBR125R
Riejufixing
PostPosted: 18:29 - 10 Aug 2019    Post subject: Reply with quote
Have you got heat (e.g. a gas torch), and some small stillsons, or a Footprint pipe wrench? If so, heat up the stud and surrounding area, and wind it out.
If you have a welder, weld a nut on, and go on that.
Perhaps someone nearby has such things, if you don't?
dan.porter15
PostPosted: 18:45 - 10 Aug 2019    Post subject: Reply with quote
Didn't have a torch so used a BBQ lighter Razz but seemed to do the trick!
Here's an after image of the stud... it's pretty bad
https://imgur.com/a/ppcrlDx
Thanks!
BusterGonads
PostPosted: 08:18 - 11 Aug 2019    Post subject: Reply with quote
I can 'feel' your relief as that stud started to come out.
I expect most of us have been there and felt the sickening grief as that sort of problem unfolded and then - sometimes - the uplift of relief as the solution unfolded.
I keep looking at the corroded, horrible threads sticking out of the exhaust nut on the exhaust port of my beater CG125 and wondering how it will be next time I need to take that exhaust off. The bike isn't worth anything much, and it is one of three, so I won't be bikeless if things go wrong, but I think I know it is going to be a bastard when I want it out. I'm thinking I should get some penetrating oil on it now, and when it is out, I might renew the stud and in future make sure I have graphite on those threads. Graphite is one of the few lubricants that will stand that kind of heat and still work as intended when the time comes to remove the nut or the stud. Come to think of it, I think last time I had it off, it was teh stud that came out, and I don't like that either because the aluminium will wear out and lead to a world of misery.
MCN
PostPosted: 15:56 - 11 Aug 2019    Post subject: Reply with quote
Thanks!
https://www.google.com/imgres?imgurl=https%3A%2F%2Fi.imgur.com%2FtTc9cKQ.gif&imgrefurl=https%3A%2F%2Fimgur.com%2Fgallery%2FtTc9cKQ&tbnid=SfBI3kH865eqRM&vet=1&docid=9dP-RKhw-ahbTM&w=196&h=181&source=sh%2Fx%2Fim
PostPosted: 16:01 - 11 Aug 2019    Post subject: Reply with quote
Couple of other alternatives for exhaust studs. One is to use a LONG nut that covers all the thread. Honda used to do this a lot in the 90's and it worked well. They had special extra-long chromed steel flange nuts just for the job.
Another is to use a brass nut that will a) Not corrode much anyway and b) Strip out well before the steel threads on the stud get damaged.
MCN
PostPosted: 16:12 - 11 Aug 2019    Post subject: Reply with quote
And don't do the fcukirz up too tight when fitting the manifold. Rolling Eyes
Sound and Clean threads and possibly some moly paste.
Riejufixing
PostPosted: 16:29 - 11 Aug 2019    Post subject: Reply with quote
Brass nuts have generally been used on exhaust studs. I have heard advice to "tighten until they just start to squeak"! However I would recommend sticking to normal practice.
Copper, copper-coated steel or bronze nuts, which can make corrosion worse, should be avoided.
MCN
PostPosted: 16:41 - 11 Aug 2019    Post subject: Reply with quote
https://www.rocol.com/news/anti-seize-product-selection
Info.
Riejufixing
PostPosted: 16:56 - 11 Aug 2019    Post subject: Reply with quote
Info.
I've got some of the old version of that, which contains lead and is poisonous. You can't get it now. I'd hope that the new lead-free stuff is just as good. It's excellent for anti-sieze purposes (I think I've mentioned it before in BCF).
MCN
PostPosted: 17:44 - 11 Aug 2019    Post subject: Reply with quote
Riejufixing wrote:
Info.
It's a bit like buying a dog.
Too many varieties to just guess and take any pup.
I rarely use a copper based anti-seize now as the moly types are far superior and more stable.
Another point of note is when any lube is used on a fastener the pressure exerted on the parts is drastically increased and even the fastener can fail due to excess loading. Some specs state no lube for that reason.
Specifically soft aluminium alloy parts that will crush under the pressure applied by the bolts.
That's why tightening carefully is advised.
Torque specs are useful for those that do not know what tight means. (You know? The people who do up a drain plug like its holding the earth on its axis. Rolling Eyes )
Riejufixing
PostPosted: 20:43 - 11 Aug 2019    Post subject: Reply with quote
They're generally designed for ;lubricating sliding surfaces, though; CV joints is a very good example. Anti-sieze compounds are for preventing siezing of fasteners and galling when things are bolted up or undone. I've heard that they can be used on steam gaskets too, but I've never come across that application, Mr PB might've.
Yes, of course. However, many people will be aware that lubricating fasteners increases their "pull" for a given torque. There's no need to do up manifold nuts, spark plugs, etc. very tight. As they say: "you can't make a gas-tight seal more gas-tight".
Ah. I guess that's a reference to my Scudo's sump plug. "National" have a lot to answer for. I used to know the bloke at my local branch, but he's buzzed off down to Devon. They've also dented the underside of a previous car of mine, and shredded the rack and pinion bellows by not releasing it when undoing/doing up the track rod end. If I go & get a new tyre, I take off the wheel trims first, so they can't eff them up too. Disgraceful.
Easy-X
PostPosted: 00:23 - 12 Aug 2019    Post subject: Reply with quote
Wise words. And conversely "is it under pressure? is it under load? get out the torque wrench, look up the specs"
BusterGonads
PostPosted: 07:17 - 12 Aug 2019    Post subject: Reply with quote
A few years back, I bought a little bottle of graphite powder for lubing locks. It is a very very fine powder - dust really. I'm thinking of mixing some with a bit of grease for threads like exhaust studs. Graphite is an excellent high temperature lubricant. The grease would evaporate and burn away, but the graphite wouldn't and it is very slippery stuff.
2023 Royal Enfield Classic 350; 2000 Honda CG125; 1997 Honda Nighthawk CB250
The last post was made 7 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 96.06 Kb
