| dan.porter15 |
 dan.porter15 Two Stroke Sniffer
 Posted: 11:52 - 10 Aug 2019 Post subject: Suzuki GS500 Oil Filter nut spinning |
Hi all,
Just attempted to remove my oil filter and one of the nuts is just spinning: https://imgur.com/a/DDuBPSG
I'm assuming the nut is stuck to the bolt. I've tried to wedge a screwdriver under it and using a socket to get it off with no luck, also tried getting some pliers on it and twisting/pulling.
Done a bit of googling and seems to be a common problem with these bikes, but other posts seem to have got the nut off which I'm not having much luck with.
Any ideas? |
| Riejufixing |
| dan.porter15 |
 Posted: 18:03 - 10 Aug 2019 Post subject: |
Thanks for your response, I managed to get it off by wedging a screwdriver under the oil filter cover, and slowly bringing the nut out with a socket.
My issue now is the thread has been completely chewed off, I'm struggling to get the stud out: https://imgur.com/a/kYOv4ZI
Attempted to stick two nuts on and lock them together to bring it out, but as you can see from the photos there's not a lot of thread for the nuts to grab. Mole grips and pliers don't seem to work either, and I'm at a bit of a loss again.
I don't own a dremel or anything like that to try get it off that way, and my nearest shop which would sell one (halfords, which is a bus journey away ) is shut now.
Any clever methods of getting these things off that doesn't involve power tools?  ____________________ Previous: 2010 Sinnis Max 125, 2009 Sym XS 125
Current: 1992 Suzuki GS500E, 2005 Honda CBR125R |
| Riejufixing |
| dan.porter15 |
 Posted: 18:45 - 10 Aug 2019 Post subject: |
Didn't have a torch so used a BBQ lighter but seemed to do the trick!
Here's an after image of the stud... it's pretty bad
https://imgur.com/a/ppcrlDx
Thanks! ____________________ Previous: 2010 Sinnis Max 125, 2009 Sym XS 125
| BusterGonads |
 BusterGonads Trackday Trickster
| MCN |
 MCN Super Spammer
 Posted: 16:01 - 11 Aug 2019 Post subject: |
Couple of other alternatives for exhaust studs. One is to use a LONG nut that covers all the thread. Honda used to do this a lot in the 90's and it worked well. They had special extra-long chromed steel flange nuts just for the job.
Another is to use a brass nut that will a) Not corrode much anyway and b) Strip out well before the steel threads on the stud get damaged. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
| Riejufixing |
| MCN |
 MCN Super Spammer
| Riejufixing |
| MCN |
 MCN Super Spammer
| Riejufixing |
 Posted: 20:43 - 11 Aug 2019 Post subject: |
| MCN wrote: | | Riejufixing wrote: |
I've got some of the old version of that, which contains lead and is poisonous. You can't get it now. I'd hope that the new lead-free stuff is just as good. It's excellent for anti-sieze purposes (I think I've mentioned it before in BCF). |
I rarely use a copper based anti-seize now as the moly types are far superior and more stable.
They're generally designed for ;lubricating sliding surfaces, though; CV joints is a very good example. Anti-sieze compounds are for preventing siezing of fasteners and galling when things are bolted up or undone. I've heard that they can be used on steam gaskets too, but I've never come across that application, Mr PB might've.
| MCN wrote: | Another point of note is when any lube is used on a fastener the pressure exerted on the parts is drastically increased and even the fastener can fail due to excess loading. Some specs state no lube for that reason.
Specifically soft aluminium alloy parts that will crush under the pressure applied by the bolts.
That's why tightening carefully is advised. |
Yes, of course. However, many people will be aware that lubricating fasteners increases their "pull" for a given torque. There's no need to do up manifold nuts, spark plugs, etc. very tight. As they say: "you can't make a gas-tight seal more gas-tight".
| MCN wrote: | Torque specs are useful for those that do not know what tight means. (You know? The people who do up a drain plug like its holding the earth on its axis.  ) |
Ah. I guess that's a reference to my Scudo's sump plug. "National" have a lot to answer for. I used to know the bloke at my local branch, but he's buzzed off down to Devon. They've also dented the underside of a previous car of mine, and shredded the rack and pinion bellows by not releasing it when undoing/doing up the track rod end. If I go & get a new tyre, I take off the wheel trims first, so they can't eff them up too. Disgraceful. |
| Easy-X |
 Easy-X Super Spammer
 Posted: 00:23 - 12 Aug 2019 Post subject: |
| Riejufixing wrote: | Yes, of course. However, many people will be aware that lubricating fasteners increases their "pull" for a given torque. There's no need to do up manifold nuts, spark plugs, etc. very tight. As they say: "you can't make a gas-tight seal more gas-tight". |
Wise words. And conversely "is it under pressure? is it under load? get out the torque wrench, look up the specs" ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| BusterGonads |
The last post was made 7 years, 78 days ago. Instead of replying here, would creating a new thread be more useful? |
